Old Dec 15, 2010, 07:02 PM
sweflyer is offline
Find More Posts by sweflyer
Joined Nov 2007
Question
9 channels ar 6100?
Anyone knows how to modify the ar6100 to get 9 channels?
My foamie needs it!! (radio dsx9)
sweflyer is offline Find More Posts by sweflyer
Old Dec 15, 2010, 08:23 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
What kind of foamy requires 9 channels?If the plane is big enough to use so many channels just get a 9 ch. Rx (the AR6100 is not that good anyway)
opc orn:
coriolan is online now Find More Posts by coriolan
Old Dec 16, 2010, 02:42 AM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
Its not likely to be possible. The 9ch rx's have extra MCU's so the Ar6100 is not likely to have 9ch code in them. The DSX9 only transmits 7ch to the Ar6100 so you would also have to trick that into sending 9.
David.
David T is offline Find More Posts by David T
Old Dec 18, 2010, 12:39 AM
sweflyer is offline
Joined Nov 2007
Thanks!
Plane is a scratchbuilt JAS, as of now ch 5 is retracts, ch 6 is motor forward /reverse
7 would be missile control.
the existing 9 ch is $$$$
so, not possible to re program the 6100? probably would make it the lightest
9ch rec?
Old Dec 18, 2010, 02:00 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
If you only need ON/OFF control then you can put several functions on one channel.
For example, you could set up channel 5 to do both retracts and motor direction. The switches for both functions would be mixed into channel 5 in your tx, giving 4 different servo positions. Then you make a simple decoder which plugs into channel 5 on your rx, detects the 4 positions, and operates the appropriate device like so:-
1.00mS = retracts down, motor reverse
1.25mS = retracts down, motor forward
1.75mS = retracts up, motor forward
2.00mS = retracts up, motor reverse
You may not even need a decoder. Retract servos usually change over at ~1.5mS anyway, and motor control could be done with a servo operating microswitches via a cam (switches operated only at full deflection). If you don't need motor reverse when the retracts are up, nor missiles when they are down, then you might be able to use the following sequence:-
2.00mS = retracts up, motor forward, fire missiles
Now you have a single channel controlling three functions!
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Dec 19, 2010, 02:21 PM
sweflyer is offline
Joined Nov 2007
thats a great suggestion!
retracts use a hacked hxt 500 wormdrive servo where the electronics serve only as brushed esc for the servo motor with microswitches for endpoints definition.
simply putting another servo parrallel with retracts and mixing in radio would probably work for missile control?
yes missiles need only work with gears up, motor fwd/ rev only gears down( to brake and taxi)
thanks!
Sold (2) Spektrum AR 6100 V1.6 only $30 each or $55 for both -= GYRO =- Aircraft - General - Radio Equipment (FS/W) 2 Dec 11, 2010 10:03 AM
Sold new AR 6100 tribute Aircraft - General - Radio Equipment (FS/W) 2 Nov 03, 2010 04:20 PM
Sold Spektrum AR 6100 Receiver $40 bigtruck169 Aircraft - General - Radio Equipment (FS/W) 0 Oct 29, 2010 10:11 AM
Wanted Trade an AR 6300 for a AR 6100 laughingstill Aircraft - General - Radio Equipment (FS/W) 3 Jan 08, 2008 07:22 PM
Sold WTT 2 NIP AR 6100's for 1 AR 7000 jakeg1999 Aircraft - General - Radio Equipment (FS/W) 2 Nov 22, 2007 11:02 AM
