This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Feb 16, 2013, 12:14 PM
crashsalot is offline
Find More Posts by crashsalot
United States, CA, Thousand Oaks
Joined Feb 2013
Originally Posted by guaglione87 View Post
Found my pride and joy about 3/4 mile away in a field where the cows graze. The cows had a field day with my plane. They stomped every square inch of the plane, leaving me with nothing, absolutely nothing salvageable. I figure around $500.
In fact not only did the stomp the plane, but buried some parts. We found servo leads, only to pull on them to unearth the servos. The motor was found 20 foot from the wreck. Destroyed.
I looked straight at the cows and let em know that I was gonna have a big juicy steak for dinner and hamburger for lunch tomorrow...
FML
Michael
I'll have a burger in memory of your plane tonight. Sorry for you loss. Won't happen in California, though, all happy cows.....
crashsalot is offline Find More Posts by crashsalot
Old Feb 16, 2013, 12:31 PM
Yabba is offline
Find More Posts by Yabba
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
That'll teach you
Yabba is offline Find More Posts by Yabba
Old Feb 16, 2013, 06:28 PM
Thothtp is offline
Find More Posts by Thothtp
Joined Feb 2010
Originally Posted by IBCrazy View Post
Watch the "Hooking it up" video at the first post of this thread. It is video #7. You will see no cables are required, just some soldering skills.
-Alex
Somehow I missed that one before, thanks again. Pretty simple.
Alex, is there a reason you recommend 900mhz over 1.3ghz? As a reminder I am looking for 1500 feet probably at the most, but likely behind trees and small buildings mostly doing low nap of the earth flying, on a quadcopter with about 8 inches of separation between TX and RX..
I know 900mhz will penetrate a bit better, but 1.3ghz misses the cell phone bands. I live in a rural residential town, but am about 10-15 miles from an urban center. We have mostly CDMA and 4G cell towers around here, but I am sure there is 900mhz as well.
900mhz was what I was originally thinking, but I keep reading that 1.3ghz has the cleanest air in the USA. What do you think?
Thothtp is offline Find More Posts by Thothtp
Old Feb 16, 2013, 06:30 PM
guaglione87 is offline
Find More Posts by guaglione87
Team Armattan
guaglione87's Avatar
United States, TX, Mansfield
Joined Apr 2012
Yes sir, Nolan Ryan grass fed steak tonight!
Think im gonna go with the SkyWalker 1900 for my next bird...
Note the SSS in the bottom left. RIP
guaglione87 is offline Find More Posts by guaglione87
Old Feb 16, 2013, 09:41 PM
Wettfeat is offline
Find More Posts by Wettfeat
"FPV"er not a "LOS"er
Wettfeat's Avatar
United States, NC, Charlotte
Joined Feb 2012
So, crappy question to have to ask but - what is yall's success rate with having people return lost planes? I have my address name and phone number on the plane in 2 or 3 spots, along with a "reward upon return" on the label.
Well first of all the chances of you crashing it on the ground where someone would run upon it is very slim. Even smack in the middle of the city where I live there are plenty of trees and wooded areas.
Wettfeat is offline Find More Posts by Wettfeat
Old Feb 17, 2013, 01:15 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
2.4Ghz control and 1.3GHz video are not friends. 900MHz video is the safer bet, especially for the short distances you intend to fly.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 17, 2013, 07:02 PM
WNCmotard is offline
Find More Posts by WNCmotard
Has an RC Problem
WNCmotard's Avatar
United States, NC, Franklin
Joined Mar 2010
If you live in the US, there is no 900mhz cellular use. It's 700-900, then 1400 on up.
WNCmotard is offline Find More Posts by WNCmotard
Old Feb 17, 2013, 10:49 PM
ucandoit is offline
Find More Posts by ucandoit
ucandoit's Avatar
United States, CO, Grand Junction
Joined Oct 2005
Reciver Antenna
Alex
Hey I know you have used the corona RP8D1 receiver and I going to try one being I just getting into FPV then move into a Dragonlink later.My Question is can I run the Antenna along the outside bottom of my Penguin airframe as long as I keep it as strait as possible? I seen your video on how you keep it on the wing but I will be removing the wings and it would be easer to run the Antenna down the back bone of the Penguin. Or should I go ahead and pull the trigger and get a Dragonlink and skip the 72mh I will be using a 9 Cap if that matters. Thanks Scott K
ucandoit is offline Find More Posts by ucandoit
Old Feb 18, 2013, 01:56 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
This is true, but the receivers we use receive below 900Mhz and thus some of the G3 band causes interference because of the width of the receiver filter.
-Alex
Old Feb 18, 2013, 01:57 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by ucandoit View Post
Alex
It's your call, but I would still run it out the wing. Maybe make it so only 1 wnig detaches? Remember that running it out the tail exposes the antenna null.
-Alex
Old Feb 18, 2013, 02:44 PM
Has an RC Problem
WNCmotard's Avatar
Joined Mar 2010
-Alex
Great, more stuff to screw up my video frequency search. Luckily, I live in a very rural area, so not a ton of cell towers here to walk on my signal.
Old Feb 18, 2013, 02:51 PM
harrym is offline
Find More Posts by harrym
HeliHarry
harrym's Avatar
United States, OK, Tulsa
Joined Dec 2006
This is true, but the receivers we use receive below 900Mhz and thus some of the G3 band causes interference because of the width of the receiver filter.-Alex
Is this true even with the receivers with the D480A SAW Filters?
harrym is offline Find More Posts by harrym
Old Feb 18, 2013, 03:32 PM
syzygyQ is offline
Find More Posts by syzygyQ
Joined Oct 2011
Reality Check: 2.4ghz Spektrum Booster
3D Robotics, at DIY Drones, describe this 2.4ghz Spektrum TX booster project.
It's an inexpensive and fairly simple project that offers 4km range without a patch, and with a patch antenna presumably somewhat further.
Have you assembled this kit? How did it do? What range have you achieved? Glitchy? Loss of aircraft? Would you recommend it as an improvement to pilots who insist on using Spektrum 2.4ghz TX / RX pairs?
Thanks!
syzygyQ is offline Find More Posts by syzygyQ
Old Feb 18, 2013, 04:38 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
Thanks!
works great, i've done it to my dx8, been working fine for 18 months, flew out to 4km on it yesterday no problems. I'm not using a patch either.
The only thing you have to do is properly attenuate the link from the tx to the booster, otherwise you'll burnout the booster.
CrashAffinity is offline Find More Posts by CrashAffinity
Old Feb 18, 2013, 04:54 PM
syzygyQ is offline
Joined Oct 2011
Good news about the capability of the setup.
How do I attenuate the link from the tx to the booster though? This is new to me -- I don't understand...
Would you please explain / point me in a good direction to learn more?
Thanks!
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
