Old Jun 19, 2012, 03:28 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
You might have trouble...which is why I ask. "not needed yet but available" might be "not needed, which is a good thing because it might not work". It did not for me, on 6s, I guess because the power supplies drop from 25.3 to 25.1 V as the current goes up, and the charger has to switch from buck mode to boost mode.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jun 19, 2012, 04:08 PM
postalflyer72 is offline
Find More Posts by postalflyer72
Everything is Upgradeable.
USA, FL, Gainesville
Joined Aug 2010
I understand what you mean by running it hard. I would never try and run it to the maximum allowed, both charger and power supplies.
postalflyer72 is offline Find More Posts by postalflyer72
Old Jun 20, 2012, 03:28 AM
REVOJohn is offline
Find More Posts by REVOJohn
REVOJohn's Avatar
Singapore, Singapore
Joined Apr 2012
true. Most electronics coming from far east use replacement or 2nd hand components which we know does not run up to full design capacity. Also heatsinks are too small thus burning out most electronics.....so yes stay 10% below rated.
PowerLab althoug can be run at full power with full rated FETs and a killer heatsink.........1344W fullpower !!
REVOJohn is offline Find More Posts by REVOJohn
Site Sponsor
Old Jun 22, 2012, 05:41 AM
c0p0ut is offline
Find More Posts by c0p0ut
United States, IL, Chicago
Joined May 2012
Originally Posted by N6145k View Post
I'd skip the e-flite battery and get a gens ace 25c--a much better battery for the money in my opinion. The connectors are also better in my opinion. You'll have to modify the connector on your ESC with something like these.
Is there a paraboard I could use with the gens ace 25c or some other method for these plug types for parallel charging?
c0p0ut is offline Find More Posts by c0p0ut
Old Jun 22, 2012, 08:06 AM
c0p0ut is offline
Joined May 2012
Disregard above message. The Gens Ace use bullet/banana plug connections. I found compatible paraboards for these connections at EPbuddy.com.
I should be able to get a different plug connection board and use adaptors, or I can get the bullet/banana plug board, which is compatible with the ESC modified connector you listed above.
Thanks.
Old Jun 22, 2012, 12:16 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
No problem. I still like the GensAce connectors, but you do have to be careful to not force them to mate because you can damage the plastic. But at least you don't need a special set of pliers to take them apart, like you do with new e-flite batteries.
Old Jun 22, 2012, 12:27 PM
Kurtis is offline
Find More Posts by Kurtis
United Kingdom, Beverley
Joined May 2012
Hi, I'm thinking of parallel charging some batteries, iv got a charger in mind which is the skyrc B6 ultimate 400W using it with a parallel charging board, or would it be better to get the skyrc quattro b6AC?
Also does the charge have to be a specific ampage, I want to charge 3-4 2s 5000mAh lipo's,
Or have you guys got any recommended chargers?
Kurtis is offline Find More Posts by Kurtis
Old Jun 23, 2012, 05:53 PM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
I have the Hyperion Super Duo 3 that I use with a couple of server power supplies. You can see in the photo it is running 34A @ 25V. It is a 1000 watt charger total, 500w per side. I have charged 8 6S batteries at the same time at 1C. - 2 6S 5800 and 2 6S 4000 on each side. If I don't want to use that many batteries, I just charge what I need at 2C. Also was fun to build
Harry
A few more photos here http://www.rcgroups.com/forums/showthread.php?t=1656481
Harry H is offline Find More Posts by Harry H
Old Jun 23, 2012, 09:49 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Nice looking system Harry.
Old Jun 23, 2012, 10:05 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Thanks, I got worried about charging on my workbench with all the flammables around. This lets me take it to my office or bedroom and keep an eye on it.
Harry
Old Jul 07, 2012, 01:51 PM
Musictree is offline
Find More Posts by Musictree
Joined Jun 2012
I need to buy a 3s-4s Lipo and a solid reliable charger. I have just purchased a DJI 450 Quad Kit, and since the kit doesn't provide either of those items not to mention I am fairly new to working with the more serious rc aircrafts, I wondered what some of you who are much more experienced would suggest??? ie. product and shop links if possible are greatly appreciate.
Musictree is offline Find More Posts by Musictree
Old Jul 07, 2012, 03:02 PM
Red Scholefield is offline
Find More Posts by Red Scholefield
Molon labe
Red Scholefield's Avatar
USA, FL, Newberry
Joined Nov 2000
FMA CellPro 4S Gold . Make sure you order the adapter needed to match your battery pack.
http://www.revolectrix.com/4sgold_description_tab.htm
Red Scholefield is offline Find More Posts by Red Scholefield
Old Jul 13, 2012, 05:21 AM
REVOJohn is offline
REVOJohn's Avatar
Joined Apr 2012
Or the CellPRO 4SMC too. Fully smart charger and quote autonomous
Site Sponsor
Old Jul 15, 2012, 09:01 AM
SleepySean is offline
Find More Posts by SleepySean
PEMAC
SleepySean's Avatar
Australia, New South Wales, Penrith
Joined Jul 2007
Cellpro looks good. Another good entry level charger is the Accucel-6
I have an iCharger and it is fantastic, but a little more expensive.
I have used Turnigy batteries for many years and find them the best value and as good as most other brands.
SleepySean is offline Find More Posts by SleepySean
Old Jul 16, 2012, 01:29 AM
eagle75 is offline
Find More Posts by eagle75
Joined Feb 2012
Can the Accucel-6 give resistor reading for the packs? Is it important?
eagle75 is offline Find More Posts by eagle75
Discussion Check list before you buy an EDF!! bighead93 Foamy EDFs 594 Apr 30, 2016 02:44 PM
Sold If you are in need of GOOD servos, LOOK HERE! flyinjrc74 Aircraft - General - Radio Equipment (FS/W) 7 Nov 12, 2010 07:49 AM
Discussion first fpv flights here - look here for beginer flights crashes and more nasty stuff! captaingeek Aerial Photography 4 Nov 01, 2010 05:15 PM
For Sale Are you looking for a trainer!? LOOK NO FURTHER! Alpha 60 Ecibob Aircraft - Fuel - Airplanes (FS/W) 8 Oct 15, 2010 07:23 AM
Link look here if you are looking for some 1/2 engines cmulder 1/2A Planes 3 Nov 19, 2008 10:09 PM
