This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Dec 19, 2010, 11:13 AM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Build Log
F4U Corsair: The Navigation Lights
This plane has to be identified in the dark of night so of course it get's a set of Navigation lights too.
UP-DATE 2/12/2013: I have taken a different approach to how I wanted to configure the landing lights on the Corsair!
I've removed that single light pod design from the belly, and I've installed a more conventional 2 light system on the wing's LE. I used two 1W 90LM LEDs mounted in 1/16" ply and recessed in the LE of both wings. I have the wiring channeled back in to the flap servo cavities and the routed in to the compartment in the wing where I changed out the light controller to a Lazertoyz Maxi, that way I can turn the landing lights on & off separate from the other nav lights. I then covered both light's recesses with pieces of 3M packing tape to simulate lens covers.
Finishing up the mod, I used strips I cut from the roll of white Oracal651 vinyl I have, painted them to match the MM Navy Blue/Gray that I used on the bottom of the wings, and covered all the wire channels.
The Corsair looks much better now!
~~~~Thumbnails~~~~
Sandancer is offline Find More Posts by Sandancer
Old Feb 10, 2011, 02:09 AM
rmasterd is offline
Find More Posts by rmasterd
Joined Dec 2005
How did you run the wires in the wings and fuselage? I was thinking of doing the same thing. I have an AIRFIELD Corsair (same plane) and a RC LANDER F9F Panther, with afterburner and lights.
I've been checking out your mods and was thinking of making my Corsair more F4U-4-like.
rmasterd is offline Find More Posts by rmasterd
Old Mar 08, 2014, 04:01 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
you cannot use 1W 90LM LEDs on the Lazertoyz Maxi unit,
you will never get 1W out of it, due to the serial resisitors of 90Ohm used on that unit. 1 Watt leds needs a current of max 300mAmp , one output of the unit will gave a max of 20mA.
i use also a Lazertoyz Maxi unit but i have modified it to use 1W LEDS
on my request he put a note on the MAXI webpage :
Kit works with most Leds 2.2 V to 3.2 V and will supply 20 mAmp no resistor required
jaccies is offline Find More Posts by jaccies
Question ME-109, Spitfire, F4U Corsair, F4U Corsair, or P-51D Mustang, best flyer??? zippiz GWS (Grand Wing Servo) 89 Oct 03, 2015 04:58 PM
Discussion Cute Little Corsair <<< "Cartoon Corsair">>> Slow flying model of the F4u Corsair D DaDesign Foamies (Scratchbuilt) 37 Jan 03, 2015 01:27 PM
Discussion Nano Navigation lights with LEDs beacon medeiros DIY Electronics 12 Mar 25, 2011 05:43 AM
Help! Can I turn my Navigation lights on and off with my DX6i and gear channel on RX dolbydarma Night Flying 6 Nov 17, 2010 06:49 PM
