| Thread Tools |
| This thread is privately moderated by warbirdguyn951, who may elect to delete unwanted replies. |
Huge gagare sale
Hey guys
I’m cleaning out my shop and selling parts, accessories, PNP, RTF EPO jets and planes that are collecting dust, I have full list of parts for helicopters, planes, jets, cars, monster trucks, servos so check the list, I’m making deals!! (Everything is plus shipping) IF YOU LIKE TO SEE MORE PICTURES OF ANYTHING FOR SALE PLEASE EMAIL ascforithobbies@hotmail.com CAR PARTS 1. Novak 27maz ch 1-6 switch module NIB $10.00 2. Novak Super sport brushless programmable ESC 2 available NIB $45.00 each 3. Duratrax 8T brushed ESC w/reverse NIB $20.00 Gas Motors and assessory 4. Megeatech MTC605 Tmaxx .16 nitro engine NIB $40.00 5. 3W 150cc twin Gas engine with Mufflers, Custom made air cleaner & cooling shrouds Used $850.00 6. HP Gold cup .120 twin inline NIB mint $400.00 7. O.S. 91 Four stroke Surpass out of box but never ran. $205.00 8. Venom Smart Temp digital read out 2 available NIB $20.00 each 9. Exceed replacement pull start 51C00-05022 $12.00 Electric Motors and accessory 10. Colbalt 2 modified 9 x2 Round wire brushed motor rpm32.016 147w NIB $20.00 11. Kavan 2 pitch hub for electric flight fits 4 & 5mm shafts NIB $20.00 12. Matched set Exceed 4000KV EDF out runner brushless motors NIB $33.00 14. Extreme power analyzer PA-10 NIB $35.00 15. SHS Brushless Heat sinks for 28MM case NIB 2 available $ 5.00 16. Turnigy 6V voltage regulator NIB $ 15.00 17. E-max 35Amp brushless aircraft ESC NIB 1 available $ 25.00 each 18. 1.97 EDF housing 2 available NIB $8.00 each 19. E-max 40 amp brushless ESC for aircraft NIB $25.00 20. NEO one Brushless 3 star 6.5 monster truck motor NIB $65.00 21. Hoffman Rocket brushless airplane out runner motor NIB $40.00 24. Reedy 10T modified brushed motor Double winds touring car NIB $19.00 Dremel accessory 25. 1 inch diameter carbon cut off wheels 100 count each package NIB 5 pack available $8.00 each 26. 3/4 diameter abrasive cut off wheels 100 count per package NIB 20 packs available $5.00 each 27. ½ diameter sanding drum 100 piece pack w/mandrels , 6 available $8.00 each Airplane parts 29. FMS P51 replacement 4 blade propeller $25.00 31. FMS 9 gram replacement servo 93A51-11 $10.00 32. FMS 19 gram replacement servo reverse 93A51-10 2 available $15.00 33. FMS 19 gram replacement servo 93A40-11 $15.00 34. Byron G17 Stagger wing Cowl used with scale features $60.00 37. 3 lbs rare earth magnet 3 in the package for holding down hatches, 30 available NIB $2.00 each package 38. 5 lbs rare earth magnet 3 in the package for holding down hatches, 30 available NIB $2.00 each package 39. Corona RP8DI Scan select receiver 72Mhz NIB $22.00 40. ¼ scale full pilot figures weighs less than a oz. 2 available $50.00 [B]Batteries[/B 44. Multiplex 3/2-3000P-M611.1V/3,000mAh #M15 7015 Lipo 6 available $25.00 each Helicopter parts. Pitch gauge for Helicopter 2 available NIB $ 5.00 each Align Trex 450 HS1008T-1 swash plate 2 available NIB $20.00 each HS1176T tail Holder set NIB $13.00 E-Flight 2XEFLHH1468 Tail pitch slider set NIB $7.00 E-SKY Belt CP V2 parts EK1-0502 Tail blade Yellow 2 pack available NIB$5.00 each EK1-0501 Tail Blade white NIB $5.00 EK1-0504 Foam blade holder 2 pack NIB $5.00 EK1-0402 Main blade clamp