This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Dec 19, 2010, 01:28 PM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Build Log
F4U Corsair: My Marines Dream Corsair!
This is my version of the MARINES DREAM FG-1D Corsair.
NOTE: The revised CG on the Corsair has changed from the original setting of 125mm to 85mm - 90mm.
I borrowed an illustration from Mike/RogueTitan on another way to measure CG on the Corsair.
Sandancer is offline Find More Posts by Sandancer
Old Mar 15, 2011, 08:08 PM
Fidy$Trainer is offline
Find More Posts by Fidy$Trainer
USA, GA, Atlanta
Joined Sep 2008
Hi,
Amazing work on your warbirds. I was wondering if I could get your oppinion. I'd like to make my AirField F4U 1430mm Foam Warbird fairly fast. I noticed that you were using the 50-55 580kv on yours. And I'm also considering this. But it's BIG and heavy. Did the extra weight with the 5S and weight of the motor address the tail heavy issues? I was also considering the SK42-60 500kv motor as compared tothe SK50-55? Which motor would you recommend and what size prop? If I have to add weight I'd much rather it be in size of battery or size of motor and not in dead weight. My goals would be to fly pretty fast enough to hang with its' Nittro 60size brothers if not faster and unlimited vertical.
But I'm undecided. It sounds like you have already been though a lot of this. now that you have the SK50-55 do you like it? What size prop are you using? Knowing what you now know would you have used a diffrent size motor? I've got both 4S 30C and 5S 3200 30c batteries and an 80A ESC. I'm just not sure which motor prop combo would suit me best for speed and vertical performance. Any help would be appreciated.
Fidy$Trainer is offline Find More Posts by Fidy$Trainer
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Discussion FMS F4U Mini Corsair Tartago Electric Warbirds 361 Jan 23, 2015 02:12 PM
Discussion Cute Little Corsair <<< "Cartoon Corsair">>> Slow flying model of the F4u Corsair D DaDesign Foamies (Scratchbuilt) 37 Jan 03, 2015 01:27 PM
Wanted Parkzone T-28D or F4U Corsair, or similar PNP or BNF TL697 Aircraft - Electric - Airplanes (FS/W) 3 Sep 13, 2010 11:17 PM
Discussion Venta de 2 aviones electricos, T-28 Troyan y F4U Corsair Alfredo Rubio Mexico 3 Sep 03, 2010 10:44 PM
