Old Dec 21, 2010, 12:26 PM
I'm FAMOUS
Joined Mar 2010
Do not Google me...stay here, read on.
The Double Horse 9100 arrived from China in just under 2 weeks, in a fairly sturdy box.
killbucket is offline Find More Posts by killbucket
Old Dec 21, 2010, 12:27 PM
Kurt's Avatar
Beer City
Joined Sep 2003
why doesn't somebody just call XHeli and ask?
Kurt is offline Find More Posts by Kurt
Old Dec 21, 2010, 12:31 PM
edwong3's Avatar
Central Florida, USA
Joined Sep 2010
I find it funny that we're spending so much time discussing a single rotor in a co-ax forum when we should be talking about this bad boy. But what the heck!
Ed
edwong3 is offline Find More Posts by edwong3
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
What fun would that be? Isn't that sort of like "Real men don't ask directions?"
Balr14 is offline Find More Posts by Balr14
Latest blog entry: Some stuff
Old Dec 21, 2010, 12:33 PM
I'm FAMOUS
Joined Mar 2010
Because you would be on HOLD forever, for something that is pretty EASY to deduce, and move on.
The Double Horse 9100 inner packaging (the display box) was crumpled on one corner, but luckily, nothing had been damaged inside, outside of a foam packing block.
Last edited by killbucket; Jan 30, 2011 at 05:39 PM. Reason: People will be telling you about That Killbucket Guy, for years to come, get used to it.
Old Dec 21, 2010, 12:34 PM
I'm FAMOUS
Joined Mar 2010
Ed
Because it's control scheme is likely identical to our coax 3-channels, making a relevant link in interest.
The Double Horse 9100 is larger than a Syma S006g or a similar-sized CostcoCopter. The thing DWARFS an S107, and my toy car is just here because it was the right colors.
Last edited by killbucket; Jan 30, 2011 at 05:40 PM. Reason: People will be telling you about That Killbucket Guy, for years to come, get used to it.
Old Dec 21, 2010, 12:37 PM
edwong3's Avatar
Joined Sep 2010
That servo is mounted quite offset on the right side of the heli so that output shaft must be pretty long in order to actuate the horn on the other side of the frame.
I don't know, it looks weird.
Ed
Edit: Oh never mind KB. I see what you're saying. The horn, and rod are actually within the frame. We're just seeing it through an opening in the frame.
Originally Posted by killbucket View Post
The white arm you see here...
is mounted to this servo, under the word hover.
It think you "see" the servo ARM outside the sideplate...it is between them.
Old Dec 21, 2010, 12:59 PM
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
It's obviously got fake front ball-links, folks.
It's a HobbleCopter.
The "NEWS" here, is it's a "Hobby Grade" airframe from a cheapie maker, apparently.
I wonder if it has front servo locations.
Who's the first to order one up to see what this thing really is ?!?
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Dec 21, 2010, 01:11 PM
Heli Mania
PNW
Joined Dec 2010
Originally Posted by jtravel View Post
This is what I see in the photos.
The swash has two linkages one connected to a servo and one fixed mounted.
The swash also has a center Anti-rotation pin.
Two buckles are also connected from the swash to the rotor blades.
These are the specs off XHeli:
Feature:
-Alloy structure, unique design
-Electronic fine-tuning, flying more stable
-All-round 3 channel control
-Advanced intelligent balance system
-New digital full 3 Channel control remotely
-Full function: up/down, forward/backward, turning left and right, fixed-point hovering
Based on the description of the movements in the specs, it sounds like a 3-channel. A 4-channel would have an added direction of "move left or right". So maybe the main blades actually do just tilt for and aft, and the tail rotor gives the yaw.
Maybe the "extra linkages" are just for added stabilization of the mechanism and don't really move anything around.
The mystery continues ....
Old Dec 21, 2010, 01:24 PM
edwong3's Avatar
Joined Sep 2010
Oh cool! We now have a new RC helicopter term, '3 Channel FP"!
Ed
Old Dec 21, 2010, 01:43 PM
Chicago 'burbs
I noticed the printing on the box...
"High degree of carbon fiber pattern simulation aluminum"
Does that translate to a printed sticker on aluminum?
richh is offline Find More Posts by richh
Old Dec 21, 2010, 01:58 PM
overedline's Avatar
Chino Hills, CA
Joined Dec 2006
If its not a coax (and it obviously isn't) then the tail rotor has to be cancelling the torque from the main rotor, but won't that make it the world's most unstable 3-channel? I mean I always thought that 3-channels were coaxes because without the dual rotors the heli would need the 4th channel to be able to control its stability.
overedline is offline Find More Posts by overedline
Old Dec 21, 2010, 02:23 PM
edwong3's Avatar
Joined Sep 2010
It is "self stabilizing", meaning it has a gyro to manage the differences between the torque from the main rotor, and the thrust from the tail rotor. Makes it almost if not as stable as a coax.
Ed
Old Dec 21, 2010, 02:30 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Ed
That isn't what self-stabilizing means at all. All single rotor helis have a gyro to hold the tail and 95% of them are not self-stabilizing. But, your confusion is justified, because it's a misused term. In simple terms, it means the heli will attempt to cancel movement, much like a coax does. It has also been used to describe helis that attempt to remain upright (due to long center of gravity), also much like a coax. There are several helis that do both. There are lots of people who won't buy a self-stabilizing heli because they assume that if it has a 45° offset flybar or head, that it will try to remain upright, which is a physical impossibility.
Old Dec 21, 2010, 02:38 PM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
A geared tail doesn't seem to me like a very efficient method, and also noisy. But we'll see when it gets there. Still think it's a little premature to call this a FAKE 4 channel. I think it was just listed wrong on that webpage. Happens more often, some advertise the Revell Proto Max as Bell Hiller and Heading Hold gyro, while it's head design is Bell, and it has a rate gyro. Can't blame the company that makes this heli for that, and this seems like a similar case...
SoloProFan is offline Find More Posts by SoloProFan
Discussion Fast Lane Proton 3 Channel Co-Ax From Toys R Us edwong3 Coaxial Helicopters 13 Nov 15, 2010 05:57 PM
Discussion How to seperate channel 6 from channel 1 in Futaba T6EXHP..?? joy4u Radios 5 Oct 14, 2010 11:31 PM
Discussion transition from three to four channel love2fish93 Electric Plane Talk 21 Sep 28, 2008 07:34 PM
Wanted WANTED: 3 channel{or four} aircraft with ailerons- Will trade plus money Lizard Boy Aircraft - Electric - Jets (FS/W) 0 Oct 02, 2007 08:29 PM
