Old Dec 23, 2012, 11:14 AM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
But his is unmilled, he might want to go with the 9L for power? I was running a 15s on mine(but it was milled).
Free
Free is offline Find More Posts by Free
Old Dec 23, 2012, 11:27 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
15S is actually too much power for F3P.
That is what is in mine , and it is very easy to fly too fast.
Mine is a V1 and weighs 114 grams w/o the battery. Is the V2 that much lighter?
Less paint? (Mine has gained ~4 grams over the years)
But if you want more 3D/ vertical performance then more power might be in order.
The idea behind the 9L would be to run a bigger prop to get better down line braking.
Scott Barnhart and (I think) Jamie Hicks were running them on their Excel V2, which have no drag brakes.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 24, 2012, 09:48 AM
wjb111 is offline
Find More Posts by wjb111
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Thanks for the replies Tim & others.
With that said, I guess I will stay with the 9L. The prop that came with the v2 is a 8x4.3 gws. Sounds like I should go larger with a 9" GWS. 9x ??? pitch?
Keep in mind I am still a somewhat of a rookie in my mind & this is my first depron plane. I've been flying 3d foamies for a couple years & still working on my landings with my foam cessna 182 & flyzone switch before I attempt my 3d balsa planes.
Next question, what light weight receiver is suggested? I use a Futaba 7c radio.
Happy Holidays to all !!!
wjb111 is offline Find More Posts by wjb111
Old Dec 24, 2012, 12:03 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
The standard prop for the 9l is the 8x4.3. Searching I cannot find any data for it with a 9" prop. I would be careful and use a watt meter to do some testing first. I would hate to see you blow your motor.
It will fly fine with the 8" prop. The reason for going to a larger prop is for motor braking. Using the drag plates that come with the osiris you already have lots of drag.
If you try it, let us know how it works.
motorhead is offline Find More Posts by motorhead
Old Dec 24, 2012, 02:37 PM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
That's why went with the 1500kv, motor swinging a 9x4.3.. I removed the stock airbrakes and made custom smaller ones..
I flew the wings off it at indoor flying Sunday/food drive, In Babylon New York. Great group of guys, That enjoy some good flying..
Most of the guys were shocked at how well my custom Osora's flys! it's about a half inch shorter, and a Almost 2 inches narrower than a stock one.. It's a proper freestyle plane now..
Thanks to the Babylon fliers for Welcoming other clubs!
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Mar 17, 2013, 01:42 PM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
r/cmark is offline Find More Posts by r/cmark
Old Apr 12, 2013, 07:59 AM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Osiris v2 flown by Jamie Hicks
Here is a nice video of Jamie Hicks flying my Fancy Foam Osiris v2 at the TINY event, which is held every year in San Angelo, Texas.
OSIRISv2 jhicks (3 min 0 sec)
aerolite is offline Find More Posts by aerolite
Old Apr 12, 2013, 07:12 PM
wjb111 is offline
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Very nice. And great skills.
Do you use any type of rear spar or something where typically a rear wheel would be? I will be flying mine outside and concerned about tearing up the rear bottom....
Bill B.
Old Apr 12, 2013, 10:11 PM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
tie-wrap tail skid
Bill B.
I use a small tie-wrap (about 3mm wide and 1 1/2" long) glued directly onto the depron. Works great as a tail skid on concrete.
Here is a photo of the tie-wrap skid on a prototype plane. You can just make it out in the photo, but shows how I do it.
I hope this helps,
aerolite
Old Apr 15, 2013, 07:18 PM
wjb111 is offline
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Thanks aerolite. I will give it a try....
Bill B.
Discussion SPEED LIST - Speed, Plane, Pilot, Location, Date, Witness, Gyro?(Yes/No) daboz Dynamic Soaring 3091 May 23, 2016 02:40 PM
Discussion Twisted Hobbys - 32" Xtra Slick - Build, Fly, Vid hercdriver7777 3D Foamies 3018 Jul 03, 2014 12:53 PM
New Product Osiris V2 eli5539 Indoor Pattern/F3P 1 Dec 14, 2010 07:08 PM
Help! thread Not used any more yiny0730 FPV Talk 4 Oct 15, 2010 08:46 AM
