Old Jan 21, 2013, 06:40 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Just about everything is in Scott Stoops' book. Finding a copy is the problem.
Doc Austin is online now Find More Posts by Doc Austin
Old Jan 21, 2013, 06:50 PM
GetSome! is offline
Find More Posts by GetSome!
GetSome!'s Avatar
United States, CA, Roseville
Joined Jan 2011
Originally Posted by LoneWolfRC View Post
NJswede, why don't you just buy an ad here?
Ignore list......bye!
GetSome! is offline Find More Posts by GetSome!
Old Jan 21, 2013, 07:04 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Oh, and I believe on spoilerons and flaperons that Scott recommends a 50% mix to start with.
The link to this video is safe, but there's a lot of other stuff on this site you might not want to see. The video, though, is fairly awesome..........
http://www.liveleak.com/view?i=004_1358809777
Old Jan 21, 2013, 07:27 PM
TheMagician007 is offline
Find More Posts by TheMagician007
TheMagician007's Avatar
United States, CA, Carlsbad
Joined Apr 2012
Originally Posted by Tom K. View Post
I don't know if there is a list anywhere, but here are some you can check against your list
--Tom K.
Thanks a ton! Probably would have helped if I posted mine, but just looking at this there are a lot I don't have. I'll cross reference with mine and then post back.mthx again.
Doc - thank you as we'll. always appreciated!!
TheMagician007 is offline Find More Posts by TheMagician007
Old Jan 21, 2013, 07:32 PM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
-the other kind of knife edge wall (they're two completely different maneuvers, but I've heard them both called a knife edge wall)
-cascade
--Tom K.
Nice list. Can you describe these three here? I know the one KE Wall is when you perform a normal wall but add aileron and rudder in the middle of the maneuver in order to roll the plane 90 degrees to the original plane they were in. But I don't know the OTHER KE Wall.
Cascade?
Also, don't forget the ubiquitous waterfall or the Aneurism!
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
thebuckeye is offline
Find More Posts by thebuckeye
thebuckeye's Avatar
United States, IL, Forest Park
Joined Jul 2011
Is there any place that still sells them?
thebuckeye is offline Find More Posts by thebuckeye
Old Jan 21, 2013, 07:49 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
You can contact him directly, he might still have some old copies that are damaged but still very readable.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jan 21, 2013, 07:54 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Originally Posted by MLT67 View Post
Once you get it dialed in - if you dont mind please share the settings of your mix. It is an impressive maneuver.
Well, I'm stumped. I have an elevator to spoileron and elevator to flaperon mix (ele->ail at +100, and -100). Works good for walls in real life and sim, and works well for tight KE spins in the sim only. But I couldn't get what you guys described. I'll have to play around with it some more based on some of the other ideas that were shared, but hopefully somebody who has actually done it will tell us.
Old Jan 21, 2013, 07:55 PM
Joined Apr 2012
Amazon has them.mranging from 65 to 130...wow!
Old Jan 21, 2013, 08:03 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Cascade?
You have the one knife edge wall.
The other knife edge wall is a knife edge, then full up or down elevator to turn 180 degrees abruptly still on knife edge and continue in the other direction.
Cascade: Straight and level at high altitude. Do a rolling half loop like a split S and return to level flight as soon as you get to the bottom heading in the other direction.
I like the cascade because it's really abrupt, gut wrenching as you're rolling at the ground, and stops on a dime heading the other way... I gotta work on that one.
I FORGOT THE WATERFALL! GRRR!!!
Aneurism? Ooo, do tell
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Jan 21, 2013, 08:05 PM
NJSwede is offline
Find More Posts by NJSwede
3D Wannabe
NJSwede's Avatar
United States, NJ, Mendham Township
Joined Jul 2011
I don't know if there is a list anywhere, but here are some you can check against your list.
-Aussie Toilet Bowl (Doc taught me that one)
Never heard of that one. Enlighten me!
NJSwede is offline Find More Posts by NJSwede
Old Jan 21, 2013, 08:10 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Full throttle across the field, then slam both sticks in the bottom right corner. It'll do this sick end over end tumble.
There's a quick one at the 30 second mark and a lower one at the 1:11 mark:
Tom Kitt - Extreme Flight Edge 540T EXP 48" (3 min 50 sec)
--Tom K.
Old Jan 21, 2013, 08:21 PM
They Call him Dead!
Joined Jul 2003
http://www.youtube.com/watch?v=HolRNJCMwlM
--Tom K.
Like a hard core snap that you just hold the inputs?
The Aneurism is something Chris H was explaining to me. Straight and level and you perform blender inputs, but you don't leave the sticks in the corners. I think you add the aileron input and instantly pull them back to neutral or slightly opposite. You hold the elevator down and I THINK you relax the rudder and then pulse the throttle. It causes a violent tumble when do correctly (I have not yet).
Old Jan 21, 2013, 08:26 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Yeah pretty much. Which way do our toilets flush? Do it the other way and it's an Aussie toilet bowl ... well, that's how Doc explained it to me
Ooooo, that sounds cool. I'll have to experiment next time out.
--Tom K.
Old Jan 21, 2013, 08:32 PM
NJSwede is offline
3D Wannabe
NJSwede's Avatar
Joined Jul 2011
--Tom K.
Oh, then I've made many of those. I call them "trying to break my plane" or "pissing off the old guys in the peanut gallery".
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 12433 Today 03:37 PM
Sold Extreme Flight Extra EXP 48 RTF HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2010 09:47 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Sold Extreme Flight EXP Extra 48inch (Red n Black) HKC3 Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2010 01:43 AM
Sold Extreme Flight Edge 540 EXP Rc_heli_flier Aircraft - Electric - Airplanes (FS/W) 4 Sep 01, 2010 11:51 AM
