This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Jun 09, 2011, 01:38 PM
OmarRG is offline
Find More Posts by OmarRG
Mexico, MEX, Metepec
Joined Jun 2011
BEV 5.8GHz AV TX/RX Set
Hello, I have this FPV System but I cannot make it work!
Can you please help me?
Thanks!
OmarRG is offline Find More Posts by OmarRG
Old Jun 09, 2011, 05:27 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
Originally Posted by Coyote64 View Post
Avoid channel 4 for the harmonics and you will be fine, seperate video channels by 100mhz
I am non-techo, but I am curious- would I be better off having some kind of filter thing on the Tx or Rx to close in on a given frequency so it isn't so broad?
I remember reading somewhere there is something that can be replaced to narrow the freq band... that is if I understood it correctly in the first place
I know when flying with other guys, all on 5.8, there's an amount of cross banding on different channels... unless we should be setting up our GS's further away from each other...
AussieHoppy is online now Find More Posts by AussieHoppy
Old Jun 09, 2011, 09:15 PM
kcleong18 is offline
Find More Posts by kcleong18
KL,Malaysia
Joined Jun 2008
Thanks!
Looking at your wiring and this http://www.bevrc.com/bev-58g-200mw-p...-fpv-p-18.html , it looks like your receiver ( if you have the same type) is not getting enough juice - - Working voltage: DC 9- 13 volts- Current consumption: 120mAh.
And using dry cells would be expensive
Kc
kcleong18 is offline Find More Posts by kcleong18
Old Jun 09, 2011, 09:43 PM
Ecibob is offline
Find More Posts by Ecibob
B to the O to the B
Ecibob's Avatar
United States, TN, Nashville
Joined Jun 2009
Is there any real advantage to using a CCTV camera like the ones that are standard definition (DX-201, etc.) or an HD camera.
I see you can get these keychain cams for like $100... seems pretty reasonable and would be a new world over the others.
Is that true, are HD cams advantageous in practically every way?
Could I use it with a standard lawmate or other TX and RX?
Ecibob is offline Find More Posts by Ecibob
Old Jun 09, 2011, 09:49 PM
OmarRG is offline
Joined Jun 2011
Thank you KCLeong18. I will change the power supply. I used this batt because I am still testing the system in my working table. Once on the plane I will use another one!. I will try tomorrow with more power and let you know the results!
Old Jun 10, 2011, 10:06 AM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
Very brief question - Of the FM frequencies (for RC control), does 72 MHz for offer the best combination of range and available receivers? I expect 35, 40, or 50 MHz would give better range, but it seems harder to find receivers and crystals.
TexasAggie is offline Find More Posts by TexasAggie
Old Jun 10, 2011, 03:59 PM
isaacintheclouds is offline
Find More Posts by isaacintheclouds
Nevermind...
isaacintheclouds's Avatar
United States, CA, Carnelian Bay
Joined May 2011
Had a successful first flight today viewing through a t.v. All went well thanks to all the good advice I got here. My VTX battery is a little heavy though, a 3s 910 mah. lipo. Someone here said it would be good for an hour or so. Since I dont need that long yet,could I lose a little weight with a 450mah battery or even less and still get 25 or 30 minutes with it? Thanks all!
isaacintheclouds is offline Find More Posts by isaacintheclouds
Old Jun 10, 2011, 07:10 PM
nakelp86 is online now
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Need some help,
I tried three different microphones and everyone of them causes severe interference while working
Toroids do not help, dont know what to do anymore, any suggestion maybe for better microphone?
nakelp86 is online now Find More Posts by nakelp86
Old Jun 11, 2011, 11:42 AM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
Originally Posted by QiW View Post
quick question ...
i am flying with futaba 2.4rc and currently using 900mhz video
i just acquired another video tx rx with the following frequencies ... which one will best suit my futaba 2.4rc without too much damage in the secondary harmonics ??
1 1080MHZ
2 1120MHZ
3 1160MHZ
4 1200MHZ
thanks
I would guess that 1080 would be the best and 1200 the worst. As always, please use frequencies that are legal in your country if only to avoid interference to yourself and other users of the frequency.
