Old Jan 28, 2013, 08:24 AM
krokko is offline
Find More Posts by krokko
Sweden, Dalarna County, Aspeboda
Joined Dec 2005
Originally Posted by TomCrump View Post
Looks good, krokko.
Don't overthink the right and down thrust issue. You can always add it after your maiden flight, if you feel that it's needed. All you'd need to do is add shims behind the motor mount.
Yes, Tom,
but
If its only 1-2 mm its ok, but if it's more, then the mount need to be moved left in order to have the prop sitting in the centre......
I dont bother right now, the engine is probably going to be used half-throttle anyway.
it's always good to have a little spare if a situation comes up!
/krokko
krokko is offline Find More Posts by krokko
Old Jan 28, 2013, 12:31 PM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
Originally Posted by krokko View Post
Yes, Tom,
but
/krokko
You can always use the rudder on take off. I don't build right thrust in anymore.
Downthrust is good if there isn a lot of wing incedence.
SrTelemaster is offline Find More Posts by SrTelemaster
Old Jan 28, 2013, 12:45 PM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I'm with you, Tele.
There has been hundreds of these built per plans. I see no reason to modify the thrust angles.
If encountered, any problems can be solved by proper usage of throttle and rudder.
TomCrump is offline Find More Posts by TomCrump
Old Jan 28, 2013, 05:29 PM
Wilian Amaral is offline
Find More Posts by Wilian Amaral
SENTA A PUAAA!!!
Wilian Amaral's Avatar
Brazil, RJ, Miguel Pereira
Joined Apr 2007
Krokko, the 2mm difference you've found could be error from the ruler you're using. It's normal.
Even if it's not, 2mm in a plane wich wingspan is 2642mm is really nothing.
Wilian Amaral is offline Find More Posts by Wilian Amaral
Old Jan 29, 2013, 11:20 AM
krokko is offline
Joined Dec 2005
tail feathers
progress update,
tail put together, I used Robarts pins.
It's not glued together yet, have to look into all other small pieces in the back before gluing the stab and fin.
glued the two pins to the front of the wing center. looks OK.
Need to get courage to cut the ailerons......and fix them with hinges and the rest. I'm going to follow the plan for servo installation in the wing. It looks ok and the explanation for the servo hook up seem ok.
Landing gear blocks and landing gear is also on the agenda. (the winter is long here, no hurry)!
Couldn't resist to add a pic on my partner "Elvis"
rgds/krokko
Old Jan 29, 2013, 11:37 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Does Elvis help you build ?
I followed Sig's instruction, when cutting out the ailerons. It's not hard, but it does take some courage. LOL
Here's a pic of Talle, taken today. She was helping me on my current project.
Old Jan 29, 2013, 11:38 AM
krokko is offline
Joined Dec 2005
rolemodel?
couldn't resist showing a link to a really nicely built SW.
Almost made me think of moving in to stamp collecting!
The end wasn't that nice,lets hope he could put the pieces together.
Sig Spacewalker, veho muvi hd cam, (5 min 5 sec)
rgds/krokko
Old Jan 29, 2013, 11:42 AM
krokko is offline
Joined Dec 2005
No, he doesn't like the smell of the glue, he is active on the field helping me starting the engine, very curious and interested!
did you look at the videolink I just put up, even the instruments was moving around!!???
Old Jan 29, 2013, 11:53 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
The builder did add some great detail. It didn't look like he was in trouble. I wonder what happened ?
You're doing a nice job on your SW. There's no need for you to take up stamp collecting.
Old Jan 29, 2013, 12:03 PM
I HATE GLOW PLUGS!
Joined Feb 2012
http://www.youtube.com/watch?v=3dhv9rkwy3I
rgds/krokko
Why do people put music over the soundtrack!
I would have much rather listened to that OS 300T!
Awesome cockpit detail! I Hope to do mine as an all-out scale except for the heads & carbs of the Saito duel carb FA300TTDP CDI engine hanging out the sides of the cowl.
Old Jan 29, 2013, 02:33 PM
krokko is offline
Joined Dec 2005
Hello there!
CDI on a methanol engine, conversion to gas. Yes, if you think it's necessary, otherwise, why!
I have a new Laser 180 on my Tiger Moth, abolutely OK, why considering gas and CDI when I fly tha plane a couple of hours per season??
Maybe you sell the CDI systems, then I can understand you!!!
Old Jan 29, 2013, 03:47 PM
I HATE GLOW PLUGS!
Joined Feb 2012
Hello there!
Glow ignition compared to converting to CDI/Methanol:
CDI W/methanol starts easier, idles reliably about 300 RPM lower, W/34 BTDC ingnition timing it will make about 6% more power and it will run about 25% longer on the same amount of fuel. No support equipment to lug around. The module battery can be charged W/ the same charger as the Rx battery.
Indeed, the question seems to be.... WHY NOT!
If a person flys more than a couple of hours a season, it's a no brainer.
As far as converting to gas?
Gas stinks, it is dangerous to transport inside a vehicle & the converted glow engine are highly unlikely to last as long burning gasoline as they will burning methanol. The elevated temperatures & carbon will take it's toll on the top end while the reduced oil mixes will affect the non-roller bearing rods. I can make 33% more HP in a 30cc CDI/Meth engine than a 20% larger 36cc gas 4-stroke.
If you really want to save fuel cost, get rid of the pick up truck that you need to haul gas models around & get a mini van to haul methaol inside.
I am looking at placing my FA180HC CDI/BBC engine into a 105" WS 20# Maxford 20% JN-4 Jenny.
With 3.5HP on 15% nitro spinning a 20 X 6 prop @ 8000 RPM I can geneate 29# of static thrust and fly in excess of 45 MPH. What more do I need?
Your glow ignition Laser will be hard pressed to do that & it will use @ least 20% more fuel IF it does.
Pay attention to what I'm putting down in my posts. it's not guesswork, I have proven it on many occasions.
Old Jan 29, 2013, 04:41 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Are we going here, again ?
Old Jan 29, 2013, 04:50 PM
I HATE GLOW PLUGS!
Joined Feb 2012
Sorry I forgot what thread I was on. There's a discussion on the subject elswhere.
Old Jan 29, 2013, 04:54 PM
don olsen is offline
Find More Posts by don olsen
I hate spray cans
don olsen's Avatar
United States, NM, Rio Rancho
Joined Jul 2007
Tom
They are doing it just to get you going! EVERYBODY know you dont want to hear about converting perfectly good motors into a perfectly good motor just a couple hundred dollars more. EVERYBODY knows not to post this on YOUR threads out of respect
Don
don olsen is offline Find More Posts by don olsen
For Sale Sig 1/3 Scale Spacewalker $400.00 local pick up only be69ar Aircraft - Fuel - Airplanes (FS/W) 0 Dec 21, 2008 05:14 PM
For Sale Sig 1/3-scale Spacewalker KIT for sale Bruce DeVisser Aircraft - Fuel - Airplanes (FS/W) 0 Aug 08, 2006 10:51 PM
Sold Sig 1/3-Scale Spacewalker w/G-38 ~ Just add Radio! N925WB Aircraft - Fuel - Airplanes (FS/W) 2 Apr 15, 2006 07:31 PM
For Sale 1/3 scale Sig spacewalker whov Aircraft - Fuel - Airplanes (FS/W) 1 Mar 22, 2006 04:41 PM
Sold Swap Meet Sale!!! Sig 1/3-Scale Spacewalker w/G-38 N925WB Aircraft - Fuel - Airplanes (FS/W) 2 Feb 18, 2006 03:09 PM
