Old Mar 08, 2013, 11:31 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
unsubscribed! It blows me away how unhelpful everyone really is on this site. I remember the first time I asked a question on here how bad it was. It is really sad that you guys that hang out on this thread a not just more opened armed to help people. So with that said Cheers to the great Charger thread!
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Mar 09, 2013, 01:31 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Solar lamps use lipo?
Anyway what is the application?
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Mar 09, 2013, 01:39 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I find the information on this site helpful.
This thread should be replaced with something that is more current though.
Old Mar 09, 2013, 11:57 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Done deal.
Last edited by 7oneWo1f; Mar 09, 2013 at 12:22 PM. Reason: action was taken (Wow:)
Old Mar 10, 2013, 03:07 AM
speedactyl is offline
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
No solar lamp uses nimh but will try to replicate the concept using lipo to automatic charge when the lipo volt drop to a certain point but still use power from solar to run my rc while on the charge. Would like to try it on a car or a boat. Aircraft will be harder due to the weight
goal is to run an rc on solar and charge the lipo at the same time.
speedactyl is offline Find More Posts by speedactyl
Old Aug 10, 2015, 09:11 AM
etopsflight is offline
Find More Posts by etopsflight
Hong Kong
Joined May 2010
Guys
Here is my experience with a SKYRC Quattro B6 AC 'Professional Balance Recharger/Discharger' which I have been using on a regular basis for a little over 2 years to charge mainly Lipos and NiMhs.
While I have not used it to death, it has been treated well and looked after. I have had the following problems:-
a) the internal PSU died and would not convert supplied AC to DC resulting in a dead unit. Luckily enough, it does have a 11-18V XT60 DC input jack and I purchased a PSU in order to continue the use of the charger.
b) Port 1 will regularly balance charge correctly but it will not auto-cut off/finish the charge until it reached the time limit.
c) Port 2 LCD screen intermittently goes blank on power up rendering the port useless. Occasionally it can be recovered by powering down and then up again to restore the screen but it does blink every so often.
d) Port 4 has a MAIN CONNECTION ERROR message and is totally useless as a recharging or discharging port. If a NiMh battery is connected, it trips the unit to power down as some kind of short circuit self protection mode.
What seemingly to be a reliable and convenient multiple battery charger turned out to be a less that robust as the retail price had suggested. Anybody else had similar experience with this particular charger?
I am looking for another 4 x 6S charger but fearing that it's the same OEM's that produce all the chargers that are on the market and they all have the same inherent problems. Any good suggestions of reliable chargers? Thanks.
Etops
etopsflight is offline Find More Posts by etopsflight
Discussion Check list before you buy an EDF!! bighead93 Foamy EDFs 594 Apr 30, 2016 02:44 PM
Sold If you are in need of GOOD servos, LOOK HERE! flyinjrc74 Aircraft - General - Radio Equipment (FS/W) 7 Nov 12, 2010 07:49 AM
Discussion first fpv flights here - look here for beginer flights crashes and more nasty stuff! captaingeek Aerial Photography 4 Nov 01, 2010 05:15 PM
For Sale Are you looking for a trainer!? LOOK NO FURTHER! Alpha 60 Ecibob Aircraft - Fuel - Airplanes (FS/W) 8 Oct 15, 2010 07:23 AM
Link look here if you are looking for some 1/2 engines cmulder 1/2A Planes 3 Nov 19, 2008 10:09 PM
