| Thread Tools |
| This thread is privately moderated by Keenan smith, who may elect to delete unwanted replies. |
On your very first post, it stated: SPECS: 4ft 2" long 7" wide 4ft 2" wingspan That's why I was worried about wing loading if retracts is added. But now it's 5' 5" Anyway here is my idea. DON't SHOOT ME though... Buy this for $3.99 http://www.hobbyking.com/hobbyking/s...idProduct=3821 or http://www.hobbyking.com/hobbyking/s...idProduct=8001 then the scale wheels from http://www.pw-rc.com/product_info.ph...oducts_id/1657 $15 for a set of 4 wheels for the 59.8" wingspan A380, each set has 4 wheels and weighs only 18.5 grams, and heres what you do: 2 ways: If you wanna make everything easy for yourself: Option one shows more scale but you'll have to drill hole precisely. The axle swivels, and helps better landings. Option 2, modify the steel wire into carbon fiber tube as shown in the picture. Other retracts to consider: 2nd: http://www.hobbyking.com/hobbyking/s...idProduct=8001 3rd: WHICH I HIGHLY RECOMMEND: A. http://www.hobbyking.com/hobbyking/s...dProduct=12883 B. NOSE GEAR : http://www.hobbyking.com/hobbyking/s...dProduct=11302 and make sure to add a bit of forward angle on the nose gear for landings. GEARS ON THE PICTURES SWIVELS 10deg up & 10 deg down AS SET BY THE MANUFACTURER (that's why 2 pics where shown) But again don't shoot me, read reviews on each item |
Option 3, which is a continuation of OPTION 1 label. On option 1 picture, you can clearly see the metal wheel axle that could be extended, use it to the add middle wheels, the the front and back wheels can be extended with flat carbon fiber piece on both sides. Heres a quick fix picture and the cheap xtra 30mm wheels needed for $2.66 a bag and hub can be spray painted with black to match the rest. http://www.hobbyking.com/hobbyking/s...dProduct=10405 Use the gears from the picture from above and follow the picture below to make it a 6-wheel boggie ![]() -SPYRO |
Latest blog entry: Joe Nall 2013!
Keenan I think I might have found a very good & easy solution for your A380's landing gear.
http://www.scaleflying.com/Airbus-A3...s_p_1190.html# |
http://www.windrider.com.hk/product.asp?id=166 |
http://www.windrider.com.hk/product.asp?page=2&id=200 http://www.windrider.com.hk/product.asp?page=3&id=200 |
| Thread Tools | |
| Discussion Huge cargo plane hover vid. | Pilot28 | Electric Plane Talk | 21 | Dec 22, 2010 06:34 PM |
| Discussion 72" wingspan cargo plane vids | Pilot28 | Electric Plane Talk | 1 | Sep 21, 2010 04:58 PM |
| Discussion Cargo Plane Plans | urpu36 | Electric Plane Talk | 1 | Sep 19, 2010 12:15 PM |
| Discussion build of an A400-CX new cargo plane | w747 | Scale Electric Planes | 2 | Sep 05, 2008 02:42 PM |
