Old May 09, 2011, 03:43 PM
Brent Slensker is offline
Find More Posts by Brent Slensker
Weni, wedi, Java...
Brent Slensker's Avatar
Casper, Wyoming
Joined Nov 2009
This is the 9 x 7.5 prop I use...HAULS!!!
http://www.hobbyking.com/hobbyking/s...dProduct=10393
Brent Slensker is offline Find More Posts by Brent Slensker
Old May 09, 2011, 04:19 PM
barnyardflyer is offline
Find More Posts by barnyardflyer
Experienced R/C Repairman
barnyardflyer's Avatar
Three Oaks, Michigan
Joined Sep 2003
Looks like some nice props!
Could you send me one of your spares for a sample?
barnyardflyer is offline Find More Posts by barnyardflyer
Old Jul 09, 2011, 10:10 PM
baddognobiscut63 is offline
Find More Posts by baddognobiscut63
Joined May 2011
p-51d
wow 2 months to the day since a post,so i just stopped by to say thanks for all the replys and im happy with mine so i had to get 2 for that price..
baddognobiscut63 is offline Find More Posts by baddognobiscut63
Old Jul 10, 2011, 05:34 PM
SMCLEODVT is offline
Find More Posts by SMCLEODVT
SMCLEODVT's Avatar
United States, VA, Roanoke
Joined Nov 2009
my motor crapped out and any other motor and there is way too much down and right thrust angle - not sure why but it flys horrible now - time to put in the ceiling til next spring and ill think of something
SMCLEODVT is offline Find More Posts by SMCLEODVT
Old Jul 15, 2011, 05:36 PM
Joined May 2011
crapped motor
any idea on your next motor? and just about how much run time on this motor and with what prop? did u get?.
Old Jul 16, 2011, 10:16 AM
SMCLEODVT's Avatar
Joined Nov 2009
no - i tossed in a park 480 and the thrust angle is so rediculous that it looks bad - wont line up with the cowl
it crapped out on me because i bent the shaft on a prop strike and i just kept flying it - not a manuf problem
Old Jul 16, 2011, 01:18 PM
Joined May 2011
I noticed the same angles u discribed in my stock 51.good luck with the new motor, will continue to watch and read more.
Old Jul 18, 2011, 11:28 AM
ricardoz is offline
Find More Posts by ricardoz
Joined Oct 2009
Yesterday was the maiden flight for my new P51D.
I´m from Lima-Perú and my comment for this plane is....
WOWOWOWOWWWWW
Perfectly balance
Really fast
I use it with a Zippy Lipo 3S 2200 30C
I'm planning to change the prop for a 9X6E according to some PropCalculator it could be faster.
Good job TowerHobbies
ricardoz is offline Find More Posts by ricardoz
Old Jul 27, 2011, 01:05 PM
GI Jon is offline
Find More Posts by GI Jon
Joined Jul 2010
Appropriate Prop type
For APC, is the appropriate prop type always the slow flyer, or will a thin electric work better or worse?
GI Jon is offline Find More Posts by GI Jon
Old Oct 05, 2011, 10:29 AM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
The motor in my P-51 failed on the fourth flight. I'll go ahead and replace it along with the ESC. What are people putting in this plane other than the stock motor which is obviously garbage?
fmw is offline Find More Posts by fmw
Old Oct 05, 2011, 12:52 PM
SMCLEODVT's Avatar
Joined Nov 2009
use an Electrifly 10 and a 45a ESC -
Old Oct 06, 2011, 07:38 AM
fmw is offline
fmw
fmw
fmw's Avatar
Joined Jul 2009
Thanks.
Old Oct 13, 2011, 10:30 PM
T3PRanch is offline
Find More Posts by T3PRanch
Team Armattan
United States, TX, Spur
Joined Sep 2011
I have a newb question. I just got my plane today and after putting it together I noticed that when looking from the front of the plane the motor shaft is tilted to the left several degrees from the center-line of the fuselage. Is this to offset motor torque or is it an issue I need to correct before flying it?
From prop tip to the same place on each wing leading edge measures as follows (looking from front of plane)
Prop tip to left wing 7.75"
Prop tip to right wing 8.00"
Thurmond
T3PRanch is offline Find More Posts by T3PRanch
Old Oct 13, 2011, 11:07 PM
lw777pilot is offline
Find More Posts by lw777pilot
Goodyear, AZ.
Joined Dec 2005
Thurmond
as seen from the cockpit looking towards the propeler using this orientation as seen from above the airplane - it is right thrust built-in to compensate for left turning tendencies of the airplane.
I havent assembled mine yet, I do have one sitting for about 3 months now.
As with lots of other models out there.... a lot of them have the right thrust to compensate for the left turning tendencies, some more than others.
hope this helps
lw777pilot is offline Find More Posts by lw777pilot
Old Oct 13, 2011, 11:40 PM
T3PRanch is offline
Team Armattan
Joined Sep 2011
Thanks lw777pilot.
From the cockpit it would produce a right thrust tendency the way it is offset.
That tells me that it is normal and all is well. It sure looks strange though.
Thurmond
Discussion Tower Hobbies P-51 Mustang wileyrc Electric Plane Talk 1274 Jan 24, 2016 05:05 PM
Discussion Tower Hobbies - vs - Horizon Hobbies dlt2859 Hobby Stores 15 Apr 01, 2014 08:37 PM
For Sale Thunder Tiger P-51D Mustang EP OBL duke714 Aircraft - Electric - Airplanes (FS/W) 10 Oct 10, 2010 10:39 PM
