Old Apr 24, 2012, 08:26 AM
jocanon is offline
Find More Posts by jocanon
jocanon's Avatar
United States, AZ, Phoenix
Joined Jul 2010
Sorry if this is a dumb question, but do these balsa wood air frames ever "expire". Like say for instance I by an airframe and just hold onto it for a couple years, are there any problems with that, like will the wood warp or does it grow old or brittle with time or anything like that? I imagine some of the hobby shops have some of these airframes on their shelves for a couple years sometimes before selling them, so I think it would be fine, I don't know, any ideas out there? I ask because I got an Extra 300 EXP 48" but don't think I am going to be able to get all the electronics for a while so I am wondering if it will keep fine in the box for a couple years or so.
jocanon is offline Find More Posts by jocanon
Site Sponsor
Old Apr 24, 2012, 08:44 AM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
It's mainly how you store them to be honest..they can warp as you say but with careful storage at right temps and avoiding moisture or excessive heat...you should in theory keep these for a long time...
the old fabric covered plane...were an issue as they would rot
Space Bat is offline Find More Posts by Space Bat
Old Apr 24, 2012, 08:48 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
I have it in my living room, so it will basically be stored at room temperature.
Site Sponsor
Old Apr 24, 2012, 08:59 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Yes, but you usually have to give them some help.
Doc Austin is online now Find More Posts by Doc Austin
Old Apr 24, 2012, 09:05 AM
Team Hillbilly (UK)
Space Bat's Avatar
Joined Oct 2011
PMSL - yer doc shure knows about MTBF (mean time before failure) and HALT (highly accelerated life testing) testing for sure
Old Apr 24, 2012, 09:26 AM
propchief is online now
Find More Posts by propchief
JKasprak
propchief's Avatar
Fayetteville, NC 28304
Joined Jan 2010
It will be fine for a long time. I've had/seen many models brought out after a long period of storage and flying with success. Especially in your case as you will go over each piece during assembly.
propchief is online now Find More Posts by propchief
Old Apr 24, 2012, 09:42 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
My nitroplanes stored for about 15years still are fine.
stgdz is offline Find More Posts by stgdz
Old Apr 24, 2012, 09:46 AM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Thanks for all the responses. Sounds like it should be fine.
Site Sponsor
Old Apr 24, 2012, 11:34 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Just dont store it anywhere with moisture, like a garage that floods or basement that floods... I have had a Sebart Pitts Python 50e that I was unaware mold had taken to the wings under the covering- First blender and .... well, the wings fold. It had previously been stored in an full scale airplane hangar that was in disrepair and had water issues.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Apr 24, 2012, 01:52 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
I have a couple servo questions for the Extra EXP 48". So do most people use the HS65 on ailerons and rudder and HS85 on the elevator? What about the digital 5065 servo, are they much better than the analog HS65? Does the 6v bec provide enough current for all digital servos? I assume it does since it was reccommended. Also, can you mix the digital servos on the ailerons and rudder with an analog HS85 on the elevator, or would a digital 5065 be as good as the analog HS85?
Site Sponsor
Old Apr 24, 2012, 02:02 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
i bought a extra exp used and it has 5065 on all surfaces running the internal 6v bec of the airboss esc. Works great i havent felt any blowback on the surfaces and there is a difference to be felt between the digital and non digital servos
shadow102 is offline Find More Posts by shadow102
Old Apr 24, 2012, 02:06 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
All digital for me - I have 5065's on aileron and rudder and a 5085 on elevator.
This allows me to use the High Speed (11ms) mode on my DX8.
You can mix digital and analog servos but you will have to use Low Speed.
The advantage of digital servos is that their speed and torque is the same throughout the travel. Analog reaches maximum torque only at the maximum travel point.
Digital servos more power than an analog - may or may not be a problem depending on your setup.
JC
ps - I originally had a 5065 on the elevator. But with 88 degrees of up throw desired, it wasn't up to the job.
JC Spohr is offline Find More Posts by JC Spohr
Old Apr 24, 2012, 02:15 PM
jocanon is offline
jocanon's Avatar
Joined Jul 2010
Using Airboss 45A Esc, the one that comes with the combo pack, is that what you are using on the all digital set up with HS-5085MG in elevator?
Site Sponsor
Old Apr 24, 2012, 02:54 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Yes - the current EF power package with Torque motor and the 45A Airboss w/ 6v BEC built-in.
12x6 APC prop and 2650 batteries - plenty of performance and flight times around 7-8 minutes.
JC
Old Apr 24, 2012, 02:59 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Unless you want to step up to 5s
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 12533 Jun 24, 2016 09:44 PM
Sold Extreme Flight Extra EXP 48 RTF HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2010 09:47 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Sold Extreme Flight EXP Extra 48inch (Red n Black) HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2010 01:43 AM
Sold Extreme Flight Edge 540 EXP Rc_heli_flier Aircraft - Electric - Airplanes (FS/W) 4 Sep 01, 2010 11:51 AM
