Old Dec 21, 2010, 12:09 PM
Z24 is offline
Z24
Find More Posts by Z24
Z24
Tamiya For A Me A
Z24's Avatar
Canada, ON, Strathroy
Joined Feb 2010
Looking at the radio, it looks to me to be in 4ch orientation.
Z24 is offline Find More Posts by Z24
Old Dec 21, 2010, 12:10 PM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
Originally Posted by Balr14 View Post
If it doesn't have a servo attached to the front link, how do you suppose it moves forward and back?
Sometimes the obvious gets overlooked in the excitement of the moment.
mono is offline Find More Posts by mono
Old Dec 21, 2010, 12:11 PM
Z24 is offline
Z24
Z24
Tamiya For A Me A
Z24's Avatar
Joined Feb 2010
lol, jinx!
killbucket is offline
Find More Posts by killbucket
I'm FAMOUS
Joined Mar 2010
You've never seen a fake trim button?
What's neat about this, is I bet the controls are the SAME as our S107's
EDIT:
The Double Horse 9100 has a BIG drive gear, more like a "real" helicopter.
It nearly is one.
killbucket is offline Find More Posts by killbucket
Last edited by killbucket; Jan 30, 2011 at 05:37 PM. Reason: People will be telling you about That Killbucket Guy, for years to come, get used to it.
Old Dec 21, 2010, 12:12 PM
jtravel is offline
Find More Posts by jtravel
Rather Be flying or Tinkering
jtravel's Avatar
Arizona
Joined Aug 2010
Originally Posted by killbucket View Post
There IS one servo in the back, it raises/lowers the back of the swash only, giving it fore/aft.
If you look close at all the pics, you see a dummy ball-link on each side of the front of the swash.
using the swash design on a three channel would still require The swash to have two linkages for stability of the swash plate.
The front swash linkage is just fixed mounted instead of being connected to a adjustable servo motor.
jtravel is offline Find More Posts by jtravel
Old Dec 21, 2010, 12:13 PM
I'm FAMOUS
Joined Mar 2010
It has one servo in the BACK to tilt the swash fore/aft.
EDIT:
The Double Horse 9100 rear servo can be replaced, because it has it's own connector, rather than being soldered. It is likely an off the shelf part, in no way special to this model.
edwong3 is offline
Find More Posts by edwong3
edwong3's Avatar
Central Florida, USA
Joined Sep 2010
That's a possibility. Maybe the other links are cosmetic only. My Millennium NTU is a single rotor 2 channel that uses a vertical tail rotor for rudder, and flies forward by default, but apparently the Double Horse 9100 adds the 3rd channel to regulate fore, and aft pitch. Actually, that's pretty unique in a 3 channel.
I wonder how it would handle a slight breeze compared to a similar sized co-ax?
Ed
edwong3 is offline Find More Posts by edwong3
Old Dec 21, 2010, 12:14 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
You can see clearly the roll control servo on the right side of the model, it is mounted base facing out, You can see where the link goes up from the servo arm which is in the inside of the frame and attaches to the swash arm.
Doubletap is offline Find More Posts by Doubletap
Old Dec 21, 2010, 12:15 PM
I'm FAMOUS
Joined Mar 2010
The two dummy links would be fixed rigidly, so THEY are the pivot point on the swash. This would actually give it some range in the blade pitch as well.
EDIT:
CORRECTION: The Double Horse 9100 does NOT change pitch, it can't because the two blade grips are rigid to one another.
However, the phasing between the swash and the rotor disk DOES change, as the swash is pushed closer to the rotor disk, the link arms must lean forward as you see here. This dampens response even more, further taming what should be a CopterGeist.
It nearly is.
Old Dec 21, 2010, 12:16 PM
I'm FAMOUS
Joined Mar 2010
Have I implored anybody to visit my big copter site today? No?
Good, I don't want to mistakenly do so.
Stay away from my site, it's MINE!!!! :0
The Double Horse 9100 head assembly. Notice how teeny-tiny that swashplate diameter is- this made it very low-cost, as a smaller bearing was used.
Last edited by killbucket; Jan 30, 2011 at 05:38 PM. Reason: People will be telling you about That Killbucket Guy, for years to come, get used to it.
Old Dec 21, 2010, 12:19 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Well it certainly would be an elaborate ruse, making a 3 channel look like a 4 channel. Why don't you order one and see?
Balr14 is offline Find More Posts by Balr14
Old Dec 21, 2010, 12:21 PM
edwong3 is offline
edwong3's Avatar
Joined Sep 2010
Well someone needs to "pull the trigger", and get one. That way, we'll all know for sure whether this is a 3 or 4 channel. Who wants to be first?
Ed
Old Dec 21, 2010, 12:22 PM
I'm FAMOUS
Joined Mar 2010
As soon as I find one not at Xheli, that will probably happen.
I may order one up from Ali Blah-blah,
Or see if one of my distributor buddies will GIVE me a sample...
EDIT:
The Double Horse 9100 turned out to be not so bad a copter, generally speaking.
Old Dec 21, 2010, 12:23 PM
Doubletap's Avatar
Joined Jul 2005
THAT attaches to the centered, (pitch, not roll) back ball on the swash, look again.
No, on the RIGHT side, not the left side which you showed that has the pitch control servo.
jtravel is offline
jtravel's Avatar
Arizona
Joined Aug 2010
This is what I see in the photos.
The swash has two linkages one connected to a servo and one fixed mounted.
The swash also has a center Anti-rotation pin.
Two buckles are also connected from the swash to the rotor blades.
Discussion Fast Lane Proton 3 Channel Co-Ax From Toys R Us edwong3 Coaxial Helicopters 13 Nov 15, 2010 05:57 PM
Discussion How to seperate channel 6 from channel 1 in Futaba T6EXHP..?? joy4u Radios 5 Oct 14, 2010 11:31 PM
Discussion transition from three to four channel love2fish93 Electric Plane Talk 21 Sep 28, 2008 07:34 PM
Wanted WANTED: 3 channel{or four} aircraft with ailerons- Will trade plus money Lizard Boy Aircraft - Electric - Jets (FS/W) 0 Oct 02, 2007 08:29 PM
