Give that 1.60 a shot in your SW. Most likely, you'll be able to fly at very low throttle settings. That ain't all bad, as that twin will sound like a Harley as you fly by.
I would suggest that you use an onboard glow unit, like the ones from Electro Dynamics. http://www.electrodynam.com/rc/EDR-103/index.shtml I have the trwin cylinder unit on my 1.60. It's easy to install and set up, and it works flawlessly. |
Sweden, Dalarna County, Aspeboda
Joined Dec 2005
I have been reading thru your thread and find it very useful for my SW 1/3 build, which I started yesterday! I'm also retired so there is plenty of time to spend in the shop. Latest was the Flair Tiger Moth 1/4 scale. (there is a thread on that one in RCGroups). So far I think that the quality of the SIG kit is much better then the Flair was. For instance I got 1:1 drawings with the SIG, xerox copied A3 instructions with the Flair! OK, to my questions: I see that you tapped the alu wing holders both up and below, isn't it enough with only below? I plan to put a 33cc Mintor on the SW, any comments on that one? I love all your pictures in the thread, haven't seen any maiden video yet? Maybe I missed something! rgds/krokko |
We all have insights. I'm sure that you could add something to what's been posted.
If it were me, I'd go with the ZDZ. Lay it over your plans. The cowl may turn out to be long enough to work for you. If not, maybe you could extend the sheeting, up front, just enough to make it work, without modifying the engine box. I don't like to over power my models, but I do prefer to make my life easy. The larger engine should simplify any balance issues, besides providing any extra power that you may desire. |
Joined Dec 2005
OK, I'll try and fit the ZDZ. Just because you suggested it, your fault if I crash!! LOL (I'm sure that the power is going to be enough)! /krokko |
CDI W/glow fuel makes 5-6% more power, runs about 25% longer on a given fuel load, gives lower reliable idle speeds & easier flip staring. With the required battery packs, CDI will weigh slightly less & take up less room. |
| Thread Tools | |
| For Sale Sig 1/3 Scale Spacewalker $400.00 local pick up only | be69ar | Aircraft - Fuel - Airplanes (FS/W) | 0 | Dec 21, 2008 05:14 PM |
| For Sale Sig 1/3-scale Spacewalker KIT for sale | Bruce DeVisser | Aircraft - Fuel - Airplanes (FS/W) | 0 | Aug 08, 2006 10:51 PM |
| Sold Sig 1/3-Scale Spacewalker w/G-38 ~ Just add Radio! | N925WB | Aircraft - Fuel - Airplanes (FS/W) | 2 | Apr 15, 2006 07:31 PM |
| For Sale 1/3 scale Sig spacewalker | whov | Aircraft - Fuel - Airplanes (FS/W) | 1 | Mar 22, 2006 04:41 PM |
| Sold Swap Meet Sale!!! Sig 1/3-Scale Spacewalker w/G-38 | N925WB | Aircraft - Fuel - Airplanes (FS/W) | 2 | Feb 18, 2006 03:09 PM |
