announcing the eLogger V4!
After listening to your valuable feedback, Eagle Tree is excited to announce the eLogger V4.
![]() The eLogger V4 has several new logging features you've requested, while retaining all the great features of our renowned eLogger V3: • High speed logging at up to 50Hz (increased from 10Hz). • Sixteen times the logging capacity of the standard eLogger V3. Typically logs all available sensors for about four hours, at 10Hz. • Voltage logging increased to 80 volts maximum. • The eLogger V4's on-board voltage regulator has much improved capability. More accessories can be used at higher voltages, without requiring the battery backup harness to be used. For our OSD customers, typical configurations should never require the backup harness with the eLogger V4. • A USB "mini" connector is built into the eLogger V4. • All the 3-pin sensor connections are now polarized, and the connectors are now shrouded, helping protect them from physical damage or short circuits. • Includes Y cable for throttle logging, which also provides battery backup if needed. And best of all, the price is the same as the eLogger V3! ![]() Available with built in DeansTM connectors or wire leads. See your favorite Hobby dealer or click here for more information! |
Great. |
| Thread Tools | |
| Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro | jbfoamy | Eagle Tree Systems | 23 | Jun 02, 2012 02:59 PM |
| New Product Announcing the eLogger V3! | billpa | Eagle Tree Systems | 281 | Aug 30, 2011 01:20 PM |
| Cool Announcing the eLogger V3! | billpa | Product Announcements | 21 | Nov 06, 2007 11:28 AM |
| Discussion Announcing the MicroPower V3 eLogger! | billpa | Power Systems | 2 | Oct 10, 2007 06:22 PM |
