This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Feb 05, 2013, 02:29 AM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
Originally Posted by williamjames View Post
Anyone know what the power consumption is on this Rx?
Alex, can you please advise regarding this? I've posted twice and I think no one has an answer because there were no replies. If Alex, or anyone else knows the answer, please feel free to share
williamjames is offline Find More Posts by williamjames
Old Feb 05, 2013, 05:20 AM
Wettfeat is offline
Find More Posts by Wettfeat
"FPV"er not a "LOS"er
Wettfeat's Avatar
United States, NC, Charlotte
Joined Feb 2012
Originally Posted by AVIATION_RULZ View Post
....bump
If all else fails just solder the wires straight to the camera. Its a better connection anyways.
Wettfeat is offline Find More Posts by Wettfeat
Old Feb 05, 2013, 07:23 AM
LowlyElevated is offline
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
A RX isn't measued in power consumption like a TX is. If you are in doubt, go with a bigger battery on the RX
LowlyElevated is offline Find More Posts by LowlyElevated
Latest blog entry: More Miniquad FPV!
Old Feb 05, 2013, 09:05 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
The only true way to get a reading of the RX is manufacturer documentation or... testing it with a watt/multimeter.
Like what waffleman said... Its a RX, just put a bigger battery on it!
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Feb 05, 2013, 09:43 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Analysis paralysis. You are really overthinking this hobby. Just get a voltmeter from Ebay and connect it to the ground station. When the battery gets low, charge it.
After flying for many years, my ground station consists of a VRX glued to the back of a Crosshair antenna that hangs from a satchel on my side. Inside the satechel is a battery, a voltmeter and an on/off switch. That's it.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 05, 2013, 12:07 PM
Joined Jun 2011
Chris
-Alex
Thanks for the help guys. I just wanted to make sure that my ground station doesn't die on me if I'm a mile or two away. But both the voltmeter and bigger battery are great options. Appreciate it fellas
Old Feb 05, 2013, 12:56 PM
swartzracing is offline
Find More Posts by swartzracing
Aerial Operator
United States, CA, Sacramento
Joined Feb 2012
Hey guys I was curious if mounting my 1.3 800mw vrx to the back of my RMRC 5 turn helical will cause any problems?
Also the helical is my first semi directional Antenna, usually use blue beam set which works great. I was curious what the beam is like when it comes to height? I know the side to side is a pretty wide beam.
Thanks Again,
swartzracing is offline Find More Posts by swartzracing
Old Feb 05, 2013, 12:58 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Thanks Again,
A helical is not "semi directional", but clearly a directional antenna. No, mounting something behind the reflector does not hurt as long as you do not electrically connect it to the reflector (asuming it's conductive on it's back side).
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Feb 05, 2013, 01:57 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
-Alex
+1 on keeping it simple, Alex
most of my flying is done with my super simple ground station heh heh... 5.8 vRx/SPW & 4000mah 2C on my hat, fpv-japan recorder in my pocket, fatsharks on my peepers
Super simple, and the 4000mah batt was the only decent 2C lipo I had lying around when I tried the hat concept, I can go out for an all day fly with the guys and barely puts a dent in the lipo
AussieHoppy is online now Find More Posts by AussieHoppy
Old Feb 05, 2013, 02:02 PM
Aerial Operator
Joined Feb 2012
HTH
Markus
Thanks Marcus Appreciate it!
Cheers,
Old Feb 05, 2013, 02:50 PM
AVIATION_RULZ is offline
Find More Posts by AVIATION_RULZ
Canada, BC, Surrey
Joined Feb 2011
Hey guys, I don't have the Fatshark Battery to power up my Dominator goggles. Would it be okay if I powered it up with a 3S Lipo instead?
AVIATION_RULZ is offline Find More Posts by AVIATION_RULZ
Old Feb 05, 2013, 04:49 PM
Movie Guy is offline
Find More Posts by Movie Guy
Movie Guy's Avatar
Delta, BC, Canada
Joined Apr 2004
Originally Posted by stgdz View Post
going to take the ham radio license
What are the free online sites for studying up on it?
I used HamTest Online to great effect last year. Note that it is not free but you can do a free demo session to see if you like it. The Canadian test is similar but different and the online software knows that. It keeps track of what you have studied and has lots of study questions and practice exams. I ended up passing Basic with Honours when I took my test. I don't think this kind of study is right for everyone but it sure worked for me.
Movie Guy is offline Find More Posts by Movie Guy
Old Feb 05, 2013, 09:18 PM
Wettfeat is offline
Wettfeat's Avatar
Joined Feb 2012
No, Fatshark's run off of 2S (7.4V)
Old Feb 05, 2013, 10:10 PM
THOMASJONES is offline
Find More Posts by THOMASJONES
Closed Account
Joined May 2011
But here it says 2S-3S.
THOMASJONES is offline Find More Posts by THOMASJONES
Old Feb 05, 2013, 10:24 PM
kc10kevin is online now
Find More Posts by kc10kevin
Lt Col, USAF, Retired
United States, IL, Swansea
Joined Jan 2010
Yep...been running 3s for a year now. No issues.
kc10kevin is online now Find More Posts by kc10kevin
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 10:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
