Old Dec 24, 2010, 11:49 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Thanks for bringing up the multi blade prop.
http://www.hobbyking.com/hobbyking/s...idCategory=279
16x5, 16x6, 16x8, 17x5, 17x6, 17x8, 18x7, 18x8
What I was trying to say is that the low pitch on top combined with a high pitch right below should give better results, or does this only work with counter rotating setups?
boredom.is.me is offline Find More Posts by boredom.is.me
Old Dec 25, 2010, 02:29 AM
Joined Nov 2007
It is Christmas morning, 3:27 am, and I'm here working. If you are having fun, does it still count as work? Anyway, here is a pic of the lower pivot rig. That box will accept the servo if I use one. It is made of six pieces; 1 pair of 1" thick milled pieces, 1 pair of 1" thick pieces, a 1/2" thick brace, and a 2" thick milled retainer.
Old Dec 25, 2010, 02:44 AM
Joined Nov 2007
I also have a potential sponsor. I can't wait to get back so that I can pursue the others I have in mind.
Old Dec 25, 2010, 03:32 PM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
I guess it might make sense to have different pitches. The other thing is the pointy end of the props is not so good for placing in a duct, as it leaves more space for air to leak past. You could cut the ends off the prop to make it flat so it seals up against the duct. Shouldn't be too hard to do. Once you mount the props on the motor, all you need to do it spin it up and hold a sanding block against the edge and sand until you get the diameter that you want.
Harrow is offline Find More Posts by Harrow
Old Dec 25, 2010, 04:28 PM
Joined Nov 2007
That is exactly what I was going to do.
Old Dec 25, 2010, 08:34 PM
Harrow is offline
Sydney, Australia
Joined Dec 2008
What is it that they say about great minds?
Old Dec 25, 2010, 08:41 PM
Joined Nov 2007
Something about how they think alike.
Old Dec 25, 2010, 09:38 PM
Joined Nov 2007
Here is the complete steering assembly. These parts will hopefully be machine cut and milled. If not than this entire setup is a bust. Let's not think about the bad though.
Old Dec 26, 2010, 08:30 AM
all4smallrc is offline
Find More Posts by all4smallrc
Founder of the EDF20 club!
all4smallrc's Avatar
Minnesota
Joined Apr 2008
Looks nice!
all4smallrc is offline Find More Posts by all4smallrc
Old Dec 26, 2010, 03:01 PM
Harrow is offline
Sydney, Australia
Joined Dec 2008
If this is a prank, Boredom is sure putting in a lot more effort than Wise Guy did!
Old Dec 27, 2010, 04:31 AM
Joined Nov 2007
I just added a new thread concerning lipo handling.
http://www.rcgroups.com/forums/showthread.php?t=1361064
I have to move all the pictures to the first post of this thread sooner or later.
It would be complete &$ if I couldn't get this done before the end of March.
Old Dec 27, 2010, 07:04 PM
Joined Nov 2007
I just made an adjustable pitch, five rotor lift fan. The pitch is manually adjusted, which is easy with a form and flat surface.
Take a look at the pics. It is pretty self explanatory.
Old Dec 27, 2010, 09:09 PM
Minnesota
Joined Apr 2008
What are your plans for how you will make the lift rotor?
Old Dec 27, 2010, 09:11 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
subbed this is looking awesome!!
foam and tape is offline Find More Posts by foam and tape
Old Dec 27, 2010, 10:35 PM
Joined Nov 2007
There are seven pieces; five rotor blades and two hub sections. The hubs are identical. It works by holding the rotors firmly together. The holding together will be done by 1/8" bolts - five around the perimeter and five closer to the center. The motor itself is responsible for holding onto the hub.
Some specs:
- hub dia. 6"
- blade count 6
- hub thickness 1 1/4"
- bolt holes 10
- bolt hole diameter 1/8"
- rotor dia. 18"
The custom lift rotor is wishful thinking at this point, but could be made like the rest of the balsa parts - cnc machining. The blade itself would require more than the average machine. So far I found one company that mills plastics and metals. I am getting quotes on the blades for various materials, but I doubt it will happen. I'm still looking for a company that works with balsa. I'll just ask if the next option will cut balsa.
New Product Carbon/Kevlar RC Racing hovercraft with [b]FULL ARTICULATED FIGURE ! camoesas RC Hovercraft 44 Apr 24, 2016 06:48 AM
Question JR X 347 Full house electric glider Graham 65 Electric Sailplanes 3 Nov 11, 2010 01:52 PM
Discussion Looking for MG servo Size: 0.9 x 0.4 x 0.9" (22 x 11 x 22mm) johnnyrocco123 High Performance 3 Oct 09, 2010 10:06 PM
Discussion Full size electric aircraft at EAA Fly-IN..time to start on a full size F-22;) Ed Waldrep Electric Ducted Fan Jet Talk 9 Aug 05, 2008 06:53 PM
For Sale Full size hovercraft for sale - trade nitromark Non R/C Items (FS/W) 18 Jan 21, 2007 03:54 PM
