Old Feb 10, 2013, 08:31 PM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
Originally Posted by Buzzed View Post
I had the distinct pleasure of flying my buddies new Edge this evening. He has a DLE-55 in it with Hitec 7955 servos. All I can say is WOW!
Ground forbid anything happens to my 88 extra that would be my next 50cc. Great looking.. Love the scheme Oh I forget..I am a sucker for RWB...
livinma1 is offline Find More Posts by livinma1
Old Feb 10, 2013, 08:33 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Looks cool. Do you know if they were the 7955 HV? Did he have to do anything to get them to work right? Thanks Buzzed.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Feb 10, 2013, 08:36 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Me too! My fav colors.
Buzzed is offline Find More Posts by Buzzed
Old Feb 10, 2013, 08:37 PM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Yep, HV. Sounds like it went together really ez and fast. I don't think he mentioned anything about the servo setup.
I will ask him though.
Old Feb 10, 2013, 08:38 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Originally Posted by Dead View Post
Honer,
What do you have in that 78" build if you don't mind me asking? I am still toying with the idea myself....
I have the EME35, 5 x HS-7955s, 1 x HS-5496 for throttle, Fromeco Wolverine switch, 2 x 2s 1300 lipos, optima 9, and a 16 oz fourtitude tank.
I forgot to post the video earlier
EF 78 extra with eme35 (8 min 14 sec)
hone1er is offline Find More Posts by hone1er
Old Feb 10, 2013, 08:56 PM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
He said he just centered them and slapped the servo arms on them. They work great!
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
I need one of those
Nice pics!
Old Feb 10, 2013, 09:35 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Nice pictures buzzed and nice flying hone1er... Are you running HV to the 7955s?
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Feb 10, 2013, 09:39 PM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
Yup, direct off 2s. I get 4 flights before i have to change my packs. I have 2 sets and charge one set while i fly the other.
Old Feb 10, 2013, 09:53 PM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Yep!
Old Feb 11, 2013, 11:20 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I have had a blind nut fall out of my wingtip on my 70" Extra's SFG.
Is there a quick fix for this, or is opening up the wing necessary? I have been flying without SFGs but I would like to tackle this before SEFF rolls around...
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Feb 11, 2013, 11:26 AM
Aeroplayin is offline
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Quick fix.... and they worked great. They were actually recommended by Chris a while back. Just make sure you get them in far enough so they are even with the wing tip edge surface. Not sure of the 70 size but these were for the 78.
http://shop.dubro.com/p/8-32-threade...ts?pp=12&pp=12
Aeroplayin is offline Find More Posts by Aeroplayin
Old Feb 11, 2013, 11:28 AM
MLT67 is offline
Find More Posts by MLT67
Joined Nov 2005
Actually removing the covering from the wing tip and cutting just enough balsa on the wing tip to re install the blind nut is the quickest and easiest repari.
MLT
MLT67 is offline Find More Posts by MLT67
Old Feb 11, 2013, 11:57 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Hate to get political, but the SSI tax *rate* just went from 4.2 to 6.2%. This means that the amount you'll pay on your check will be up 47.6% over last year.
Anyway, not sure how this will pan out for the hobby.
I was reading about the history of model aviation and was surprised by the number of people involved during the great depression.
But, for a lot of people, their take home income just went down $50-$250/month, depending on how much they earn.
I think it is going to have an impact. That could be a new airframe per month for a lot of people.
Old Feb 11, 2013, 12:48 PM
_OZ_ is online now
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
You can fix this a couple of ways without cutting any covering.
1. Drop a line down through the hole, down the wing and out the other side. Put the blind nut on and then tie on an object behind it like a nut or small rod. Pull line back up through the wing with the new blind nut. When you get it close to the wing tip, center it on the hole and then pull the line tight to seat the blind nut. Cut the line and then thread a screw and washer and tighten it to ensure the new blind nut is seated. Now you are ready to put your SFGs back on.
2. Use same procedure above but use a rod with a L bend instead of a line
_OZ_ is online now Find More Posts by _OZ_
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 12547 Yesterday 09:54 PM
Sold Extreme Flight Extra EXP 48 RTF HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2010 09:47 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Sold Extreme Flight EXP Extra 48inch (Red n Black) HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2010 01:43 AM
Sold Extreme Flight Edge 540 EXP Rc_heli_flier Aircraft - Electric - Airplanes (FS/W) 4 Sep 01, 2010 11:51 AM
