Old Dec 29, 2010, 03:31 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
Well that tonnage isn't very realistic.. maybe about 500tons is more realistic a ship of the line around 1800 was only 1650tons and the largest windjammers about 11000.
But nevertheless she will carry a lot of ballast in that beam and full hull
Looking forward to the rest of your build and your sailing reports!
meatbomber is offline Find More Posts by meatbomber
Old Dec 29, 2010, 06:14 AM
disabled is offline
Find More Posts by disabled
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Youīre probably right.
Iīll have to recheck this anyway!
__________________
Sorry - my mistake!
Donīt know what I had in mind when I wrote that.
In the book it says between 240 and 250 metric tons.
Makes more sense to me as well.
This would be between 30.0 kg and 31.25 kg overall displacement for the model at 1:20.
_________________
Anyway.
Have been lazy during christmas holydays.
But here you have the aftward sections glued onto the main cross section - to give you a first impression of the hull lines.
disabled is offline Find More Posts by disabled
Old Dec 29, 2010, 07:31 AM
JerryTodd is offline
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
Originally Posted by disabled View Post
Iīm planning 1/3 of the overall ballast for internal ballast, plus 2/3 of the weight as a lead bulb on an external keel fin.
Also a removeable rudder extension is planned for better sailing abilities.
Do you think this will be apropriate?
I think you'll be just fine.
JerryTodd is offline Find More Posts by JerryTodd
Old Dec 29, 2010, 01:44 PM
yancovitch is offline
Find More Posts by yancovitch
Joined Oct 2006
stem to stern above the waterline....60".....length to figurehead..72"....total length....93".......width....17"......only have present weight.....48lbs.......maybe 100lbs of lead needed......maybe a bit less
yancovitch is offline Find More Posts by yancovitch
Old Dec 30, 2010, 07:05 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Originally Posted by yancovitch View Post
stem to stern above the waterline....60".....152.40 cm
length to figurehead..72".... 182.88 cm
total length....93"....... 236.22 cm
width....17"...... 43.18 cm
only have present weight.....48lbs....... 21.60 kg
maybe 100lbs of lead needed...... 45.00 kg
maybe a bit less
Thank you, Sir!
______________
And hereīs mine again -
converted to your system:
stem to stern above the waterline....55.12"....140.0 cm
length to figurehead....65".... 165.0 cm
total length of hull.....70"..... 177.5 cm
width of hull....15.75"...... 40.0 cm
total length of ship.....78.75"..... 200.0 cm
Overall weight maybe only 31.25 kg,
allthough of compareable size?
This would mean less than half of your ships weight!
Strange.
One more question, if I may?
Is the total length of 93" including bow sprit or not?
Old Dec 30, 2010, 11:33 AM
Joined Oct 2006
yep...including the bowsprit......i added 100lbs when the ship was mostly a shell, and my fat ass hull is pretty wide most of it's length.......bui i may need less weight now ....will measure when put in water this spring hopefully.......gotta figure out how to move the darn thing....oh....no external keel......
Old Dec 31, 2010, 03:48 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Thank you, Sir!
One thing came to my mind when we talked about a proper trailer for your "darn thing" (how much I would love to have/own it!):
One of these fully closed horsetrailers!
(May need to find a picture for you) -
There might be someone in your area who would/could lend it out to you every now and then.
This may be the only proper option for the size of your beautiful model.
And just because of the natural size of horses - not to talk of their weigth, which is much more -
these would fit for your ship just as they are.
Just my 5 cents
Old Dec 31, 2010, 03:13 PM
Joined Oct 2006
yea....i can see myself pulling one of those with my smart car
Old Jan 01, 2011, 04:29 AM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
I think a horsefarm with such a horse trailer would also have a proper car to pull that thing.
If they would lend both out to you is just a question of asking or not. What could you loose?
Old Jan 01, 2011, 10:46 AM
Joined Oct 2006
http://www.sportutilitytrailers.com/LongChih/832T.htm
i was thinking more along this line..i could build whatever protection necessary...just furl up the sails and leave the masts exposed..who knows.......cheapest one i found......
Old Jan 01, 2011, 03:44 PM
SCALE Sailor
JerryTodd's Avatar
Joined Apr 2008
Brenderup Trailers
The smallest cheapest Brenderup started at $8,000 in 2004 (I have one) and even used they ain't cheap. I'll probably use mine to move Constellation but I have a horse, so it's actually doing double duty.
The trick with trailers is that most small utility trailers have stiff or NO springs and will bounce all over, even completely off the road - can your model take that sort of pounding?
Old Jan 01, 2011, 08:58 PM
Joined Oct 2006
scrap that then thanks for the warning! ...i never thought of that.....
Old Jan 04, 2011, 09:10 AM
Schrott is offline
Find More Posts by Schrott
Dolores, Colorado
Joined Dec 2007
the problem with horse or stock trailers, they are ment to haul an animal that weights half a ton. The bumper pull in the picture is a 2 horse which means 1 ton and the suspension is set for that weight.
Empty they bounce all over the place, loaded they run smooth.
But an idea would be those hitch cargo racks.
Schrott is offline Find More Posts by Schrott
Reply With Quote  (Disabled)
Old Jan 04, 2011, 09:52 AM
SCALE Sailor
JerryTodd's Avatar
Joined Apr 2008
I have one of those racks - You could easily put a box on it to fully enclose the model. You are limited to the width of the vehicle so it's not likely you could put the model in it fully set up.
Old Jan 04, 2011, 12:32 PM
disabled is offline
disabled's Avatar
Vienna/Austria
Joined Jan 2009
Looks like my idea is getting out of control a bit.
But at least I know by now I gave you something to think about.
These big ship models also have "some" kind of value,
so I believe itīs worth thinking about how to protect them well during transportation.
Just thinking about a treasure like the Royal William gets damaged
makes my heart hurt.
Shock absorption foams of different kinds and thickness could also be used.
_____________________________
And now back to my Pirate Galeon:
I have drawn the forward cross sections directly onto the foam
using some white cardboard - with the copied cross sections.
Starting from the main cross section -
and then simply cutting the next smaller sections -
untill I was done.
Some more pics to show the size relation between the original plan at 1:100 and my started model at 1:20. One problem is that the original plans arenīt very precise - is some areas up to one millimeter incorrect, which adds up to 5mm for my model.
Discussion Syren, Brig, SC&H R/C Square Rigger, 1/24 scale DanL Scale Sailboats 377 Dec 11, 2015 10:50 PM
Discussion 16th Century Pirate Galeon - a Square rigger in 1:20 Scale disabled Sailboats 36 Mar 21, 2011 07:14 AM
Sold Model Airways 1:16th Scale Sopwith Camel F.1 ssg.perkins Aircraft - General - Miscellaneous (FS/W) 1 Dec 03, 2010 06:46 PM
Discussion traxxas new 1/16th scale rally smurfkiller Car Talk 7 Nov 03, 2010 04:54 PM
Wanted Traxxis Slash 1/10th scale or revo 1/16th or slash 1/16th Dimarazumov Cars - Cars and Parts (FS/W) 4 Nov 24, 2009 04:41 PM
