Old Jul 20, 2011, 01:13 AM
WBE is online now
WBE
Find More Posts by WBE
WBE
White Fang
WBE's Avatar
United States, NV, Henderson
Joined Aug 2005
Thanks for the mini review and the comparison Ray, enjoy your new bird!
WBE is online now Find More Posts by WBE
Old Jul 21, 2011, 10:44 AM
RayPB is offline
Find More Posts by RayPB
F3P and Sailplanes-Great!
RayPB's Avatar
S.E. Minnesota
Joined Jun 2007
Issue with depron "wheel pants" and "strut"
After a couple of flying sessions with my new Osiris V2, I noticed an issue and wonder if others have had the same problem and, if so, how they handled it.
I built my plane using the included wheels. As per the instructions, I taped the depron "wheel pants" to the vertical part of the .032" wire that becomes the axle for the wheels. After a few landings, I find that the top of the depron "wheel pant" is ripping away from the depron "strut where the "strut" is glued to the flat carbon fiber landing gear. This seems to happen because the wire flexes on landing causing the "wheel pant" (fastened to the wire) to flex right where it joins the more rigid carbon fiber strut.
Has anyone else had this problem? If I simply cut off the "wheel pants", would this affect the flying characteristics of the plane?
Ray
RayPB is offline Find More Posts by RayPB
Old Jul 21, 2011, 01:54 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
I don't use the wheel pants or leg shrouds on mine, and it flies just fine.
aerolite
aerolite is offline Find More Posts by aerolite
Old Jul 22, 2011, 11:39 AM
RayPB is offline
RayPB's Avatar
S.E. Minnesota
Joined Jun 2007
aerolite
aerolite,
Thanks. I think I will remove the depron leg shrouds and wheel pants for now. I can always cut out new ones and attach them if someone can suggest a way to attach them so they aren't damaged when landing.
By the way, I do "Fly inverted!" as much as possible.
Ray
This afternoon, I watched videos of Andrew Jesky, designer of the Osiris and Osiris V2 flying an Osiris V2 with the wheel pants and leg shrouds on his plane. I do think they look cool. Andrew, if you follow this thread, do you have any suggestions on how to keep the depron landing gear parts from being damaged when landing? Thanks, Ray
Old Jul 22, 2011, 07:29 PM
EnzoFalconi is offline
Find More Posts by EnzoFalconi
Joined Nov 2006
Pant attachment
This bent wire method has worked great for me on all the models I've used it on. The paperclip shape bends gives enough glue area to hold the wheelpant. It works well with depron or epp. My epp Sultimate gets flown exclusively outdoors and I land on dirt or pavement so I wanted real wheels and tires. My Deluxe V3 is mostly flown indoors or occasionally at night outdoors when the wind is calm. I've used this mounting method on many different foam models including my Osiris V1. Some models have had gear leg fairings and some didn't. I do NOT glue the top edge of the gear leg fairing to the fuselage and I always use round carbon rather than flat. Round carbon will flex in any direction. Flat carbon flex is primarily in the fore and aft direction when used as landing gear supports in our models. My models are not flown in competition, so a couple of extra grams isn't a big factor. I use wheels on all of my models so I can have the option of flying off of the pavement where I live when the winds are calm enough.
Cheers
Michael
EnzoFalconi is offline Find More Posts by EnzoFalconi
Old Jul 22, 2011, 08:28 PM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Originally Posted by RayPB View Post
aerolite,
Ray
Ray, take a look at this post. I demonstrate how to make landing gear, and have some photos on attaching wheel pants, and show a photo of a Fancy Foam yak with shrouds and pants attached using this method.
Dennis R.
http://www.rcgroups.com/forums/showp...84&postcount=1
Old Jul 23, 2011, 09:16 PM
RayPB is offline
RayPB's Avatar
S.E. Minnesota
Joined Jun 2007
Dennis, Michael,
Thanks for the help. I have taken the shrouds and wheel pants off my Osiris V2 for the moment. I'll fly it that way for a while. When I get the chance (lots going on at the moment), I'll cut out some new ones and try to attach them using the information you gave.
Do you two have any indoor videos of your flying an Osiris?
Ray
Old Jul 23, 2011, 11:42 PM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Dennis, Michael,
Ray
Actually I do have a video of me flying the Osiris in competiton, but I'll have to figure out how to edit it out of a 30 minute segment.
I'll work on it.
Dennis R.
Old Jul 25, 2011, 10:06 AM
leliommarino is offline
Find More Posts by leliommarino
leliommarino
leliommarino's Avatar
United States, MA
Joined Nov 2007
does anyone know how the batts from value hobby are i just boought some for this plane
leliommarino is offline Find More Posts by leliommarino
Old Jul 25, 2011, 10:26 AM
ronmad02 is offline
Find More Posts by ronmad02
AJ Addict
Toledo Ohio
Joined Jun 2008
I am using the G-force batterys from value hobby I like them I have some 3s 2200 ,2s350, 2s250 2s 800 , 3s 800, and 4s2650 I think they work really well. Priced right also .
ronmad02 is offline Find More Posts by ronmad02
Old Jul 27, 2011, 11:29 AM
RayPB is offline
RayPB's Avatar
S.E. Minnesota
Joined Jun 2007
I flew my Osiris V2 with bare carbon fiber landing gear at the armory this morning. It flew fine without the depron shrouds and wheel pants
A huge fan blowing diagonally across the room did make for interesting air currents.
Ray
Old Dec 12, 2011, 12:13 PM
Ducati Mechanic is online now
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
One on the way..
I just ordered a 3mm printed kit, Esc, and motor with four Hyperion packs from fancy foam..
I've been flying indoor Depron planes for a few years, but this is my first AJ. F3A plane.. I'm looking forward to some serious warehouse flying this winter!
BTW. Very cool design AJ! I dig the V2!
Ducati Mechanic is online now Find More Posts by Ducati Mechanic
Old Dec 12, 2011, 12:18 PM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
You'll love it. Flys like a dream.
teookie is offline Find More Posts by teookie
Old Dec 15, 2011, 04:25 PM
Joined Oct 2008
Looks like mike is getting mine shipped out right before vacation..
Thanks Mike.
Old Dec 24, 2011, 08:59 AM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
More new videos added (12/24/11). See post 1.
r/cmark is offline Find More Posts by r/cmark
Discussion SPEED LIST - Speed, Plane, Pilot, Location, Date, Witness, Gyro?(Yes/No) daboz Dynamic Soaring 3103 Jun 16, 2016 02:42 AM
Discussion Twisted Hobbys - 32" Xtra Slick - Build, Fly, Vid hercdriver7777 3D Foamies 3018 Jul 03, 2014 12:53 PM
New Product Osiris V2 eli5539 Indoor Pattern/F3P 1 Dec 14, 2010 07:08 PM
Help! thread Not used any more yiny0730 FPV Talk 4 Oct 15, 2010 08:46 AM
