Old May 17, 2011, 04:38 PM
dynamicman is offline
Find More Posts by dynamicman
dynamicman's Avatar
Türkiye, Ankara, Ankara
Joined Jan 2007
Dear Bill,
I would like to see my receiver battery voltage but I have used all tmp inputs. (temp 2-3 for CPD4 stabilisation sensors cables and tmp 1 for RSSI).
Can I connect and use any centre pins of tmps for second battery voltage in the same time with other inputs?
Thanks.
Hakan
(My system; OSD Pro, Elogger 4, Thomas LRS, CPD 4 stab. sensors. with out co-pilot.)
dynamicman is offline Find More Posts by dynamicman
Old May 18, 2011, 01:24 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Floater, great idea. I've sent this to our windows developer to implement on the firmware control page.
dynamicman, this isn't possible now with the eLogger setup, but will soon be when we release the "FPV Expander" add-on, which has separate inputs for multiple voltage sources.
billpa is offline Find More Posts by billpa
Site Sponsor
Old May 19, 2011, 10:01 AM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Thanks.
Also, the new eLogger V4 works great. The EagleTree support was quick and helpful. (Even when I'm the one that fried the old one!)
Floater73 is offline Find More Posts by Floater73
Old Jun 07, 2011, 06:47 AM
pierre_mousel is offline
Find More Posts by pierre_mousel
Luxembourg, Luxembourg, Dudelange
Joined Aug 2006
High current sensor
Will the 300A sensor work with the V4 logger ??
pierre_mousel is offline Find More Posts by pierre_mousel
Old Jun 07, 2011, 12:09 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
No, the 300 amp sensor is for our data recorder products only.
Site Sponsor
Old Jun 07, 2011, 12:40 PM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
GPS on board battery
GPS 10,00MHZ no longer works, the small battery on the PCB shows .57 volts.
I think I need a new battery, what volt and size should I get??
I guess we should NOT leave the GPS plugged in to the V4 when not in use???
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Jun 07, 2011, 12:59 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Jim, the battery should be charging when the GPS is connected to the eLogger/recorder. It's just there to provide backup, which can decrease fix time. But, the GPS should still work without it.
Site Sponsor
Old Jul 08, 2011, 01:09 PM
jimctr is offline
Find More Posts by jimctr
Joined Jul 2011
Electrical Specifications
I clicked on the link for specifications of the eLogger V4 and it took me to a page which talked about product features. Where can I find specifications (voltage, max current, etc) for this product? Thanks
jimctr is offline Find More Posts by jimctr
Old Jul 08, 2011, 01:29 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Jim,
The specifications are at the back of the user manual, located here.
Site Sponsor
Old Jul 09, 2011, 06:09 AM
jmaurin is offline
Find More Posts by jmaurin
Joined Mar 2007
How can i invert throttle display on pc-software? In my ESC with futaba radio, i need to reverse the servo direction do work right....and in software, i can see the throttle, but inverted, from 20 [idle] to 0 [100%].
jmaurin is offline Find More Posts by jmaurin
Old Jul 15, 2011, 12:18 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, when you calibrate the throttle ("Calibration, calibrate throttle" in the software) it should automatically handle this for you.
Site Sponsor
Old Jul 22, 2011, 01:37 AM
iskoos is offline
Find More Posts by iskoos
Orlando, FL
Hi there,
Could any elogger V4 user confirm if this unit's built-in voltage regulator can handle GPS, OSD pro and one or more other major sensors (like the baro altimeter sensor) at the same time without brown outs?
I currently have elogger v3 and cannot use GPS and the OSD pro at the same time without using a backup power. I will get this new v4 if the voltage regulator can feed all major sensros at the same time without the need of any backup power.
iskoos is offline Find More Posts by iskoos
Old Jul 22, 2011, 03:13 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi iskoos,
Yes, that should be fine with a 4S pack or less.
Site Sponsor
Old Jul 23, 2011, 02:00 PM
iskoos is offline
Orlando, FL
Hi iskoos,
Hi Bill, I have 10s packs
So does that mean I would still need a packup power even with elogger V4?
Old Aug 01, 2011, 05:44 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Yes, definitely will require backup power at 10s if using the GPS + other sensors. Sorry about that!
Site Sponsor
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
New Product Announcing the eLogger V3! billpa Eagle Tree Systems 281 Aug 30, 2011 01:20 PM
Cool Announcing the eLogger V3! billpa Product Announcements 21 Nov 06, 2007 11:28 AM
Discussion Announcing the MicroPower V3 eLogger! billpa Power Systems 2 Oct 10, 2007 06:22 PM
