Old Jan 20, 2013, 08:31 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Originally Posted by SrTelemaster View Post
Not wanting "Cub" gear. I want autentic scale Spacewalker gear.
How do they differ ?
TomCrump is offline Find More Posts by TomCrump
Old Jan 20, 2013, 08:52 AM
SrTelemaster is online now
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
Do they not differ?
If they are exactly the same, that would be great as there are functional bungee Cub gear that I would love to use.
When one says that the Cub gear can be "adapted" that insinuates that the gear is not exactly the same.
I plan to do mine all out full cockpit scale W/the exception of the FA300TTDP cylinder head/dual carbs protruding from the sides of the cowl.
SrTelemaster is online now Find More Posts by SrTelemaster
Old Jan 20, 2013, 09:19 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
They are not the same in that mods will be necessary when building your airframe. From what I saw at the time, it would be easy, then.
I looked at it after I had completed most of the wing center section, and decided not to do a retrofit.
Old Jan 20, 2013, 09:24 AM
I HATE GLOW PLUGS!
Joined Feb 2012
Can you elaborate?
Are the maingears dimensionally the same?
Old Jan 20, 2013, 01:49 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
You'd have to check. I saw that the two gear mount differently. I didn't want to open up the sheeted structure to make the modifications. I never went any farther than that.
I believe there is a discussion of this, somewhere in this thread.
Old Jan 20, 2013, 02:24 PM
I HATE GLOW PLUGS!
Joined Feb 2012
Hey thanks for what you were able to convey.
I'll cneck into it.
Old Jan 21, 2013, 05:08 AM
krokko is offline
Find More Posts by krokko
Sweden, Dalarna County, Aspeboda
Joined Dec 2005
progress report........
Tom,
Started the fuselage today - looks good!
Right wing almost finished, need to cut out the aileron, then left wing.
I really like this SIG kit, it's the first I ever bought from them. Clear instructions and very good quality plans. I have cut the nose to the ZDZ50 NG, it needed one inch shorter nose.
krokko is offline Find More Posts by krokko
Old Jan 21, 2013, 06:39 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
krokko
You're doing a great job !
Look back in this thread, to where I joined the front fuselage to the rear. I layed 1/32" ply over the joint, to help bond the halves together.
This really strengthens the area. You may want to take a lok, and see if you are interested in doing something similar.
Old Jan 21, 2013, 07:53 AM
I HATE GLOW PLUGS!
Joined Feb 2012
I did some checking on the Robart Cub maingear.
The 1/3 Cub gear is way to large.
The 1/4 scale gear #690 would work.
The width @ the fuselage mounting is spot on & the hieght is only 1/4" less than the OEM SIG gear.
However, the width of the Roabart gear is 15 1/8" @ the wheel hub whereas the Sig gear is about 18" wide.
I'll just have to utilize the SIG gear as I do not want to sacrifice ground handling W/a narrower maingear.
Old Jan 21, 2013, 09:21 AM
krokko is offline
Joined Dec 2005
krokko
Yes, Tom,
I noticed earlier and intend to follow your example!
(I had a problem with the upper center spar bending down a bit in the back, until I read the instructions and understood that it was for the incidence,,,,,,,)
Old Jan 23, 2013, 08:52 AM
krokko is offline
Joined Dec 2005
Fuselage and left wing coming on.
Progress is made - fuselage done up til the point when the wing middle should be installed. Left wing started.
/krokko
Old Jan 23, 2013, 09:07 AM
4075aaron is offline
Find More Posts by 4075aaron
United States, MD, Frostburg
Joined Aug 2008
What a beast! You are doing a great job. I can't wait to build mine.
4075aaron is offline Find More Posts by 4075aaron
Old Jan 23, 2013, 09:28 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
I don't know how forgiving your covering is going to be, but if it were me; I would taper the backrest/stringer filets to a very narrow trailing edge so they do not form a step, that may show as such when finished.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Jan 23, 2013, 11:13 AM
krokko is offline
Joined Dec 2005
Les
Hi Les,
Yes I have been thinking about the covering, once did a couple of mistakes that I paid for later, (on a Super Cub). I'll keep thinking about the covering, haven't decided yet but believe that plastic film isn't an option!
/krokko
Old Jan 23, 2013, 07:48 PM
Wilian Amaral is offline
Find More Posts by Wilian Amaral
SENTA A PUAAA!!!
Wilian Amaral's Avatar
Brazil, RJ, Miguel Pereira
Joined Apr 2007
nice job!
Wilian Amaral is offline Find More Posts by Wilian Amaral
For Sale Sig 1/3 Scale Spacewalker $400.00 local pick up only be69ar Aircraft - Fuel - Airplanes (FS/W) 0 Dec 21, 2008 05:14 PM
For Sale Sig 1/3-scale Spacewalker KIT for sale Bruce DeVisser Aircraft - Fuel - Airplanes (FS/W) 0 Aug 08, 2006 10:51 PM
Sold Sig 1/3-Scale Spacewalker w/G-38 ~ Just add Radio! N925WB Aircraft - Fuel - Airplanes (FS/W) 2 Apr 15, 2006 07:31 PM
For Sale 1/3 scale Sig spacewalker whov Aircraft - Fuel - Airplanes (FS/W) 1 Mar 22, 2006 04:41 PM
Sold Swap Meet Sale!!! Sig 1/3-Scale Spacewalker w/G-38 N925WB Aircraft - Fuel - Airplanes (FS/W) 2 Feb 18, 2006 03:09 PM
