Old Nov 13, 2011, 06:36 AM
dhares is offline
Find More Posts by dhares
Saline, MI
Joined Jul 2006
Using the eLooger V3 directions for altimiter & airspeed sensors works fine, since the connections are the same. The altimeter needs a source of Static Pressure, so it is connected via a "t" to the pitot tube's static port, which does not experience "ram" effects.
dhares is offline Find More Posts by dhares
Old Nov 13, 2011, 11:33 PM
Wise_Man is offline
Find More Posts by Wise_Man
Bolingbrook, IL
Joined Jan 2009
There is still the question of where to connect static pressure tubing on altimeter!
Wise_Man is offline Find More Posts by Wise_Man
Old Nov 14, 2011, 06:20 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
If you look at the installation instructions that came with the altimeter or the online instructions there is a picture of how to connect both tubes. The pressure tube goes to the + port and the static to the - port.Durrr, ALTIMETER.
That configuration is apparently only valid if using the Data Recorder since it appears there is no port on the Stand Alone Altimeter.
Rob
camship is offline Find More Posts by camship
Old Nov 16, 2011, 12:00 AM
StarHopper44 is offline
Find More Posts by StarHopper44
United States, NC, Richlands
Joined Jun 2011
Rob
Another swing&amiss!!
That suggests there's 2 separate modules for StandAlone use and Recorder use. There is only one Altimeter module (not counting firmware versions) and it's used for either setup.
And the point remains - not only is there no visible place to attach a hose in the one picture in its manual, there's also not a single word about hosing nor attaching one in the instructions. Too, no hose in its parts list.
Besides, AFAIK altimeters don't work as suggested by hose hookups anyhow - they work off static barometric pressure (weight of the atmosphere on an internal 'drum') and its accuracy would be affected by anything disturbing the air around it. 'Static' pressure means de facto pressure surrounding the sensor, without any outside influence - hence the warning "If your airframe uses a “ram-air” intake into its cockpit area for cooling or other purposes, the pressure increase can cause a slightly lower reported altitude. To mitigate this, do not expose the Altimeter V4 to direct airflow or place it in a “ram-air” chamber."
I'm happy with the answers I got for my first 2 parts here, but think this question is best left to the expert so, Master Billpa, please???
StarHopper44 is offline Find More Posts by StarHopper44
Old Nov 16, 2011, 05:26 AM
dhares is offline
Saline, MI
Joined Jul 2006
It appears that when ET came out with the altimiter V4, which uses a different sensor to measure presure, they eliminated the pressure port. I'm guessing that's going to prove to be a bad move. I'm a real stickler for measurement accuracy and I also fly electrics. My planes have airflow throughout the fuselage, so the v4 is going to be a step back for me. Back when the airspeed sensors didn't have a static port, I would put them in a perscription pill container inside the plane. I put a hole in the cap for wires and a small brass tube that would attach to a pitot tube's static port, and sealed it all with silicon. That was the only way I could come up with to get good static pressure.
If you're wondering why pitot tubes yeild reliable static pressure, there are several good articles on line if you google pitot tubes. One of my favorites is here: http://www.efunda.com/designstandard...bes_theory.cfm
Old Nov 22, 2011, 04:01 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, in my experience, pressure variations in most cockpits have little effect on the actual altimeter readings. This is not true for airspeed, due to the much greater sensitivity of the sensor.
A way to validate this is to fly level (perhaps on the runway) and look for changes in altitude with the model traveling at different speeds, but at the same elevation.
The improvements in resolution, drift, filtering, and other improvements in the Altimeter V4 will far outweigh the potential error due to cockpit pressure variations IMO. However, if there are cases of the altitude readings varying significantly, it is relatively simple to seal both ends of the V4 with silicon after inserting a rigid tube (something like the ink tube inside of a ballpoint pen) and connecting that to a static source.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 24, 2011, 10:50 AM
michelcote is offline
Find More Posts by michelcote
Joined Jul 2008
Physical packaging
Hi,
I found that Eagletree has the most comprehensive features.
BUT
The fact that the current sensor is on the main board of the elogger is really annoying when you install it for fpv. It is really annoying when wiring because it is relatively big and you have to keep access to usb for downloading.
I would like to see a unit with remote current sensors.
I understant that this way it will need power from the batterie backup cable.
Regards
Michel
michelcote is offline Find More Posts by michelcote
Old Nov 29, 2011, 01:43 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Michel,
Thanks for this feedback! We are investigating some options.
