Joined Apr 2007
This may be of help. Taken from http://www.mikrokopter.de/ucwiki/en/MikroKopter-Tool
Update failed? If an update failed or was interrupted during the transfer, the program in the controller is damaged. Sometimes the FC makes a continuous beeping don't panic: the bootloder is still active If a new update is not possible, you can do the following steps: •connect the PCB directly to the MKUSB via the flat cable (don't use wireless link). Note: for BL-Ctrl use the side connection of the MKUSB. •disconnect the Jumper of the MKUSB •Select the file in the KopterTool ans start the update •Now install the Jumper during the dots "..." are displayed •Directly after startup the bootloader in the MikroKopter-Electronic starts for 1/2 second - it now recognises the update-command of the KopterTool and the Update is possible •Try again if this failed - it is a question of timing |
| Thread Tools | |
| Discussion Mikrokopter navi ctrl update? | malcr001 | Video Piloting (FPV/RPV) | 2 | Oct 02, 2010 06:59 PM |
| Discussion Navi ctrl mikrokopter update problem | malcr001 | Multirotor Talk | 0 | Oct 02, 2010 06:44 PM |
| Discussion ET eLogger dead after attempted firmware update? | webdr | Video Piloting (FPV/RPV) | 8 | Feb 23, 2010 06:04 AM |
| Discussion Dead After Update | Xptical | Eagle Tree Systems | 14 | Aug 15, 2008 09:42 AM |
