Old Dec 19, 2010, 04:12 AM
PLD is offline
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Dual input/output 5A electronic switchjack failsafe system
With modern receivers being more sensitive to power disturbances, coupled with digital servos imparting more demand onto batteries, it's now becoming essential to run power systems that are more than just a single set of 4 or 5 Ni cells.
Many people are now switching over to directly running with LiFe or A123 packs and we're providing the ESJ-5ADV as the ideal companion to keeping your gear running.
The ESJ-5ADV accepts dual battery pack inputs (they can even be difference chemistries and sizes, provides remote switching ability with even tiny switches and provides dual power outputs in the event that one of the cables fail to the receiver. Additionally, the ESJ-5ADV provides a voltage readout of the highest pack and includes strong capacitor decoupling to help smooth out those spikes and dips.
At 1.1x1.0" in size, complete with mounting points, the ESJ5-ADV is a very compact unit. The voltage drop across the ESJ5-ADV will very often be less than that experienced if you used a normal mechanical on/off switch system due to the superior low resistance switching of the MOSFET used.
The ESJ5-ADV is ideal for gliders, large electrics and glow planes.
Two initial levels of build will be available;
ESJ5-AD (dual in, dual out, decoupling, power good indicators) - $23.00
ESJ5-ADV ( +voltage readout ) - $33.00
Units will commence shipping in about 2 weeks.
ESJ-5AD - http://nqrc.com/?vp=PLD-ESJ-5AD
ESJ-5ADV - http://nqrc.com/?vp=PLD-ESJ-5ADV
Paul.
PLD is offline Find More Posts by PLD
Old Dec 19, 2010, 05:24 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
A few technical points to share about the design;
1. The balancing input stage can handle 3~5A constant under normal conditions.
2. The switchjack stage will cope with with 5A and only dissipate 75mW of heat and drop 15mV of voltage.
3. The LEDs will only draw 3~5mA each and will only be active when the switch is activated.
4. The dual-output headers are bonded to the same power rails
5. The choice of the switch used to turn on/off the ESJ doesn't really matter as there's only a tiny amount of power passed through it.
6. The whole ESJ has an off-state current draw of only 1.5uA, to put that into perspective, each 1mAh capacity of the battery will last 4 weeks. The battery itself will self-discharge faster.
7. The ESJ5AD[V] will have a 470uF low ESR decoupling capacitor.
8. Total forward voltage drop will range from 0.3~0.5V (this is mostly from the drop across the schoktty balancing diodes).
9. Reverse polarity protection.
Higher average currents can be achieved by placing small heatsinks on the balancing diodes.
Paul.
Old Dec 22, 2010, 08:42 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Seems like the PCB factory has gone on holiday - as I've not heard anything back yet since the submission of the boards. Normally by now I've got a FedEx notice.
Old Dec 29, 2010, 08:28 AM
skyboyken is offline
Find More Posts by skyboyken
I do this for fun!
Sunshine Coast, Australia
Joined Sep 2004
Hi Paul,
nice one!
So if I understand it right, the unit doesn't include a switch. That is probably what the 2 wire header is for. Correct?
What state will the board be in if the switch goes open circuit when the switch is in closed circuit state? I.e. the switch fails
What will the board do if the switch contacts suffer from increasing resistance?
Do you have a switch you recommend?
Should the batteries be wired directly to the 'switchjack'?
How do you recommend charging the batteries? For the record I don't remove LiFe to charge them as they do not have an overtemp failure mode.
Please confirm the unit protects from a dead battery discharging the other (good) battery?
I'm asking these detailed questions because I'm keen on giving one a try for my lovely new slope rocket (Skorpion Needle).
TIA!
Ken.
skyboyken is offline Find More Posts by skyboyken
Old Dec 29, 2010, 08:38 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Hi there skyboyken,
Originally Posted by skyboyken View Post
Hi Paul,
That's right - the big problem is that everyone will have a different choice on what sort of switch they want and how long they want the wire.
If the switch goes open circuit, or the cable disconnects, the power is ON.
This will make it progressively slower to turn off, once the contacts exceed about 100K resistance the board will be effectively impossible to turn off.
I'd recommend any high quality action compact toggle switch. For double assurance you can put two in series, so that if one fails in a short circuit manner it won't deactivate the ESJ.
I suppose that's subjective - personally I'd consider it the most reliable option but of course you will need to ensure the packs have their own charge headers.
I recommend each pack has a separate header/port for charging.
That is correct. The system will only draw power from the highest voltage pack, as a consequence, if one pack collapses or goes internally high resistance, the other pack will supply the power but it will not be 'drawn down' by the failed pack.
Hope that gives you sufficient information
Paul.
Old Dec 29, 2010, 08:36 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Well, good news everyone.... the boards arrived about 10 minutes ago.
Now I have to actually build them!
Old Dec 29, 2010, 10:53 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Built and working
I've finished the first of the non-voltage-readout versions (ESJ-5AD).
One thing I did have to do is change to a 470uF 10V cap, which isn't a major problem. If additional decoupling is needed it will be better to be plugged directly into the RX with a VP470 or VP1000 unit.
Attached are some piccies
I've got two 2S lipos attached here but it'll work with 5 cell Ni, A123 or LiFe no problems.
Old Dec 30, 2010, 05:15 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
I should make a note - you don't have to use two input packs. There's no reason you cannot just use this as a single battery switch system.
Paul.
Old Dec 30, 2010, 09:07 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Here's another diagram showing the intended configuration
Last edited by PLD; Dec 30, 2010 at 11:42 PM. Reason: Uploaded newer picture detailing voltage drop
Old Jan 01, 2011, 02:17 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Simplified view
Attached is a simplified electrical model of the ESJ system, just to provide some clarification.
Note that the two batteries have their grounds tied together, which is okay because the two diodes in the balancing section prevent any substantial power flowing between the batteries (there is a small current flow on all back-biased diodes but it's insignificant in this situation).
Old Jan 09, 2011, 03:01 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
I've changed the pricing on the new dual-input/output ESJ units; had a miscalculation there on the parts.
ESJ-5AD is now $23 (was $29) [ http://nqrc.com/?vp=PLD-ESJ-5AD ]
ESJ-5ADV is now $33 (was $45) [ http://nqrc.com/?vp=PLD-ESJ-5ADV ]
Paul.
Old Jan 17, 2011, 03:14 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Finally got the 5ADV firmware sorted out, it was a real nightmare to work on because I threw everything possible against myself.
The chip has to be programmed at 5V but I put it into a 2.48V circuit, the programming pins don't like any sort of load on them (during programming) but I put my buzzer and LED on those two pins [ remember, there's only 3 usable pins on this thing ]. The circuit board itself has no provision for programming pads so I had to jig it all together with fine 30AWG single-strand wire and try not move it too much (else they break of course). Finally, it had to be coded in Assembly... because the chip is so tiny it cannot handle the sort of firmware that would be generated from C (yet).
Good to have it working now... my wife is duly irritated at the "Damned beeping"
New Product Modular power distribution board with failsafes and electronic switchjack PLD NQRC / PLDaniels Electronics 9 May 17, 2011 12:28 AM
New Product 3A~5A electronic switchjack with lost model alarm and low voltage alarm (4 & 5 cell) PLD Radios 0 Aug 15, 2009 11:05 PM
New Product 3A~5A electronic switchjack with lost model alarm and low voltage alarm (4 & 5 cell) PLD Slope 0 Aug 15, 2009 10:55 PM
For Sale Medusa BEC 45v input 3.5A@5V output Terkan Aircraft - General - Radio Equipment (FS/W) 1 Jun 14, 2008 02:21 PM
