Old Dec 24, 2012, 02:26 AM
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Originally Posted by polix View Post
ok sorry let me ask you this first, what are you actual charging needs? you mentioned a number of batteries at once right? how many? what type? how fast?
Right now I am charging 4 Cell/14.8 V/3000MaH Batteries (Most)
and then I have a bunch of 2 Cell/800Mah for my small TH Foamys
....But I am getting ready to buy a 74 Edge which will take a 6 cell Battery or might go 8 Cell which in that case I will probaly just pair the two 4 Cell Batteries up to do so. So I am trying to figure out what I would need to do to get the best results out of this charger and also if this was a good charger tha tI bought. It is too late with taking it back so I want to mak the most out of what I got, but It would be nice to hear that I did buy a good charger (If that is the case)
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Dec 24, 2012, 02:34 AM
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, BC, Summerland
Joined Nov 2012
Well, you may have gotten a good charger.... but here's what i do....
if your batteries are discharged to the same voltage level, you can recharge them in parallel with the same charger, but that's usually not the case.
If you want large parallel charging capacity, setup your own charging station, with multiple cheap chargers, like this (see attachment)
It's basically a suitcase that hooks up to a car battery, the bigger charger chargers 2-6 cell batteries at 200W (cost me $40), the 4 smaller chargers ($9 each) charge 2-4 cell batteries.
It gives me the ability to charge a lot of batteries at once at different voltage levels, no problem, and at a cheap setup price too.
Basically this charger 'suitcase' cost me about $100 including chargers, foam, and suitcase, not a bad deal. I've used it many times, it's awesome.
CrashAffinity is offline Find More Posts by CrashAffinity
Latest blog entry: DJI F550 build w/naza
Old Dec 24, 2012, 07:03 AM
Minnesota
Joined Sep 2003
I need a battery charger.
Which one is the best?
Greg
OldRookie is offline Find More Posts by OldRookie
Old Dec 24, 2012, 10:19 AM
Joined Jan 2012
Wow! That would have saved me about 200 dollars if I spoke to you before purchasing a charger: so what is the name these items that you bought and where can I buy them at??
Old Dec 24, 2012, 03:09 PM
Joined Nov 2012
The bigger charger is this one
http://www.hobbyking.com/hobbyking/s...ischarger.html
the smaller ones:
http://www.hobbyking.com/hobbyking/s...30w_2s_4s.html
i bought the 1st one quite a while ago, then just added the 4 little guys later on
no fancy features on these guys, just down and dirty really, for more money you'll get better features
Old Dec 27, 2012, 11:08 AM
Joined Nov 2012
Just want to ask before make a mistake here...
Im going to buy my first charger, and thinking about either a Imax B6, or a turnigy accucel 6 50w. Any major difference between these?
Which ones better?
Dr.Dork is offline Find More Posts by Dr.Dork
Old Dec 28, 2012, 10:26 AM
130 mph :)
3d astronaut's Avatar
Joined Sep 2011
I am curious about something.. Is there a way to use a bigger lipo battery ie a 6s 3000mah to power my accucel 6 for charging my micro 1s batteries? It would be so much easier than hauling around my power supply, finding an open plug at an indoor event, and dealing with all of that. I'm sure its been answered but after searching I cannot seem to find anything. Maybe its my wording in my search?
3d astronaut is offline Find More Posts by 3d astronaut
Old Dec 28, 2012, 02:21 PM
Joined Nov 2012
your accucel 6 appears to support an input voltage of 11-17 volts or so, so a 3 - 4 (maybe 5?) cell would be your safest battery to plug it into, and then yeah you could just charge your micro batteries that way
Old Dec 28, 2012, 03:23 PM
130 mph :)
Joined Sep 2011
Have you personally done this? I know it should work in theory, just looking for some results Thanks for your help!
Old Dec 28, 2012, 03:45 PM
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
A 5 cell Lipo will not work. Even at nominal voltage it is over 18V. A good size 4 cell lipo will cost you 2 to 3 times what a gel cell will cost you and you will risk the chance of ruining a lipo if you don't watch it's voltage very closely. A sealed gel cell is ususally 7,000 mAh and if you drain it while charging your packs it will not be damaged. That is the way I would go.
still4given is offline Find More Posts by still4given
Old Dec 28, 2012, 04:12 PM
130 mph :)
Joined Sep 2011
Wow didnt realize how cheap they are. Something like this? http://www.amainhobbies.com/product_...-Charger-Combo
Old Dec 28, 2012, 04:21 PM
Sky Pilot
Victorville, CA
Joined Jun 2006
Yes, no muss no fuss.
Old Dec 28, 2012, 04:50 PM
130 mph :)
Joined Sep 2011
I was really considering the lipo route but seeing as I am dumb and didnt think about input voltage, this is the perfect solution. I don't have any 4s packs that I would risk ruining by charging from them so buying one would be quite expensive. Thank you kind sir!
Old Dec 28, 2012, 07:24 PM
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
This discussion has inspired me to try using my motorcycle battery for charging 4S 2200 lipo's, in the field, using my 206B. It is 12 ah, so easily transported.
loNslo is offline Find More Posts by loNslo
Old Dec 28, 2012, 11:36 PM
Joined Nov 2012
Good point, definitely a better way to go
Discussion Check list before you buy an EDF!! bighead93 Foamy EDFs 479 Feb 04, 2013 03:42 AM
Sold If you are in need of GOOD servos, LOOK HERE! flyinjrc74 Aircraft - General - Radio Equipment (FS/W) 7 Nov 12, 2010 07:49 AM
Discussion first fpv flights here - look here for beginer flights crashes and more nasty stuff! captaingeek Aerial Photography 4 Nov 01, 2010 05:15 PM
For Sale Are you looking for a trainer!? LOOK NO FURTHER! Alpha 60 Ecibob Aircraft - Fuel - Airplanes (FS/W) 8 Oct 15, 2010 07:23 AM
Link look here if you are looking for some 1/2 engines cmulder 1/2A Planes 3 Nov 19, 2008 10:09 PM
