Old Feb 02, 2012, 07:48 PM
Dynoman is offline
Find More Posts by Dynoman
Joined Feb 2012
I'm a new user and have some questions why my rpm isn't reading with my elogger V4. I am using this for a dyno for brushless car motors. I have both the brushless and magnetic sensor and no luck. I am using the power panel. My whole objective was to use the power panel mostly that's why I bought it. Tech support is closed on Thursday?
Dynoman is offline Find More Posts by Dynoman
Old Feb 04, 2012, 12:49 PM
Dynoman is offline
Joined Feb 2012
Anybody out there that can help? Eagle Tree has 2 voicemails, 3 emails and this forum. No response. I am needing to get this up and working so I am asking anybody here who has used this item. I keep hearing about the great technical help that Eagle Tree offers.
Old Feb 04, 2012, 12:57 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Dynoman, sorry to hear about your issue.
Here are a few questions:
1) is it possible the RPM plug is not corrected in the right place? It should be connected to the outermost 3 pin connector on the eLogger.
2) It sounds like the RPM data is not showing up on the LCD for some reason. But, is RPM data logged correctly? Note that you will have to select RPM to be logged in "Hardware, Choose Parameters to log in recorder." for this to work.
3) Have you configured the RPM sensor under "Calibrations/Calibrate Motor RPM?"
4) I don't think this is the problem, but if none of the above helps, can you select the flight profile rather than the car profile, under "Software, Set Model Type" and then configure RPM on the LCD again?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Feb 05, 2012, 03:20 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
All I want is to hook up a GPS and V4 elogger...I will be running 8S and 12S configurations...will I need a back up power source for these compents?? These two compnents should give me battery readings, air-speed, altitude and GPS settings??
ZACATTACK is offline Find More Posts by ZACATTACK
Old Feb 06, 2012, 02:40 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Zacattack, I don't believe you will need the backup for that scenario. However, if you find that logging drops out occasionally, or the pack voltage readings start fluctuating, the backup harness should solve it.
Yes, the GPS will provide you with ground speed (not airspeed) as well as the other parameters you list.
Site Sponsor
Old Feb 09, 2012, 07:10 PM
snorider14 is offline
Find More Posts by snorider14
Joined Feb 2012
Does the eLogger V4 and Airspeed MicrosensorTM V3 support live airspeed readout to the PowerPanel LCD?
snorider14 is offline Find More Posts by snorider14
Old Feb 10, 2012, 07:08 AM
JIM CALDWELLA is offline
Find More Posts by JIM CALDWELLA
United States, OH, Cleveland
Joined Aug 2002
Bill, can you clarify your comment about 8 and 12S above!
If he is getting battery readings eg; volts and amps you don't need back up power. That would mean the logger and GPS can take 48 volts????
Back up harness or log th. with the supplied cable per the V4 instructions??
JIM CALDWELLA is offline Find More Posts by JIM CALDWELLA
Old Feb 16, 2012, 02:38 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Jim,
The eLogger V4 is rated to 80V. The GPS is powered via the eLogger's internal regulator, or with the backup harness, which should connect to a 5V-6V source if needed.
Site Sponsor
Old Feb 17, 2012, 08:40 AM
Joined Aug 2002
Thanks Bill!
Old Feb 23, 2012, 08:50 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Bill,
Is there a way to get the points type kmz file from the elogger? Like this one.
http://www.rcgroups.com/forums/showp...postcount=8227
Steve
Floater73 is offline Find More Posts by Floater73
Old Feb 24, 2012, 12:28 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Steve, I sent that file link to our windows dev to have a look at!
Site Sponsor
Old Feb 24, 2012, 01:12 PM
ZACATTACK's Avatar
Joined May 2011
E-Logger and GPS
I'm new to this e-logger...what I cannot understand is that the e-logger is connected to an 8S system pumping 22.2 v. Why in the world would I need a back-up power source for a scenario like that?? I just dont get it??
Old Feb 24, 2012, 11:27 PM
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
There is a voltage regulator on the elogger that supplies 5v to the Eagletree devices. The elogger V3 regulator can become overloaded and needs the additional input of 5v from the flight system to provide more current. The elogger V4 provides more current and usually doesn't need the back-up power.
Steve
Old Feb 26, 2012, 03:10 AM
Vilniz is offline
Find More Posts by Vilniz
Vilniz's Avatar
Latvija, Ventspils
Joined Apr 2011
Looks like I have some problem with elogger v4. It stopped to work with Usb, still OSD menu and all works, but it does't react when I plug in USB cable, just go straight in recording mode (one flash). Is there any way to reset device through osd menu ? As it looks like stopped work after I try to get used with osd menu from radio and exactly can't say what I turned on or off in menu. Also tried the normal usb cable, same result, computer even don't detect any device at all.
I hope it isn't broke as I have it only for two days.
My only thought is that it stays in some process, which is higher priority than usb connection. Firmware is 1.15.
I'm not novice and have plenty experience with other autopilots and also in electronics.
Edit: osd information now also don't show up, I can use osd menu, but that's all.
Vilniz is offline Find More Posts by Vilniz
Old Feb 27, 2012, 09:58 PM
outkast1779 is offline
Find More Posts by outkast1779
Fret for your pilot...
outkast1779's Avatar
Phoenix
Joined Apr 2006
soooooo...is there any reason the V3 software can't be upgraded to work with the Seagull Telemetry transmitter? The programming can't be that far off. Some of us have multiple V3's who don't want to "start all over." Maybe even charge a small "upgrade fee"?
outkast1779 is offline Find More Posts by outkast1779
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
New Product Announcing the eLogger V3! billpa Eagle Tree Systems 281 Aug 30, 2011 01:20 PM
Cool Announcing the eLogger V3! billpa Product Announcements 21 Nov 06, 2007 11:28 AM
Discussion Announcing the MicroPower V3 eLogger! billpa Power Systems 2 Oct 10, 2007 06:22 PM
