Old Nov 27, 2011, 12:32 PM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Since you are powering the Rx by the Bec Pro, you are only monitoring the voltage output of the Bec, not the flight pack, right ?
Regard running 2s directly to the servos, I think one 2s 1500/1800 mah 25c should be plenty for the servos (more than 30A of current available) --> should not sag below 7.0 V, IMO.
Vien
vienquach is offline Find More Posts by vienquach
Old Nov 27, 2011, 05:29 PM
Micronics is offline
Find More Posts by Micronics
Micronics's Avatar
Italy, Lazio, Rome
Yes its gas, with dle 55. Im powering it with dual battery switch (emcotec) high voltage from 2 2S 2100mah battery 20C. Your right, i get some Blow Back. I dont think its my power source cause I think it can handle the power of the servos. For the Geometry of arm and horn well I followed the manual. Another thing is I change it from Blue Bird servos that have 25kg. of tourque, TG and HV aswell. Thats why I get this new servos with much more torque but same result. Maybe I'll try another set of servos for my ailerons. Any suggestions.
Micronics is offline Find More Posts by Micronics
Old Nov 27, 2011, 05:45 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Originally Posted by Micronics View Post
Guys, I have some question about my plane... Its not an EXP but still its an Extremeflight.
Its a 88" Edge. Even though, I have 2 48", 1 60" extra & 1 edge EXP. I have this problem with my 88" Edge. When I fly it slow to mid stick trottle my roll it a bit fast but not fast enough for my taste, when half throttle to full, the roll is so slow and its like I'm in low rate even I have full deflection (50').I think my servos are stalling. What bothers me is that I have 30kgs. Of torque each of my servo. Its Dymond 9999 TG. Its a titinium gear, High Voltage, .11 sec. Of speed at 7.4 volts. Now whats wrong with my plane or setup?
I'm running JR 8911HV servos on mine and get zero blow back even at crazy speed. I would look at your servos first.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Nov 27, 2011, 08:08 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Try getting a high quality camera zoomed in on your plane and roll it and see if you are actually getting blow back...
Tom K. is offline Find More Posts by Tom K.
Old Nov 27, 2011, 08:53 PM
jwilliamsrc is offline
Find More Posts by jwilliamsrc
Team Extreme Flight, JR, BandE
Georgetown, IN
Joined Dec 2003
I used the Airtronics 94780 on my ailerons, overkill but I never starve for power.
Jeff
jwilliamsrc is offline Find More Posts by jwilliamsrc
Old Nov 27, 2011, 08:57 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
anyone here play around with the little blade helis at all? I was thinking about picking one up as I noticed that it helped me out with orientation a bit more.
Figured it would help with orientation in tumbles, its getting cold up here and I need something to do inside
stgdz is offline Find More Posts by stgdz
Old Nov 27, 2011, 08:58 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Inside as in living room or as in gym?
--Tom K.
Old Nov 27, 2011, 10:11 PM
stgdz is offline
stgdz's Avatar
Joined Jul 2011
living room, gym is for the foamie but most of them don't stay open at night
Old Nov 28, 2011, 12:53 AM
jlloyd1995 is offline
Find More Posts by jlloyd1995
jlloyd1995's Avatar
United States, OR, Molalla
Joined Oct 2010
Better yet, he should get a cheap key chain camera and mount it on the fuselage facing the aileron.
jlloyd1995 is offline Find More Posts by jlloyd1995
Old Nov 28, 2011, 04:15 AM
Micronics's Avatar
Italy, Lazio, Rome
Yes I got one of those micro cameras. I'll put one on my next flight to see whats happening in a high speed full trottle roll. Anyway thanks forthe help guys. I'll report back bt the time I solved the problem. By the way I'm beginning to put my 60" Extra EXP. I know I gonna love this plane more than my 2 48",because bigger is better.
Old Nov 28, 2011, 07:01 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
The 60" Extra EXP is amazing!!! It's My favorite bird right now, due to how convenient it is.. I'm loving the 7min flight times, and massive power that the torgue,airboss,3600 6s combo provides. I'm loading the car to go fly mine as we speak!
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Nov 28, 2011, 09:19 AM
kellyzo6 is offline
Find More Posts by kellyzo6
kellyzo6's Avatar
United States, VA, Berryville
Joined May 2010
Hey Tim What are you doing to get the 60" to fit in your car? I have a RAV 4 and can just get my 48" Edge to fit in the back behind the back seat. Thanks Kelly
kellyzo6 is offline Find More Posts by kellyzo6
Old Nov 28, 2011, 11:08 AM
Joined Oct 2008
I take the wings off,and bag them for safety..The plane comes with a nice bag, made of the aircell material(like the larger planes) that keep them cool in the car. I also make sure the wing bag shades the canopy in the car .. It only takes two minutes to throw them on, and if it's a lunch break, or a fast flight at the park, I'll just skip the SFG's.
I like the size because I can still get away with flying it at parks, construction sights, etc..
It's Still a BIG plane!
Old Nov 28, 2011, 12:22 PM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Jealous me ????? eeerrr Yep !
Raining and windy here in the UK
Kris... is offline Find More Posts by Kris...
Old Nov 28, 2011, 01:29 PM
CRFan1 is offline
Find More Posts by CRFan1
Northwest Indiana
Joined Feb 2011
Tim, what 3600 Lipos are you using? I am going to order my Extra when the next batch comes in and was thinking about the Gens Ace 6s 3800's....
My kid has the 3300's and the plane is awesome too....
CRFan1 is offline Find More Posts by CRFan1
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 12224 Yesterday 12:27 PM
Sold Extreme Flight Extra EXP 48 RTF HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2010 10:47 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 07:45 AM
Sold Extreme Flight EXP Extra 48inch (Red n Black) HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2010 02:43 AM
Sold Extreme Flight Edge 540 EXP Rc_heli_flier Aircraft - Electric - Airplanes (FS/W) 4 Sep 01, 2010 12:51 PM