Site Sponsor
Old Dec 06, 2011, 03:34 AM
kalps is offline
Find More Posts by kalps
kalps
i have a question, kindly help. I am very new with FPV. I scored a deal on ebay and got elogger v4, lcd, sensors, gps. Didnt get a OSD Pro, do i requite it?
kalps is offline Find More Posts by kalps
Old Dec 07, 2011, 09:29 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, yes, you also need the OSD Pro board for OSD display (sounds like you've got everything else).
Site Sponsor
Old Dec 11, 2011, 05:23 PM
zkilzz is offline
Find More Posts by zkilzz
Joined Sep 2011
Whats the max wattage the Elogger can handle. Was it 70volts and 100amp? 7000? The one with t connector/deans. V4
zkilzz is offline Find More Posts by zkilzz
Old Jan 06, 2012, 12:56 PM
drcigg is offline
Find More Posts by drcigg
drcigg's Avatar
United States, MN, Chaska
Joined Sep 2011
So if I buy the Elogger I will also need to buy the OSD pro so I can view my heli or plane stats from the ground while its flying high up in the air?
drcigg is offline Find More Posts by drcigg
Old Jan 08, 2012, 10:35 AM
iskoos is offline
Find More Posts by iskoos
Orlando, FL
Well you need to buy the OSD if you would like to view your telemetry data on your video screen (assuming you have a video downlink). But this is generally the case for FPV flying. If you are not doing FPV, then getting an OSP pro is useless because you would still need a way of transmitting that data down somehow. That means a video downlink So if this is the case, you would be looking into getting a Seagull wireless upgrade for your elogger (only for V4 not for V3). Seagull upgrade will downlink your data...
If you don't get any of these options, you can only record your data and view it after your flight...
So in short, elogger logs/stores your data. It has nothing to do with downlinking it. Downlink your data requires different equipment...
iskoos is offline Find More Posts by iskoos
Old Jan 08, 2012, 10:38 AM
drcigg is offline
drcigg's Avatar
Joined Sep 2011
Thank you for the clarification.
Old Jan 22, 2012, 11:19 PM
iskoos is offline
Orlando, FL
V4 Voltage Regulator vs V3 Voltage Regulator
Hi I finally got my elogger V4. There was only one reason why I got the V4 and that was the improved voltage regulator. Of course that was what was said and I didn't get to test it till I got mine. Here is what I found out:
With the elogger V3, the on board voltage regulator started becoming an issue for me when I started adding new sensors to my ET system. I am always running 10s flight packs and higher voltage is no good for the tiny on-board regulator. Previously with V3, things were fine till I added the GPS. GPS sucks lots of juice. With the addition of GPS to my system (elogger V3, OSD pro, V3 Altimeter, temp sensor, LCD power Panel), I had to use backup power (even though my OSD pro was connected to my Rx). Using a backup power (directly from the Rx) is a mess because if you do not power up your equipment in a certain order and within 5 seconds, your voltage calibration will be thrown off by as much as 2-3 volts (based on 10s packs). And furthermore, your backup power must be 5.0 volts. I had hell with it. And most of the time, I was unpluggin the GPS unit just to avoid using the backup power so I could have reliable voltage readings.
Later, I downsized my system and removed the OSD pro and the V3 altimeter sensor. I had only elogger V3, LCD power panel, temp sensor and a GPS. I thought with the removal of OSD and altimeter sensor, I could (maybe) avoid the backup power. I was wrong!.. I still needed a backup power because the problem mostly was the GPS expander not the OSD pro as OSD pro draws its power mostly from the Rx anyways. So I kept using the backup power but soon realized I still had brown outs. Upon doing some more test, I figured out even the backup power wasn't enough to supply my downsized system. So I was unable to run my GPS with a 10s flight pack no matter what I did.
Now what changed with the V4!.. If I want to run my complete system (including the OSD pro and the GPS), everything seems to work w/o the backup power.
On my downsized system (just elogger V4, LCD power panel, GPS and temp sensor), I can reliably run everything w/o the need for the backup power as well. So the voltage regulator is definitley improved. I removed my backup power harness and now have more reliable voltage readings...
If you are using smaller flight packs like 4s or smaller, you may even eliminate wiring your OSD pro to your Rx. This means just the flight pack may power everything...
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
New Product Announcing the eLogger V3! billpa Eagle Tree Systems 281 Aug 30, 2011 01:20 PM
Cool Announcing the eLogger V3! billpa Product Announcements 21 Nov 06, 2007 11:28 AM
Discussion Announcing the MicroPower V3 eLogger! billpa Power Systems 2 Oct 10, 2007 06:22 PM
