Sooooo... Found a soft spot in the tail boom of the D05. A vulnerability in the tail box in a crash landing on the skids. The tail box that wraps around the tail boom literally tore open and shot the tail box and fin right off. I don't have these parts so it's going to be a week or 2 before i can fly it again. Was interesting and i've found my sweet spot for the pitch curve so i'm happy. I'll be working with lighter throttle curves later. The point is to increase the flight time while keeping efficient power output for 3d flight.
Enjoy my pain:
Joined Feb 2008
Terence http://www.chinesejade.com/walkeraV120D05.htm |
Ehirobo is selling the bind and fly D05 for $99. Change the RX to a 2622V, add the 215-T motor and D02s head assembly and main shaft and you've got an awsome heli for around $230. I know this is still more than a new D02s but with a higher torque motor and belt drive that you just can't beat. You won't need Bob's slipper clutch with this baby.
United States, NC, New Bern
Joined Apr 2012
anybody knows if this will work on the v120d05?
http://helircstore.com/shop/index.ph...product_id=166 i was thinking of getting it, but i dont think it is meant to recieve the d05 tail. |
Joined Apr 2012
Here is some pictures of the tail section of my D05 after planting the tail fin in the ground. My best guess is that the heli rolled over but the tail did not want to go with it. The tail section has a factory split in the tail and a screw to tighten it to the boom. Well, it tore on the opposite side of the factory split. All most all the way back too. It even split the tail boom a little and i bent it back out to round to try and salvage the tail boom.. Why?? i donno, they are only like $2. But it gave me something to do.
I have updated the build log for my v120d05 with some experimental improvements on adding durability to the weakened modified main gear from drilling it out for the upgrade to custom "S" rotor head from the D02S. Also another experimental additional mod to the main gear cap to help keep the main shaft secure and to prevent the gear cap's nipple from being worn down, causing play in the main shaft in the first place.
Link to the whole build log: http://www.rcgroups.com/forums/showt...3#post22050845 Link to the post on the main gear durability: http://www.rcgroups.com/forums/showp...45&postcount=8 |
| Thread Tools | |
| Discussion Belt-driven tail FP helis? | APJudson | Beginner Training Area (Heli-Electric) | 47 | Oct 17, 2010 02:22 PM |
| Question Shaft Driven or Belt Driven 4WD? | deathstar | Car Talk | 5 | Dec 04, 2009 05:38 AM |
| Discussion Motor driven tail rotor spin the same as belt driven tail? | BowerR64 | Micro Helis | 4 | Mar 17, 2008 11:53 PM |
