Old Sep 05, 2012, 07:06 AM
Jim Blanchfield is offline
Find More Posts by Jim Blanchfield
McLean, VA
Joined Dec 2001
Brushed Motor Fwd and Rev Question
First time Eagtree user with V4
Searching forum returned no results, so hopefully one of you can help.
I want to install the logger in a boat that has a brushed motor and an ESC that allows forward and reverse. The V4 instructions specify the motor side red wire should connect to the positive pole on the motor. That pole becomes negative in reverse direction.
How will the V4 react? I am just logging VOLTS, AMPS, and MAH values. Will I get absolute totals or subtractions.......or a puff of smoke?
The boat has a car type motor and runs on a 2S-4900 mah Lipo.
Thanks for any advice or warnings!
Jim
Jim Blanchfield is offline Find More Posts by Jim Blanchfield
Old Sep 05, 2012, 03:26 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
HI Jim,
The eLogger should connect between your battery and your ESC, not between your ESC and your motor.
I searched the manual for the word "motor" and didn't find anything re connecting the red wire to the motor side. Could you let me know where in the manual you are seeing that? We need to correct if it it's there.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Sep 05, 2012, 04:51 PM
McLean, VA
Joined Dec 2001
billpa,
Thank you for the prompt reply.
I did not read the instructions as carefully as I should have.
On page 2, last paragraph......."The red wires of the 'wire lead' version of the eLogger must be connected to the positive side of the load and source (normally the red wires). For measuring current and voltage during battery charging, it is ok to connect a charger to the ES connection, so that current is flowing 'backwards' through the eLogger. The eLogger will still measure current correctly in this mode!"
I mistakenly mistook "load" to mean the motor. The subsequent mention of current flowing "backwards" through the eLogger being ok made me wonder whether the mah would be subtracted from a prior total, and whether volts and amps would be graphed as negative values.
After seeing your reply, its now clear that with the eLogger between the ESC and battery, current will be flowing only in one direction, regardless of the motor's rotational direction.
I do have Sermos connectors between the ESC and the motor and between the ESC and the battery. But it would have been an error if I had put the eLogger between the ESC and the motor.
Thanks for the great customer support. Sorry about raising a silly question.
Jim
PS....is the "ES connection" in line 3 of my quote supposed to be "ESC connection"
Old Sep 08, 2012, 11:29 PM
junioro16v is offline
Find More Posts by junioro16v
junioro16v's Avatar
Brazil, PR, Curitiba
Joined Mar 2009
Originally Posted by Floater73 View Post
Bill,
Is there a way to get the points type kmz file from the elogger? Like this one.
http://www.rcgroups.com/forums/showp...postcount=8227
Steve
Bill,
Any news on that or something similar to this?
junioro16v is offline Find More Posts by junioro16v
Old Sep 12, 2012, 08:46 AM
junioro16v's Avatar
Joined Mar 2009
Originally Posted by junioro16v View Post
Bill,
Still waiting for any answer.
Old Sep 14, 2012, 10:26 AM
junioro16v's Avatar
Joined Mar 2009
Well, well.
Good support here Bill.
Old Sep 14, 2012, 01:38 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, sorry, I missed your post when I was last here.
I like the look of the points - had not seen that before. It's something we can look into doing. Any other interest?
Site Sponsor
Old Sep 14, 2012, 03:59 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
I would like it.
Steve
Floater73 is offline Find More Posts by Floater73
Old Sep 14, 2012, 04:37 PM
junioro16v's Avatar
Joined Mar 2009
I would like it.
Steve
Anything like this or close to this is very good. I think this way you can see more clearly the track. High altitudes with red colors or anything like this.
Old Oct 15, 2012, 10:59 AM
junioro16v's Avatar
Joined Mar 2009
Bill,
Any news on that request?
Old Oct 16, 2012, 02:12 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi Junior,
This is on our list of things to dig into. The developer here who does this is on another project, but I hope we'll be able to dig into it soon.
Site Sponsor
Old Dec 03, 2012, 08:50 PM
Sit-N-Fly is offline
Find More Posts by Sit-N-Fly
Joined May 2004
I'm considering one of these on a 10S 3000W system. With all the chatter about avoiding long battery leads, does the V4 introduce enough inductance that I should worry about my ESC? Do the Hall sensors take all my problems away......
Sit-N-Fly is offline Find More Posts by Sit-N-Fly
Old Dec 12, 2012, 02:22 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, I would be surprised if the eLogger introduced enough inductance to cause you any issues. The resistance through the hall sensor itself is approximately 0.0001 ohm, if that helps.
Site Sponsor
Old Dec 17, 2012, 06:44 PM
junioro16v's Avatar
Joined Mar 2009
Any news?
http://www.rcgroups.com/forums/showp...&postcount=154
Old Dec 18, 2012, 01:33 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, we have that feature on our UI request list, but have not gotten to it yet.
Site Sponsor
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
New Product Announcing the eLogger V3! billpa Eagle Tree Systems 281 Aug 30, 2011 01:20 PM
Cool Announcing the eLogger V3! billpa Product Announcements 21 Nov 06, 2007 11:28 AM
Discussion Announcing the MicroPower V3 eLogger! billpa Power Systems 2 Oct 10, 2007 06:22 PM
