Old Dec 22, 2010, 01:48 PM
xtremeRCpilot is offline
Find More Posts by xtremeRCpilot
xtremeRCpilot's Avatar
Cleveland, Ohio
Joined Sep 2006
How can you improve on an already great flying Bird, Leave it to Andrew to figure a way
Nice Design and Great Job on your build Mark!!
John
xtremeRCpilot is offline Find More Posts by xtremeRCpilot
Old Dec 24, 2010, 01:40 PM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
New Videos added in post 1. Finally got a nice day. I am used to flying the V2 now and I like it! It snaps and stall turns better than the V1. It is also almost a half oz lighter( lighter paint and more milling).
r/cmark is offline Find More Posts by r/cmark
Old Dec 24, 2010, 03:43 PM
steinywi is offline
Find More Posts by steinywi
Joined Apr 2008
Is the weight shown complete RTW with or without Battery? Mine came in at 4oz without battery.
Thanks steiny
steinywi is offline Find More Posts by steinywi
Old Dec 25, 2010, 11:40 AM
Andrew Jesky is offline
Find More Posts by Andrew Jesky
Andrew Jesky's Avatar
United States, UT, Tooele
Joined Oct 2002
Mark,
Glad to hear you got some good flights on the V2. Those are the things I noticed witht he V2. Also, the tail should fly a bit higher than the V1 as its lighter and I changed the configuration around to have the tail fly higher.
Andrew
Andrew Jesky is offline Find More Posts by Andrew Jesky
Old Dec 29, 2010, 12:41 PM
eli5539 is online now
Find More Posts by eli5539
eli5539's Avatar
Western New York
Joined Dec 2007
Got mine in and noticed that the servo pockets are on top, thought that they should be on the bottom
eli5539 is online now Find More Posts by eli5539
Old Dec 29, 2010, 08:02 PM
steinywi is offline
Joined Apr 2008
Nope mine are on the top. I cut a small hole under each servo to get the wire under wing to receiver. Hope this helps!
Old Jan 03, 2011, 09:24 AM
TopDave is offline
Find More Posts by TopDave
MY '75 CZ "FALTA REPLICA" 2010
TopDave's Avatar
Waterford, Michigan
Joined May 2006
Anyone care to post pic of their radio/battery placement? i would really appreciate it! thanks, Dave
TopDave is offline Find More Posts by TopDave
Old Jan 03, 2011, 05:28 PM
steinywi is offline
Joined Apr 2008
Hope this helps!
Old Jan 04, 2011, 09:20 AM
TopDave is offline
TopDave's Avatar
Waterford, Michigan
Joined May 2006
Originally Posted by steinywi View Post
hope this helps!
thanks alot steiny!
Old Jan 04, 2011, 09:31 AM
TopDave is offline
TopDave's Avatar
Waterford, Michigan
Joined May 2006
cogging
Has anyone experienced "cogging" or hard starting at start up with the Hacker A10-15s / Thunderbird 9 combo? Mine will start intermittantly or will cog and with careful throttle control start up. I also can flick the prop and get it to run. I went thru the reprogramming routine without improvement also. New fully charged thunderpower lites 7.4 350 mah batts too.
Thanks, Dave
Old Jan 04, 2011, 09:35 AM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Thanks, Dave
what prop are you running?
aerolite
aerolite is offline Find More Posts by aerolite
Old Jan 04, 2011, 10:48 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Thanks, Dave
I had the same problem with the TB 6, switching to the PH 10 or Turnigy Plush solved the problem. Seems to be a timing issue, but the timing is not adjustable in the TB series. I took all kinds of grief about " hand starting" an electric motor.
Azarr
Azarr is offline Find More Posts by Azarr
Old Jan 04, 2011, 11:25 AM
steinywi is offline
Joined Apr 2008
Yes I have an older T-9 with version 1.02 software and it works great, but the new T-9 with version 3.0 does not let the motor start. I have sent my new controller back to have them look at it! I have also tried another motor and had the same problem!
Old Jan 04, 2011, 05:59 PM
TopDave is offline
TopDave's Avatar
Waterford, Michigan
Joined May 2006
aerolite
aerolite, running a gws 8x4.3 prop. What are you thinking the prop size would effect? I'm just a noob to all of this stuff, so I'm just curious to learn what you guys have experienced. Thanks guys, Dave
Old Jan 04, 2011, 06:17 PM
RayPB is offline
Find More Posts by RayPB
F3P and Sailplanes-Great!
RayPB's Avatar
S.E. Minnesota
Joined Jun 2007
I use the same motor/ESC/prop/battery combination as you do, and do not experienced the cogging you mention. I have, however, had a cogging problem when using too large props on other motors.
Ray
RayPB is offline Find More Posts by RayPB
Discussion SPEED LIST - Speed, Plane, Pilot, Location, Date, Witness, Gyro?(Yes/No) daboz Dynamic Soaring 3030 Feb 09, 2016 08:38 PM
Discussion Twisted Hobbys - 32" Xtra Slick - Build, Fly, Vid hercdriver7777 3D Foamies 3018 Jul 03, 2014 01:53 PM
New Product Osiris V2 eli5539 Indoor Pattern/F3P 1 Dec 14, 2010 08:08 PM
Help! thread Not used any more yiny0730 FPV Talk 4 Oct 15, 2010 09:46 AM
