Old Dec 21, 2010, 05:09 PM
Twisted Realm is offline
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
Sexy,,, ah plane that is.
the sliver in the red scheme really looks hot!
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Old Dec 22, 2010, 09:04 AM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
My Edge EXP is "bar none" the best 48" class plane I have flown. I have had a bunch of the other popular brand 48" size planes and they were always lacking something at one end of the performance envelope or the other. But this Edge compromises nothing, just a great flying plane.
I'm really looking forward to the 60" Edge and will be picking up a 48" MXS for spring also. By the way, is there an email notification list I can get on for the 60" or do I just need to keep watching on the 60" thread for pre-orders?
So the next question for Chris is: are there any new 48" EXP's on the horizon?
dawg
r/cdawg is offline Find More Posts by r/cdawg
Old Dec 22, 2010, 09:06 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Damm. I was going to buy the red/white/blue, but now I have to buy the red/yellow/black too. This is getting expensive.
Doc Austin is offline Find More Posts by Doc Austin
Old Dec 22, 2010, 09:34 AM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
Dawg, your SFG' are different, aren't they? Not just recovered red?
The red looks great as they don't stand out as much!
aerosheldon is offline Find More Posts by aerosheldon
Old Dec 22, 2010, 09:37 AM
r/cdawg is offline
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
I had to rebuild them after a lot of knife edge abuse. While I was doing that I made a quick substitute set set from 6mm depron. I have since gone back to the original black SFG's, and have been abusing them again.
Old Dec 22, 2010, 09:39 AM
Joined Sep 2003
Thanks, I like the RED! Abuse away....
Old Dec 22, 2010, 11:12 AM
EXTREME FLIGHT is offline
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
r/cdawg, RCGers will get the first notice when we begin taking orders.
More 48" EXP madness in the works!
EXTREME FLIGHT is offline Find More Posts by EXTREME FLIGHT
Old Dec 22, 2010, 12:00 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Yesterday's 4s MXS beatdowns............
Old Dec 22, 2010, 12:17 PM
danielph is offline
Find More Posts by danielph
TEAM EXTREME!
danielph's Avatar
High Prairie, WA
Joined Nov 2007
Nice work Doc!
danielph is offline Find More Posts by danielph
Old Dec 22, 2010, 12:56 PM
thomer is offline
Find More Posts by thomer
Off roading with the Fun Cub!
thomer's Avatar
CA
Joined Mar 2003
My EXP tracks so solid and true like on rails, but when I try 3D flying/harrier, I get a decent amount of wing rock. I've tried moving the battery to different locations, but not having much success. Setup is Torque 2814/820 motor, 12x6 prop, 4s 2200 packs, Hitec HS-65mgs all around and fly with the SFG's. Any suggestions? Is the EXP fairly CG senstive?
thomer is offline Find More Posts by thomer
Old Dec 22, 2010, 01:04 PM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
How is your elevator throw? Perhaps too much?
MikeRx is offline Find More Posts by MikeRx
Old Dec 22, 2010, 01:09 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
It's not really rock. It's just that with a full 88 degrees of elevator movement harrier can be a little tricky. With that much throw it is easy to rotate the plane so hard that you dump whatever partial lift you are getting off the airframe. In harrier you are right on the ragged edge of a complete stall, and having the elevator authority to rotate past the critical angle of attack can put you over the edge.
Once I figured this out I started concentrating on using less elevator in harrier and that helped. We have never had this kind of elevator movement to play with before, so it's a bit of a learning process.
Lately I've been setting my low rate for 100% rudder and ailerons, and dropping the elevator to 50 degrees. Basically, all I have is a high/low for the elevator only. Low is my harrier and general flying around rate, and I use the high rate for tumbles, walls, parachites, etc. This works well, but I'de rather fly on just one rate, so I have just learned to fly the plane on high rate and work on getting my harrier better.
thomer is offline
thomer's Avatar
CA
Joined Mar 2003
I did not think about that, I do think I have quite a bit. I will give that a shot. Thanks.
Thanks to you too, Doc, makes sense. It's easy to think, "hey, I've got all this throw, let's crank it up!" and not considering any adverse affects it may have. I'm going to try turning it down some and see what happens.
Now that I am working with 2 variables, (battery placement and elevator throw) is battery against the wing spar a good place to start? I don't remember where the CG location is, but I usually assume balance on the spar.
Old Dec 22, 2010, 02:01 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
cool thread. trying to avoid the small stuff...really want to try one of the 70" exp birds...one of these days
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 22, 2010, 03:04 PM
EXTREME FLIGHT CEO
Joined Feb 2004
thomer, Doc is spot on. The 80 degree elevator throw is great for tumbles, flips, waterfalls, etc. but can make harriering the plane a bit more difficult, especially if you are just learning the maneuver. I would suggest setting up a 45 degree rate to practice harriering the EXP. It is without a doubt one of the easiest planes to harrier ever. Shoot for a hands-off inverted (neutral) CG.
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 12469 May 23, 2016 03:42 PM
Sold Extreme Flight Extra EXP 48 RTF HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2010 09:47 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Sold Extreme Flight EXP Extra 48inch (Red n Black) HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2010 01:43 AM
Sold Extreme Flight Edge 540 EXP Rc_heli_flier Aircraft - Electric - Airplanes (FS/W) 4 Sep 01, 2010 11:51 AM
