Espritmodel.com Heli Air
Closed Thread
This thread is privately moderated by Keenan smith, who may elect to delete unwanted replies.
Old Dec 16, 2010, 05:33 PM
Depressed, Enraged and DF CEO
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
3.5 metre A380
change of plan
hi every one i i am going to build a Airbus A380
i am planning on using
SPECS:
3.26m long
28cm wide
3.57m wingspan
1m tall
POWER SYSTEM:
X2. HK-SS60A - Hobbyking SS Series 50-60A ESC
X1. planet 5 2.4Ghz 5 CH Tx & Rx V2 (Mode 1..
X4. HK90139 - HK2839 EDF Outrunner 2800kv for 70mm
X4. 130mm edf
X5. Hitec/ 1.6kg / .12sec Micro Servo
X6. hitec MG Metal Gear Servo 2.5kg/
X2OR007-01701 - Full Direction Elevator arms 90x28x12mm
X2. Turnigy 4000mAh 2S 30C Lipo Pack
X1. Mechanical Retracts 2 sets (6pc)
X22 foam wheels
pls comment and tell me what you think
Keenan smith is offline Find More Posts by Keenan smith
Old Dec 18, 2010, 01:21 PM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
everything looks good, except the speed control and the packs. the speed controls should be 30Amp. if you look at any 64mm size jet for sale, they all come with a 30Amp ESC for 3S packs. and you'll need two.........one for each fan/motor. I only saw one listed. secondly, your packs don't have enough mAh in them for anything decent in flight time. the bigger the better and get the highest C rating you can afford. if it were me, I would be getting a minimum of 2200-3000mAh packs with a 35-40C rating. the higher C rating will keep them cooler and the higher mAh will give you longer flight times. with a plane that big and lots of lifting surface, you should get the largest packs you fit in there. perhaps 4 packs total, or two per fan, wired in parallel. this'll double your mAh, while maintaining the same voltage. which equals massively long flight times. the best bang for the buck are the Nano-Tech packs from Turnigy. check them out.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 18, 2010, 02:57 PM
Joined Dec 2010
thanks
as im on a tight budget and im starting off with two 64mm with a 4500kv motor and 7 bladed fans for the engine pods 2 and 3 then ill scale up to four 64mm ducted fans and two HK-SS30A - Hobbyking SS Series 25-30A ESC
Joined Jan 2009
if you are gonna go Turnigy packs, then go with the 2200's instead of the 1000's. there's only a couple of bucks difference in price. the other option is to see what's available on here, used. a lot of guys are selling 2200's for almost next to nothing. put a want add up, asking for them and see what replies you get. deffinitely don't get less than 30Amp ESC's. they will provide you with plenty of overkill for 64mm fans. off the top of my head, a 64mm will probably pull somewhere around 20Amps, so the 30's will give lots of overhead. again, you could put a want add for those too, if you are on a budget.
Rich
Old Dec 18, 2010, 03:01 PM
Joined Jan 2009
also check the Plush series of ESC's. they are damn near bullet proof. the Hobbywing are good, but the Plush are a bit better and the same price.
Old Dec 18, 2010, 03:07 PM
Joined Dec 2010
nah i only have 2 hobbywing is what i have lying about i was originaly going to order the 6a plush ones in from hobbyking
Joined Jan 2009
is that $87 for packs and ESC's, or just for packs?
oh, I see. that's what you have laying around. they'll work well for this application. check hobbypartz.com for their Blu Lipos, as well as hobbyking.
Old Dec 18, 2010, 03:11 PM
Joined Dec 2010
$87 for pack and servos + reciever
Old Dec 18, 2010, 03:12 PM
Joined Jan 2009
here's the packs from hobbyking
http://www.hobbyking.com/hobbyking/s...idProduct=8934
if you order servos from them, you can cut down on shipping costs and I believe they are about 3 bucks a piece for servos. maybe less.
if you join a swarm, you can often get several dollars off the suggested price.
Old Dec 18, 2010, 03:15 PM
Joined Jan 2009
these servos will work well for this application.
http://www.hobbyking.com/hobbyking/s...?idProduct=662
Old Dec 18, 2010, 03:18 PM
Joined Jan 2009
see above. they are 2.69 each. they are great servos, center well and are great for the money.
Old Dec 18, 2010, 03:22 PM
Joined Dec 2010
now in terms of landing gear what would you reccomend
Old Dec 18, 2010, 03:26 PM
Joined Dec 2010
and p.s i just bought 5 of the servos you reccomended
Old Dec 18, 2010, 03:31 PM
Joined Jan 2009
you made a good choice then. LOL. they are awesome servos for the money. you can't beat them.
what are you thinking for landing gear? do you want fixed, or retracts?
Old Dec 18, 2010, 03:38 PM
Joined Dec 2010
retracts but they have to look scale but still cheap
Closed Thread
Discussion Huge cargo plane hover vid. Pilot28 Electric Plane Talk 21 Dec 22, 2010 06:34 PM
Discussion 72" wingspan cargo plane vids Pilot28 Electric Plane Talk 1 Sep 21, 2010 04:58 PM
Discussion Cargo Plane Plans urpu36 Electric Plane Talk 1 Sep 19, 2010 12:15 PM
Discussion build of an A400-CX new cargo plane w747 Scale Electric Planes 2 Sep 05, 2008 02:42 PM
