Old Apr 19, 2011, 03:04 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I got held up big time by "life" and "stuff", but I'll show what's done later on today. It is 4 am and I am going back to sleep.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Apr 19, 2011, 09:43 AM
custom t is offline
Find More Posts by custom t
Platinum Ball3r
custom t's Avatar
Canada, BC, North Vancouver
Joined Oct 2009
Ok yay!
custom t is offline Find More Posts by custom t
Old Apr 20, 2011, 03:12 PM
Joined Nov 2007
Just a little something.
Old Apr 20, 2011, 03:13 PM
Joined Nov 2007
Idk why they are upside down, but you get the idea.
Old Apr 21, 2011, 07:47 AM
FalseHope is offline
Find More Posts by FalseHope
Foam Flyer
FalseHope's Avatar
Wakulla County, FL
Joined Oct 2009
Wow! A hovercraft that hovers inverted. You better watch it, the military will come calling for that kind of technology.
FalseHope is offline Find More Posts by FalseHope
Old Apr 22, 2011, 06:20 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
haha very cool BIM! you gotta get it to work and at least take one cruise down the street before shelving it
derk is offline Find More Posts by derk
Old Apr 30, 2011, 09:36 PM
djdavies83 is offline
Find More Posts by djdavies83
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
Nice work mate! Glad I'm on my laptop, I just held it upside down!
You uploaded at 4am, it happens.
Oh found micro outboard wind up motors, should be able to fit a 6mm or something in them.
djdavies83 is offline Find More Posts by djdavies83
Old May 01, 2011, 07:29 AM
Joined Nov 2007
Good find dj.
Due to stupid reasons, this will have to be postponed.
Old May 01, 2011, 06:24 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
The hover craft or the micro out-board? I hope it's not the hovercraft.
Old May 01, 2011, 08:00 PM
Joined Nov 2007
It's not the outboard.
Old Jun 25, 2011, 07:05 AM
Brady93 is offline
Find More Posts by Brady93
Glover
Brady93's Avatar
Joined Jun 2011
Hey.
I am interested in building one of these as a school project (Senior school composite materials studies).
Any more updates? Keen to see more, this is the best hovercraft i've came accross so far. It looks excellent.
I've got access to pretty much any petrol two stroke or four stroke engine. I have a workshop full of them i can use. Lol.
I've just sent away an email to a local foam specialist to get a quote.
I've been thinking of using two 4 stroke 150cc Briggs and stratton engines one at the front and one at the back, just for the hover, and a 2 stroke Victa 150cc engine for the propulsion prop.
Do you guys think this may be overkill? Or maybe to heavy?
What conventional materials can i use to make a skirt?
My aim is to carry a payload of 200kg.
Is this unrealistic with those engines?
Open to all idea's, thought's and advice.
Cheers
Brady
Brady93 is offline Find More Posts by Brady93
Old Jun 25, 2011, 10:14 AM
Joined Nov 2007
I'm continuing this project when I get to the states. There, I will actually have support. I think I may even start over. It is actually pretty cheap and I will have access to a larger cnc machine. Every part will be more precise and exact. I honestly do not like the quality of the current one, but it is way more than acceptable.
Brady,
You should know what your doing with the material. The foam by itself will only support a load if there is a hard surface. In my case, that hard surface is either a 2'x4' piece of wood or plexi. The wood is heavy, but I have been using it when I was working on the hull. In your case. You will need way more than a driver support. You will need to build an enclosure for the lift fan and you will need a bit more support, because of weight and heat aspects.
I personally prefer two strokes because they are significantly lighter, often times half the weight, than their four stroke counterparts. A modern two stroke is also just as clean or even cleaner than a four stroke. If the two stroke is not so modern (80s-90s), then I would suggest routing the exhaust to the side, not underneath.
I'll be back to this, but I may use bigger motors.
Old Jun 25, 2011, 10:33 AM
Joined Nov 2007
I'm also done dealing with HK. I'm going to a technical school. The needed electronics should be able to be produced in house.
Old Jun 25, 2011, 10:37 AM
Joined Nov 2007
I also had further updates, but at this point, a little more waitin wouldnt hurt. I got the entire thing built, except the skirt.
Old Jun 26, 2011, 05:35 AM
Brady93 is offline
Glover
Brady93's Avatar
Joined Jun 2011
Brady,
Excellent, thankyou.
Will take into consideration everything you said, on that information, i might make it one person for simplicity.
Can't wait to see this.
I was talking to an experienced friend the other day, he said it would be a good idea to cover the polystyrene foam with a thin layer of epoxy resin to seal it up against weather, and so the craft has a longer life span. A little extra weight for a much longer life span, and you can always upsize the motor if needed.
I am looking to make my hovercraft very efficient, so i will be toying with ideas along the way. Would you like me to share info with you as my design process proceeds?
I'm sure you've already thought of everything, but you never know. Lol.
Brady
New Product Carbon/Kevlar RC Racing hovercraft with [b]FULL ARTICULATED FIGURE ! camoesas RC Hovercraft 44 Apr 24, 2016 06:48 AM
Question JR X 347 Full house electric glider Graham 65 Electric Sailplanes 3 Nov 11, 2010 01:52 PM
Discussion Looking for MG servo Size: 0.9 x 0.4 x 0.9" (22 x 11 x 22mm) johnnyrocco123 High Performance 3 Oct 09, 2010 10:06 PM
Discussion Full size electric aircraft at EAA Fly-IN..time to start on a full size F-22;) Ed Waldrep Electric Ducted Fan Jet Talk 9 Aug 05, 2008 06:53 PM
For Sale Full size hovercraft for sale - trade nitromark Non R/C Items (FS/W) 18 Jan 21, 2007 03:54 PM
