Old Dec 17, 2010, 03:03 PM
Joined Aug 2010
Turnigy nano-tech 5000mah 4S 25~50C Lipo Pack
Does anyone know if these 11.1v batteries are ok for a standard hex or do they need to be 14.8v?
What would be the difference if they do work?
Regards
skyward1 is offline Find More Posts by skyward1
Old Dec 17, 2010, 03:44 PM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
Regards
Each cell is 3.7v so a 4s would be 14.8. The 11.1v is a 3s batt. You have to make sure your ESC's and motors go up to 4s if thats what you wanna use.
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Dec 17, 2010, 04:03 PM
Joined Aug 2010
I have a standard hex mikrokopter that came with a14.8v 3300 20c lipo that has been working well, so I suppose my motors & esc`s can handle it.
Here are the turnigy battery specs from HK i`m looking at:
Spec.
Capacity: 5000mAh
Voltage: 4S1P / 4 Cell / 11.1V
Discharge: 25C Constant / 50C Burst
Weight: 523g (including wire, plug & case)
Dimensions: 159x49x33mm
Balance Plug: JST-XH
Discharge Plug: 4mm bullet-connector
Is this a mistake that they are calling it a 4 cell then?
Old Dec 17, 2010, 04:11 PM
Z06 Tony's Avatar
Rochester NY
Joined Sep 2008
Spec.
Capacity: 5000mAh
Thats a mistake. They are either 11.1v 3s or 14.8v 4s. You will have to find out which one.
Site Sponsor
Old Dec 17, 2010, 04:59 PM
Joined Aug 2010
Thanks for clearing that up Tony
Wanted Turnigy nano-tech 2200mah 3S 45~90C Lipo Pack NIB unlvace Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 03, 2010 07:42 PM
Sold Nano Tech 4s 3000mah 25C-50C NEW MichaelT1960 Aircraft - Electric - Power Systems (FS/W) 2 Sep 13, 2010 07:51 AM
Sold Nano-Tech Turnigy 6000mah 3S 25~50C Lipo Pack Bombay Aircraft - Electric - Batteries & Chargers (FS/W) 9 Aug 30, 2010 12:18 PM
Sold NIB Turnigy nano-tech 4500mah 6S 25~50C Lipo Pack $75 djmoose Aircraft - Electric - Batteries & Chargers (FS/W) 3 Aug 21, 2010 08:19 AM
Sold Turnigy nano-tech 6000mah 6S 25~50C Lipo Pack x 2 Mikemynameis Aircraft - Electric - Batteries & Chargers (FS/W) 3 Aug 14, 2010 08:06 PM
