Old Jan 05, 2011, 06:24 AM
disabled is offline
Find More Posts by disabled
disabled's Avatar
Vienna/Austria
Joined Jan 2009
One problem is the original inaccuracy of these old plans -
but as Im building a fantasy ship I only need to take care
for harmonic hull lines, not for preciseness of +/- 0.5 mm or so.
Cutting the stern to proper angle:
disabled is offline Find More Posts by disabled
Old Jan 05, 2011, 07:54 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Stern template cutted
First pieces of timber?
No - thats just my floor.
Foam Stern sanded straight after cutting and templates glued on -
with doublesided tape again.
As said before, Im an impatient man -
I hate to wait untill any glue has cured.
Old Jan 05, 2011, 09:19 AM
steamboatmodel is offline
Find More Posts by steamboatmodel
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
Originally Posted by JerryTodd View Post
You might want to rethink relying only on internal ballast. The real versions of these boats weren't the most stable and models of them are even less so.
http://www.youtube.com/watch?v=gUOSRL7HpAY
http://www.youtube.com/watch?v=wK1G7hnIB7A
Yes yes, these were miscalculated launches, and I posted them to poke fun, but the lower your weight, the less you will need, and being able to detach 18-25 kilograms will make handling the model a lot easier too.
I like the first one where you can see the Hardhat Diver working and the man working the air pump.
steamboatmodel is offline Find More Posts by steamboatmodel
Old Jan 05, 2011, 09:42 AM
yancovitch is offline
Find More Posts by yancovitch
Joined Oct 2006
wonder what ever happened to the nau portugal...sure looked great....
yancovitch is offline Find More Posts by yancovitch
Old Jan 05, 2011, 10:39 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Lost in a battle against Sir Francis Drake maybe?
Old Jan 14, 2011, 10:45 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Shaping Stevens
Or was it: "Well shape it Baby, twist and shout"?
Old Feb 12, 2011, 09:33 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
got a bit more sanding done
Looks more like the aftward sections of a galeon now.
Old Feb 12, 2011, 12:41 PM
Joined Oct 2006
sexy.....
Old Feb 13, 2011, 06:44 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Still not satified
Quite interesting -
I found it easier to sand this wide hull when it stands vertical like in the first pics. Its easier like this, as I can turn it around like I want to and just from the light coming in through the window it of course develops its own shadow(s) -
telling me where I have to do some more fairing.
There are still some bumps/kinks (or whatever you might call it), that need to be smoothed out. Sometimes its also good, just to sit down and look at the hull from different angles - like in the last pics.
Actually I dont like the "pinky" color of the foam at all. Cant wait to see this shape in a "good and shiplike" color!
On the other hand the slight color difference between 8cm foam and 6cm foam helps me to determine the proper cross section shapes.
"Lighter pink and darker pink" - *ARGL* - I HATE those tussicolors! -
(As disgusting as having to touch Paris Hilton !!!)
_______________________
Some facts:
This plug is 99cm high/long now, the three forward cross sections are still missing.
For now I have one section forward of the mainframe and six aftward sections glued together - 10 sections of 14 cm overall. But it could as well be that I take off the two mainsections again, to fit and shape the forward sections seperately -
and glue them onto the aftward part later on.
Thats the main advantage of using doublesided selfadhesive tape, instead of some kind of glue to fit the sections together for "eternity". And as this tape isnt hard, it doesnt disturb me during the sanding/fairing process either.
One more thing:
This whole (big) block has only 3.10 kgs for now!
Really easy to handle and turn it around to whatever position I might want/need to.
And when Im done with sanding/fairing the whole thing, I simply will glue it onto my building table (again with doublesided tape) - so it doesnt move - and laminate it completely in one step.
All five or six seamless layers of fibreglass in one workingstep.
Old Feb 13, 2011, 07:49 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Size comparison between my 1/25 and 1/20 Pirate Galeons!
And almost doubled volume -> 1.25 x 1.25 x 1.25 = 1.953125:1
Old Feb 13, 2011, 12:42 PM
Taran is offline
Find More Posts by Taran
Joined Feb 2007
never mind pink...
having two different colours certainly helps spatial perception, whereas light coloutrs show uneven surfaces better in good light (shadows!). White would glare...
So probably you couldn't have done better than pink for practical purposes.
There used to be a pink submarine in an old Hollywood movie...
so much for precedent!
Taran is offline Find More Posts by Taran
Old Mar 15, 2011, 09:39 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Update for the planning!
Youll never expect how much planningtime is necessary for such a project.
As you can see the planned new rigging is much higher and has a lot more sailarea than the original one of the "Roter Lwe" - "Red Lion".
But as Im planning to use an extended fin keel with a heavy lead bulb, this should be workable.
I just follow my own fantasy -...- whereever it may take me.
Old Mar 15, 2011, 10:28 AM
JerryTodd is offline
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
You may want to study where the center of effort of your alternate sailplan falls in relation to the center of lateral plane of your hull with the fin - you'll probably have to put the fin somewhere different that you originally planned to get things balanced again.
JerryTodd is offline Find More Posts by JerryTodd
Old Mar 15, 2011, 11:11 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
No Jerry, I dont think I will "study" that - it probably will be more of the try & error type -...- but Im still on a long way untill I`ll reach that point.
So many things to do, to decide, to sand and laminate in between, before the empty fibreglass-hull shell will hit the water for the first time.
And a lot of pics to show to make you know how Ill do it:
Old Mar 16, 2011, 03:05 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Next thing to do -
- is to cut out the three remaining cross sections (42 cm) and "add it up" to the allready exsting hull.
But in order to get the bowcurve correct/precise, this time I need to make a cardboard template first.
Pics will follow.
Discussion Syren, Brig, SC&H R/C Square Rigger, 1/24 scale DanL Scale Sailboats 377 Dec 11, 2015 10:50 PM
Discussion 16th Century Pirate Galeon - a Square rigger in 1:20 Scale disabled Sailboats 36 Mar 21, 2011 07:14 AM
Sold Model Airways 1:16th Scale Sopwith Camel F.1 ssg.perkins Aircraft - General - Miscellaneous (FS/W) 1 Dec 03, 2010 06:46 PM
Discussion traxxas new 1/16th scale rally smurfkiller Car Talk 7 Nov 03, 2010 04:54 PM
Wanted Traxxis Slash 1/10th scale or revo 1/16th or slash 1/16th Dimarazumov Cars - Cars and Parts (FS/W) 4 Nov 24, 2009 04:41 PM
