This thread is privately moderated by k.rags, who may elect to delete unwanted replies.
Old Dec 20, 2010, 10:20 AM
k.rags is offline
Find More Posts by k.rags
k.rags's Avatar
Tigard, Oregon
Joined Dec 2006
glass sphere to resin ratio
Wing bagging notes
Don't use the carbon pieces containing the edge tape
Cut mylars so ends curl down when laying up
Use more accurate scale to measure epoxy
get cutting mat (about 2' x 6' or 3' by 6' marmolium).
Create a clean area for storing cut pieces of fabric
Make sure alcohol and paper towels are available before bagging and using epoxy
Larger mixing cups would be good
Make sure core beds align and the chord thicknesses match up perfectly
http://hfmarine.dk/files/datablade/w...onsanduses.pdf
Length of pushrods from Kennedy composites.
40 " for Blaster
54" AVA
all have bondable sheaths
Barry
Steps to bagging with kevlar
Make paper pattern
Cut wax paper with pattern
Lite spray wax paper
Place wax paper on Kevlar
Cut Kevlar
Epoxy mylars
Place Kevlar with wax paper onto mylar
Finish wetting out Kevlar
Put toilet paper onto Kevlar
Place one Kevlar onto the other (toilet paper touching)
Place into vacuum bag
Draw vacuum for a few minutes
Remove from bag
Take off toilet paper
Put Kevlar onto cores
Bag
k.rags is offline Find More Posts by k.rags
Discussion Resin/Fiber Ratio Math wyowindworks Composites Fabrication 22 Dec 14, 2010 03:01 PM
Depron + (Resin + Glass fiber) = ? hate Foamies (Kits) 1 Jul 03, 2005 11:37 PM
Polyester resin : Mek ratio ?? JerryHall Composites Fabrication 10 Dec 23, 2004 03:35 PM
Help to locate Epoxy resin & Glass The Baron Scale Kit/Scratch Built 1 Dec 18, 2002 09:42 PM