I recall that 900mhz may be cell phone frequencies outside the USA.
Cliff
theothercliff is offline Find More Posts by theothercliff
Old Jun 11, 2011, 11:53 AM
Temple, GA, USA
Joined Jun 2009
another quick question
how far apart does the video frequencies have to be in order not to interfere with each other (assuming range between 900mhz to 1.2ghz) ?
planning on flying FPV together ...
Standard FPV links have an audio sub-carrier on 5.5mhz or 6.5mhz. Figure that the video is using as much as 3.5mhz in the center of the channel and you get a deviation of +-10mhz for a bandwidth of 20mhz; so that is the bare minimum.
The width of the IF in the receiver is generally a little wider than 20mhz (think of it as +- 10mhz), so you can get interference from a transmitter that is only 20mhz away that is transmitting +-10mhz.
Most FPV links have at least a 40mhz channel separation to avoid the possibility of cross channel interference. Some receivers will lock on to an adjacent channel if the signal is strong, but loose lock at any flight distance or if the correct channel is broadcasting.
I hear reports of adjacent channels on 5.8g bleeding through. To be honest I have little experience with multiple FPV links flying at the same time.
Cliff
Old Jun 11, 2011, 12:05 PM
Temple, GA, USA
Joined Jun 2009
Filters on the transmitter are really only good for reducing harmonics, e.g. reducing the 2560 from a 1280 transmitter.
The IF filter in 910 and 1280 receivers can be replaced. The stock one is something like 22.5mhz and the replacement one is something like 17.5mhz. The major effect of this is to reduce noise and increase range, although it would help keep adjacent transmitters out too.
Cliff
Old Jun 11, 2011, 12:13 PM
Nakelp
nakelp86's Avatar
Joined Sep 2004
Originally Posted by nakelp86 View Post
Need some help,
Anyone pls?
Old Jun 11, 2011, 01:12 PM
Jamiem is offline
Find More Posts by Jamiem
United Kingdom, England, Ashford
Joined Jan 2011
I've just had my first ever FPV experience, and it hasn't gone particularly well. Im running a KK quad copter, a Markus Zingg vTX with his SPW and clover leaf antennas. It's a 5.8ghz system, 2.4ghz radio, and I managed about 20 feet range before the video signal was unworkable. I've connected the power through the easyOSD current sensor only, and this powers the vTX, EOSD and sony CCD Cam. I understand that ferrite rings may help reduce interference, but where, and how?
I'm going to go and try over again but with the OSD removed from the system.
Jamiem is offline Find More Posts by Jamiem
Old Jun 12, 2011, 08:43 AM
Temple, GA, USA
Joined Jun 2009
Do not adjust your FPV transmitter.
Need some help,
What FPV sender/receiver do you have? Have you adjusted it in any way? These systems require amplified audio that puts out standard "line level" audio of about .5 to 1.0 volts.
One of the first FPV systems that I bought was from r2hobbies and although it has a place for audio and comes with audio cables, the text of the ad does not mention audio and the audio does not work. Taking the transmitter apart, there are components missing in the audio section.
Do not adjust your FPV transmitter. Experimentation is tempting, but you will only do it more harm than good. Too much one way and both your bandwidth and harmonics go up past the limit. Too much the other way and your sync level and intensity may become unusable. Also, adjustments to the transmitter should be complimented with opposite adjustments to the receiver.
Cliff
Old Jun 12, 2011, 08:51 AM
Temple, GA, USA
Joined Jun 2009
You should get more than that for range.
Did you know that you must run CP antennas on both Tx and Rx.
Does this copter have significant metal or CF structures that might block the signal? Generally, you must always be able to see the transmitter antenna from the receiver antenna. Is the aircraft rotated so that the aircraft blocks the signal?
Do you know what the antennas should look like and do they look like that? They should be very symmetric with loops poking up at like 45 and 45 degrees (don't know exact numbers) each.
I would put the stock antennas back on for a test, and test it off the aircraft. 5.8ghz is the worst for line of sight and multi-path, but you should get at least several hundred feet.
I would PM Markus and ask for help.
Cliff
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 10:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