set 3 available NIB $6.00 EK1-0404 Feathering spindle shaft set NIB $6.00 EK1-0411 short push rod head set NIB $2.00 EK1-0534 Main Gear set NIB $8.00 EK1-0413 Ring-link push rod NIB $3.25 EK1-0529 tail blade control set NIB $6.00 EK1-0538 main shaft 2 per package NIB $6.50 EK1-0422 Flybar NIB $3.50 EK1-0006 3800KV brushless out runner motor NIB $20.00 Jets PNP Spear 70MM EDF delta Jet with Navigation and After burner lights, 60amp Esc ,1800KV out runner motor, 9 Gram servo the plane is built and need your TX RX battery to fly $155.00 RTF Star Max F35 EPO 4 channel complete with battery charger radio this is NIB $ 160.00 RTF Exceed Tornado with battery radio charger, tiger color marking, mechanical sweep wings NIB$159.00 Airplanes Great Planes P-6 Hawk ARF NIB $480.00 Byron F6F Hellcat kit Robart retract including tail wheel, Byron Power purr for G62, Byron Sliding canopy & cockpit kit, Byron wheels & Brakes all NIB $3,500.00 HELICOPTERS E-SKY Belt CP V2 RTF with Lightning CNC Aluminum 5 blade head ,CNC aluminum Tail rotor, Carbon fiber main & tail rotor blades, Heli artist Hughes 500 fiberglass fuselage w/ Nav blinking lights, 11.1V lipo. $550.00 PNP EXI carbon fiber 450, all metal CNC head and tail, metal gear 9 Gram servo’s, E-sky hold heading lock Gyro,2800Kv brushless Outrunner motor,35amp ESC ,Custom paint H-1 Huey Gunship fiberglass fuse everything is new and assembled 0 flight time…$500.00 Boats Moebus SeaView Sub kit w/Caswell SVFC Seaview Fittings Kit, WTC with copper Gas reservoir, Less radio and battery $425.00 Revell GATO class sub NIB $100.00 Various Boat Molds email me for info, ascforithobbies@hotmail.com Shop Equipment 2-HP Industrial Dust Collector System collects dirt, dust and debris as tiny as 5 microns while you work brand new in the box. Specs: Description of Central Machinery 97869 Large-capacity dust collection system with 70 gallon, 5 micron top bag captures the finest dust for a cleaner work environment in your shop or garage. That includes sanding dust, workshop dust and dirt, sawdust. Clear bottom bag, so you’ll know when it’s full Four locking swivel casters for easy transport Lockable toggle switch 4" diameter intake and 4" diameter exhaust Includes two collection bags, casters, hex wrenches . 2 HP, 120 volt, 60 Hz, 20 amp peak, single-phase motor 3450 RPM 1550 CFM air suction capacity Overall dimensions: 33" L x 22" W x 75-1/2" H Weight: 103 lbs. Shipping Weight: 103.58 lbs. NIB $ 175.00 Ridgid Dust collection accessory kit NIB $60.00
Billy
They are Hoffman Mighty mite 60MM EDF electric motors. shipping will be priority mail 5.00 I accept Pay pal ascforithobbies@hotmail.com your total will be 55.00 with the shipping |
| Thread Tools | |
| Sold Huge Lot, Must Go, Moving Sale | coupe-r | Garage Sale/Large Lot Ads | 17 | Dec 06, 2010 04:15 PM |
| Sold HUGE Texas Garage Sale, Jets, Helis, etc. | Roswalt | Garage Sale/Large Lot Ads | 15 | Dec 01, 2010 04:46 PM |
| Sold Huge lipo sale!!! $110 shipped!!! For 32 batteries!!! | Hilson87 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Sep 26, 2010 08:16 PM |
| Sold Huge lipo sale!!! | Hilson87 | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Sep 25, 2010 09:43 AM |
| Rave Huge FlyFly Sale Mix and Match 2 for $299.99 | SkylineFlyer | Foamy EDFs | 0 | Aug 31, 2010 09:20 PM |
