Old Dec 21, 2010, 04:31 AM
specnaz is offline
Find More Posts by specnaz
Vozdushno Desantnie Voiska
specnaz's Avatar
Croatia
Joined Jun 2010
Help!
F-14 folding wing DECAL HELP NEEDED
Hi guys, I'll be honest with you straight away, I never stick any decal on foamy , indeed , I have no idea what kind of decals are these, water ones, or they require glue or what, I need the "how to" to stick them on my F-14 parts , and I have no idea what is the yellow sheet for , one side has a bit oily feeling on touch, other don't . please help!
specnaz is offline Find More Posts by specnaz
Old Dec 21, 2010, 05:04 AM
benjo is offline
Find More Posts by benjo
Pointy end at the front.
benjo's Avatar
Joined Aug 2009
They are waterslide decals, put them in water until they can move around on the backing, then slide them into position, i recommend cutting as close to the decal as possible to get the least ammount of shiny area around the marking, and also wet the area that the decal will be placed or the decal will stay where you slid it onto. Wetting the surface first allows you to move the decal around before its fixed in place.
benjo is offline Find More Posts by benjo
Old Dec 21, 2010, 05:07 AM
specnaz is offline
specnaz's Avatar
Croatia
Joined Jun 2010
Thank you Benjo! I'll try it now. And the yellow paper, is there any use of it?
Old Dec 23, 2010, 04:32 AM
benjo is offline
benjo's Avatar
Joined Aug 2009
Im pretty sure i dont remember any yellow paper, but i'm sure its just to protect the decal markings and film before they are used.
Discussion HK Superdeal: F-14 Folding Wing Jet w/ Twin 60mm EDF Kit CrashingDutchman Foamy EDFs 8 Feb 08, 2011 06:44 PM
Discussion F-14 folding wing DECAL HELP NEEDED specnaz Foamies (Kits) 1 Dec 21, 2010 04:27 AM
Discussion Help needed for motor size..flying wing Swaneyjoe Flying Wings 3 Dec 14, 2010 12:42 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 12:13 AM
Help needed: Hacker 50L 16 Turns.DS-51 3ph,Best controllers,cells for my F-14? bipeflyer Electric Ducted Fan Jet Talk 33 May 22, 2002 01:36 PM
