Old Dec 17, 2010, 03:51 PM
frdeluca1 is offline
Find More Posts by frdeluca1
United States, MA, Wareham
Joined Dec 2002
Hobbywing Pentium 40A Brushless ESC with UBEC
Just received this controller from HobbyPartz. It has an encapsulated coil wound into the receiver leads. Anybody know what this is for and if it is necessary?
frdeluca1 is offline Find More Posts by frdeluca1
Old Dec 17, 2010, 04:26 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
It is a toroid coil to reduce interference... beyond that, ask someone smarter than I am!
From an RC Groups post:
It is more likely that the ESC noise is radiating from the motor wires and being picked up by your Rx antenna and/or servo wires. Toroid rings can be effective in reducing the noise conducted by the servo wires. They should be placed as close to the servo plugs (where they connect to the Rx) as practical. The energy radiated by the motor mains can be reduced substantially by simply twisting them together. This simple expedient may be enough to resolve the problem you have experienced.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 17, 2010, 04:29 PM
gofish is offline
Find More Posts by gofish
United States, CA, Rocklin
Joined Jan 2006
That would be a "ferrite ring". It suppresses high frequency noise in electronic circuits.
I'm unclear if it is needed with 2.4GHz.
Dr.Kiwi beat me to it.
gofish is offline Find More Posts by gofish
Old Dec 17, 2010, 08:29 PM
ampmaker is offline
Find More Posts by ampmaker
Sleepy Hollow, IL
Joined Dec 2008
The ferrite rings are mainly used on ESCs that have a switching supply for the BEC. The ring as others have stated is to reduce the switching noise from entering the receiver.
Since linear BECs don't have this switching noise the ferrite rings are really not needed.
ampmaker
ampmaker is offline Find More Posts by ampmaker
Old Dec 18, 2010, 05:26 PM
RobC(UK) is offline
Find More Posts by RobC(UK)
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
If you decide to leave the ferrite ring in place be sure to tie it down to the airframe!
I have seen 2 planes disconnect their Rx power due to the ring flailing about and pulling the plug out of the RX. Both times it happened during violent manoeuvres so the control surfaces stayed at near full deflection!
RobC(UK) is offline Find More Posts by RobC(UK)
Old Dec 20, 2010, 01:32 AM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
With switch mode bec's, the bec can introduce high frequency noise into an FM reciever, but 2.4ghz systems aren't affected by these high frequencies.
For 2.4ghz, you can remove the coil ( I use a pair of diagonal cutters to break the coil since they are rather brittle and soft.
for fm systems, its a must that you keep it on.
cryhavoc38 is offline Find More Posts by cryhavoc38
Sold Used 1x HobbyWing Pentium 60amp opto Esc w/ UBEC $30 shipped jmrust Aircraft - Electric - Power Systems (FS/W) 7 Dec 06, 2010 08:47 PM
Alert $19.44 only at oomodel,hobbywing pentium 40A brushless ESC oomodel.com Hot Online Deals 0 Sep 18, 2010 09:56 AM
Hobbywing pentium 40A brushless ESC ONSALE!! targethobby Aircraft - General - Miscellaneous (FS/W) 0 Apr 26, 2010 02:11 AM
Sold Hobbywing 40A Pentium ESC heychas Aircraft - Electric - Power Systems (FS/W) 1 Mar 11, 2010 01:06 PM
Sold Hobbywing Pentium 40A ESC w/ 3A BEC awayne Aircraft - Electric - Power Systems (FS/W) 4 Dec 07, 2009 05:12 PM
