Old Dec 16, 2010, 10:34 PM
iskoos is offline
Find More Posts by iskoos
Orlando, FL
Yeah I agree 50Hz is overkill but we can always set it lower than that.
On V4, all I care is the new built-in regulator and maybe an extended memory. I don't care about the logging rate.
iskoos is offline Find More Posts by iskoos
Old Dec 17, 2010, 12:31 AM
wiper1974 is offline
Find More Posts by wiper1974
Croatia
Joined Dec 2010
Re dealer availability, shipments are to begin early next week. Not sure if this timing was a particular stroke of genius. Products seem to ship when they want to, despite our best efforts to coax them along.[/QUOTE]
Billpa ,
Since I paid the amount in the HOBBYKING for eLogger V3 but does not have them in stock, is the next shipment to HOBBYKING will be V4 version?
wiper1974 is offline Find More Posts by wiper1974
Old Dec 17, 2010, 07:18 AM
garris2 is offline
Find More Posts by garris2
Australia, VIC, Glen Waverley
Originally Posted by Syberian View Post
Oh, that 50Hz logging rate is an overkill. For the FPV needs it`ll be better to split the capture rate of elogger and OSD Pro (i.e. write to the log at 0.1-1Hz and pass the data to the OSD Pro at the same 10Hz).
But don't forget the eLogger can be used for many things besides FPV.
Say you wanted to measure the power of an RC Internal combustion engine....
Those that desire to do so can build a fly wheel of known dimension and mass (density of material).
Using the optical RPM sensor measure at a high sample rate, the rate of acceleration of the fly wheel, while accelerating the engine as quickly as possible. Then knowing the timing, using maths you can calculate the power and torque of the engine.
The eLogger is much much more versitile than just FPV and with 50Hz logging it really opens up the horizons to see what is going on at high speed or in great detail.
It really is a great step forward.
Geoff
garris2 is offline Find More Posts by garris2
Old Dec 17, 2010, 08:49 AM
tychoc is offline
Find More Posts by tychoc
tychoc's Avatar
Austin, TX
Joined Feb 2006
Looks great billpa! I've been very busy with work and house projects this year, but I will upgrade to v4 for sure. I'm getting ready to dust off my planes again. I've even decided to finish the UltraSport 60 kit I started two years ago, although that will not be a FPV platform!
-tychoc
tychoc is offline Find More Posts by tychoc
Old Dec 21, 2010, 08:33 PM
iskoos is offline
Orlando, FL
Well, I am still waiting for the upgrade options for V3 owners.
Old Dec 21, 2010, 10:26 PM
crusey_aus is offline
Find More Posts by crusey_aus
Melbourne
Joined Aug 2010
Me too
I have a brand new V3 unopened that I will happily trade up if that is an option
Purchased it a few days before the V4 was announced
Cheers
crusey_aus is offline Find More Posts by crusey_aus
Old Dec 22, 2010, 05:07 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Originally Posted by billpa View Post
• High speed logging at up to 50Hz (increased from 10Hz).
So now Live mode logging fills the hard drive five times faster?
Fred
flarssen is online now Find More Posts by flarssen
Old Dec 22, 2010, 07:01 AM
garris2 is offline
Fred
Only if you set the logging rate to 50Hz. You can still use the 10Hz rate if you want. There's no pleasing some people is there.
If space is a problem set it to 1Hz, you probly used more space downloading this website to make your post than what you'll get from a full memory logging session.
Buy a bigger hard drive, they're very cheap these days $ / Megabyte. You can get 1TB for less than the cost of a new elogger V4.
Old Dec 22, 2010, 09:02 AM
Son, Norway
Joined Sep 2004
Last time I tried live logging it wrote a record in the file for every single sample, containing every possible parameter. If it is fixed, I'm very pleased indeed!
Space was not the main concern. It was more what happens when a 5-6MB file is loaded into the software for analysis.
Fred
Old Dec 23, 2010, 05:47 AM
dhares is offline
Find More Posts by dhares
Saline, MI
Joined Jul 2006
It always writes a file containing every sample for every parameter. Even standard logging does this. What was the problem?
dhares is offline Find More Posts by dhares
Old Dec 23, 2010, 02:53 PM
Son, Norway
Joined Sep 2004
Rate is settable for standard logging. Here is one second live recording (1.2kB). Unless it's fixed, it could be five times more with V4:
Milliseconds IsEvent EventError EventData Altitude Airspeed ServoCurrent*100 Throttle PackVolt*100 Amps*100 Temp1*10 Temp2*10 Temp3*10 RPM RPM2 GPSLat GPSLon GPSAlt GPSSpeed GPSCourse GPSDist GPSUTC NumSats GPSFlags SpektrumHolds SpektrumLostFrames SpektrumAFades SpektrumBFades SpektrumLeftFades SpektrumRightFades GPSUTC-ASCII HDOP*10
0 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
100 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
200 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
300 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
400 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
500 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
600 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
700 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
800 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
900 0 0 0 0 0 0 0 0 0 83 12 435 0 0 0.000000000000 0.000000000000 0.0 0.0 0.0 0.0 0.0000 0 0 0 0 0 0 0 0 10/18/2009,01:00:00.89 0
Old Dec 24, 2010, 12:42 AM
dhares is offline
Saline, MI
Joined Jul 2006
You are getting 10 samples a second recorded. That's what it is supposed to do. You cannot drop a set of readings just because they are the same as the one before it. I'm not seeing the problem. The EagleTree app and Excel read the file in very quickly.
Old Dec 30, 2010, 05:35 PM
alexf1852 is offline
Find More Posts by alexf1852
alexf1852's Avatar
United States, FL, Inverness
Joined Jan 2010
So will there be some kind of trade-in program for V3 owners? Or some kind of discount?
Do the new V2 brushless motor sensors work with the V3 data logger? Is there any benefit when pairing such?
alexf1852 is offline Find More Posts by alexf1852
Old Dec 31, 2010, 02:04 AM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
alex, there's not a trade-in program, but right now we have a 10% rebate for qualifying purchases - details here.
Yes, all presently shipping eLogger V3 sensors are V4 compatible (only ones that are not are the altimeter/airspeed V1 I believe).
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jan 02, 2011, 01:31 AM
iskoos is offline
Orlando, FL
That 10% discount applies to anyone it seems; plus $100 minimum order is required.
As a supersaver club member, I can get a better discount than that thru Tower Hobbies...
Sorry Bill but I was expecting a little better from you guys. And I believe you were the one announcing the upgrade option.
Going for V4 is not very logical for me at this stage. I prefer waiting. Let's see how the new V4 will perfrom.
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
New Product Announcing the eLogger V3! billpa Eagle Tree Systems 281 Aug 30, 2011 01:20 PM
Cool Announcing the eLogger V3! billpa Product Announcements 21 Nov 06, 2007 11:28 AM
Discussion Announcing the MicroPower V3 eLogger! billpa Power Systems 2 Oct 10, 2007 06:22 PM
