Old Aug 24, 2011, 11:11 AM
jack_rogers is offline
Find More Posts by jack_rogers
Joined Aug 2011
Hi Bill,
Do you know if the GPSSpeed data in the log file is "ground speed" (x-y only) or a full 3d velocity estimate (x-y-z).
Thanks.
jack_rogers is offline Find More Posts by jack_rogers
Old Aug 29, 2011, 08:45 AM
alexvan is offline
Find More Posts by alexvan
alexvan's Avatar
Italy, Lazio, Rome
Joined Aug 2011
I recap tow questions I made in other topics because probably this is the most appropriate topic:
1) Can an external battery monitored on the temp1 (temp2 and 3 are connected to the CPD-4)?
2) Can a spektrum receiver be connected to the USB port for signal quality monitoring (the gps port is connected to the gps module)?
Many thanks.
Alessandro
alexvan is offline Find More Posts by alexvan
Old Aug 30, 2011, 01:23 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi,
Presently, an external battery cannot be monitored as described. And,the spektrum receiver cannot be monitored when GPS is used (but we are working on a solution for both of these features).
billpa is offline Find More Posts by billpa
Site Sponsor
Old Aug 31, 2011, 05:25 AM
Julian Amsterdam is offline
Find More Posts by Julian Amsterdam
Joined Oct 2010
Dear,
does anyone have a drawing or photo for the connection of the eagle tree?
I have a mentor (multiplex) with Futaba T12 transmitter
I use the, FY-20A stabilization,
thanks,
julian
Amsterdam
Julian Amsterdam is offline Find More Posts by Julian Amsterdam
Old Sep 03, 2011, 11:39 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Originally Posted by Julian Amsterdam View Post
Dear,
thanks,
julian
Amsterdam
Look here http://www.rcgroups.com/eagle-tree-systems-443/
or here http://www.rcgroups.com/forums/showthread.php?t=1286603
Steve
Floater73 is offline Find More Posts by Floater73
Old Oct 15, 2011, 04:28 PM
starjet is offline
Find More Posts by starjet
Joined Jun 2009
Hi guys, I just wired up my V4 and OSD with Gps..everything appears ok on my goggles but I can't seem to get it to connect with the pc on Windows7. I installed the software ok but when I connect the USB it won't recognise it, the v4 gives 3 flashes and the driver appears to have installed automatically but when I checked device manager it shows E logger V3 with a warning triangle next to it. I clicked the icon and re-installed the driver which windows said is now ok but the "E logger V3" is not there after this is done!
Any ideas?
starjet is offline Find More Posts by starjet
Old Oct 17, 2011, 10:34 PM
Gordon65 is offline
Find More Posts by Gordon65
Australia, SA, Adelaide
Joined Dec 2004
Bill, thinking of upgrading from V3. Does the Acer laptop USB issue still exist or does the V4 resolve it.
Gordon65 is offline Find More Posts by Gordon65
Old Oct 26, 2011, 09:31 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
starjet, that's odd. The 3 blinks on the elogger means that the USB is working correctly (the PC and eLogger are communicating). if you have a very old version of our software (older than version 9.13) the software will not detect the eLogger V4. But, if the eLogger is showing an error in device manager, something else is going on that is at a higher level than the USB interface. Do you have another PC to try?
Gordon, we have few if any problems reported any more with Acer since we switched to the eLogger V4, but I am no sure if that is just a coincidence.
Site Sponsor
Old Oct 30, 2011, 12:19 AM
Wise_Man is offline
Find More Posts by Wise_Man
Bolingbrook, IL
Joined Jan 2009
Is there a way to use the speed control and altimeter sensors together?
Wise_Man is offline Find More Posts by Wise_Man
Old Nov 03, 2011, 02:29 PM
Wise_Man is offline
Bolingbrook, IL
Joined Jan 2009
Come oonnn... anyone?
Old Nov 03, 2011, 07:21 PM
n5iln is offline
Find More Posts by n5iln
United States, CA, Salinas
Joined Nov 2011
If by "speed control" you're referring to the airspeed sensor, yes, they can be used together by daisy-chaining them.
http://www.eagletreesystems.com/Supp...irspeed-v3.pdf
http://www.eagletreesystems.com/Supp...timeter-v4.pdf
n5iln is offline Find More Posts by n5iln
Old Nov 04, 2011, 05:00 PM
Wise_Man is offline
Bolingbrook, IL
Joined Jan 2009
Sorry for the typo, yes I meant speed sensor. Thank you for your reply.
When you daisy chain connect two or more micro-sensors (say altimeter, airspeed, and g-force sensors) how does it record the data? Does the elogger do some kind of data multiplexing? How does it affect the logging rate?
Personally I would prefer more ports for micro-sensors instead of 3 ports allocated to temperature measurement.
Old Nov 04, 2011, 06:04 PM
n5iln is offline
Joined Nov 2011
As far as I know it doesn't affect logging rates. I'm unfamiliar with the internals; you might get more information on that from the Eagle Tree forum. But electrons are fun to play with, and they can do amazing things...
Old Nov 05, 2011, 06:27 AM
dhares is offline
Find More Posts by dhares
Saline, MI
Joined Jul 2006
The data logger usses what is esentially an I2C data bus to connect it's sensors. If you look at the specs, it's very robust and very fast. It supports many more expansion modules than are currently available, all at the V4's rated speed. The microprocessor on the V4 has only one bus, hence one "expansion" port. The temp and servo inputs are essentially direct to the microprocessor too.
dhares is offline Find More Posts by dhares
Old Nov 13, 2011, 12:04 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
I have the ET V4 Logger; & intend to get the Airspeed Sensor module, but highest version I've found is the V3. Is that indeed the latest, or is there a V4 Airspeed either out or imminent?
Another small concern - the User Manual (at ET's website) for the V3 Airspeed shows connection to V1/V2 loggers, as well as the V3 logger -- but doesn't show connection to (nor is there any other mention of) the V4 logger. Does it connect the same as to the V3 logger?
Would suggest this omission be updated on the PDF doc.
And finally, the dealer I'm ordering from offers a small optional 'T'-barb fitting for "...sharing the static source of the pitot tube with both altimeter and airspeed static inputs". This suggests the altimeter sensor needs pitot input. (?!) But if the altimeter is negatively affected by 'cabin' pressure from a ram air cooling system (as its manual states), I'm a li'l confused as to how/why sharing the 'ram' from a pitot tube would be a beneficial thing or a wise choice. Also noting no silicon tubing seen as part of the Altimeter packaging - hopefully my confusion is understandable?
Enlightenment, please?
StarHopper44 is offline Find More Posts by StarHopper44
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
New Product Announcing the eLogger V3! billpa Eagle Tree Systems 281 Aug 30, 2011 01:20 PM
Cool Announcing the eLogger V3! billpa Product Announcements 21 Nov 06, 2007 11:28 AM
Discussion Announcing the MicroPower V3 eLogger! billpa Power Systems 2 Oct 10, 2007 06:22 PM
