This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old May 27, 2011, 07:33 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by QIK_RX View Post
Alex,
Thanks for the reply. Is there any instructions around in how to set it up with a DX8 with the head tracking gear? I have no idea, other than plug it in and turn it on. I do know some settings for set ups on my planes. But the fancy programing Im new at.
So any help or were to get help would be good.
Cheers,
Rob.
Not sure. Check www.fpvmanuals.com and see if they have something posted there.
Funny, Cliff and I are the guys giving all the advice here and we fly the most basic setups: 72 MHz, maybe an OSD, no LRS, no antenna tracker...
IBCrazy is online now Find More Posts by IBCrazy
Old May 27, 2011, 08:10 AM
QIK_RX is offline
Find More Posts by QIK_RX
QIK_RX's Avatar
Australia, QLD, Raceview
Joined Jan 2011
Im looking at a basic set up as well. Micro transmitter and cam. I only want to fly around my local park with fpv, im not realy looking at going miles away with it. I was looking at setting up one of my Parkzone planes with a camera for some fun while flying. I had already bought the DX8 as i had a heap of rx's from my dx6i. Might have to sell it and just go buy a futaba 9 radio.
QIK_RX is offline Find More Posts by QIK_RX
Old May 27, 2011, 09:52 AM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
2.4g RC, range checking, and camera lenses
There is certainly nothing wrong with a DX8 or DX6i. Not my first choice perhaps because I don't have one...
Of course you can't fly RC on 2.4g with video also on 2.4g... You may even determine from ground range tests that you need to filter the FPV transmitter signal to remove harmonics that are close to the 2.4g RC (e.g. 1280x2=2560 which is close to the 2500 at the top of the 2.4g ISM band). Best to ask around on that one. Maybe even start a question thread with that question if you can't find that someone already has started one.
If OSD with GPS is in your future, you may want to research avoiding GPS interference caused by the FPV transmitter.
I would use "long range" receivers as opposed to "park flyer" receivers, but as long as you can develop a safe way to test what you already have (with the FPV radio in it and switched on) just fly what you got.
You can put your plane up a non-metallic pole (the taller the better, but 3m should be OK) on the side of a hill or top of a rise with the camera pointing toward the control surfaces and set up your FPV receiver and stand by it with the RC transmitter a long way away. Wiggle the sticks and watch the controls through the FPV video. If both work try farther, always where you can see the airplane if you were to look at it with a telescope (Line Of Sight).
One thing that catches a few beginners is to make sure you have a "wide angle" or "fish eye" lens on the camera before you fly it. A 70 degree horizontal FOV (Field Of View) is a minimum. More than maybe 120 has a lot of distortion which will be a little strange the first time you land. The ground is far away and then is suddenly close. In the middle of that range is best.
Typically a lens with a focal length of 2.5mm (120 degrees horizontal) to 4mm (67 degrees horizontal) is what you want. Most cameras come with or have an option for a 3.6mm lens. That is fine and you don't need to buy anything else unless you want to experiment. 6mm or longer is not good, but you might get away with 6mm if you have the camera mounted on a pan (left-right camera moving) servo. These numbers are for 1/3 inch sensors and work well enough for 1/4 inch sensors. The smaller the sensor, the smaller the FOV given a fixed focal length. The 1/4 inch sensors will have a slightly smaller FOV angle than than described above.
Most security cameras (the size we FPV'ers use) have 1/4 to 1/3 inch image sensors and lens FOV is not described directly. They usually tell you the focal length (which is relative to sensor size). Point being that if you have a very small or very large camera the sensor may be smaller or larger than the stock 1/4 to 1/3 and you have to do a simple ratio with the lens focal lengths listed above to determine what you need.
Cliff
theothercliff is offline Find More Posts by theothercliff
Old May 27, 2011, 11:37 AM
ODUsurfer is offline
Find More Posts by ODUsurfer
Fly it like you stole it!
ODUsurfer's Avatar
United States, VA, Purcellville
Joined Aug 2009
Not sure if it's been posted yet, but I found this video to be a fabulous explanation for the different antenna designs.
There's a shout-out to IBcrazy in it too, hehe.
Flite Test - FPV Antennas - FLITE TIP (9 min 42 sec)
ODUsurfer is offline Find More Posts by ODUsurfer
Old May 27, 2011, 02:40 PM
IMEIV is online now
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Originally Posted by theothercliff View Post
"Geographically complex (rocky mountains)" and "don't loose FPV system"...
Hi Cliff,
if I understood correctly you suggest me a traditional receiver/transmitter system, I think to buy this because it's in Europe http://shop.righthere.nu/fpv-transmi...prod_1072.html I think that would fit...
Then I'm reading IBCrazy blog for to understand what CP antenna I need... but it's not simple.. where can I find CP antennas on sell ?
IMEIV is online now Find More Posts by IMEIV
Old May 27, 2011, 03:11 PM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
I have buy some on http://videoaerialsystems.com/products/ good work
eyesonsky is offline Find More Posts by eyesonsky
Old May 27, 2011, 03:21 PM
IMEIV is online now
IMEIV's Avatar
Joined Apr 2009
Old May 27, 2011, 04:02 PM
IMEIV is online now
IMEIV's Avatar
Joined Apr 2009
I studied a little about the links that Cliff showed me and perhaps would not recommended invest money in a Diversity receiver but rather in an antenna tracker to have polarization always perfect and always bet on the antenna model...
I hope to have said something right..?
Old May 27, 2011, 04:49 PM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Do you guys get the regular free shipping form bestoffer or do you pay for the tracking number? Not sure which way to go...it's 10 bucks more to get tracking and that doesn't even work sometimes, this is why I ask. Thanks.
By the way, you guys got any coupons for them... I'm about to order my cheapo video transmitter...just getting one, two gets expensive.
Oh well, I went ahead and added a couple more items to the cart and added the tracking number just to make sure I get it. So now I'll have a new cheap watch too. Mine broke so I needed a new one, I don't need anything special, as long as the time is fine it's good to me. Hey, almost all this stuff is made in China anyway, so might as well save me a buck or two.
By the way, I got some jst connectors, but there was one other connector you had on there that I may need for it? Never mind, I found it on page 48...Oh crud, I still need a camera...well that's no good.
http://cgi.ebay.com/RCA-FEMALE-JACK-...ht_2164wt_1141
efx is offline Find More Posts by efx
Old May 27, 2011, 08:32 PM
chemnut842 is offline
Find More Posts by chemnut842
United States, MD, North East
Joined Apr 2011
That receiver will cover all the 1.3g frequencies, but there are only two that are usable in the USA; 1255 and 1280. I am guessing that you are in the USA.
If you bought this (I bought one and it works well) you would get a receiver that does both of those frequencies plus a transmitter, plus a pair of decent dipole antennas. power supplies, and cables for less money ($49 shipped). The only down side I can find is that the transmitter is not the "tin can inside a heat sink" type, so you can't easily take the heat sink off the transmitter to make it lighter.
This is the only cheap system that I know of that has the uncommon 1255mhz frequency, so you can fly when everyone else has to share 1280mhz.
Ch 14 - E is 1255mhz
Ch 15 - F is 1280mhz
There are three kinds of diversity, they all need two antennas and you would need two preamps for any of them:
- a box with two receivers built in
- a circuit board that you attach to the RSSI of two standard receivers (you must attach a wire inside the receivers)
- a box that you connect the video outputs of two receivers to
Cliff
I bought the above linked combo and received it yesterday. I am building the ibcrazy cloverleaf for the tx and noticed that this model has a very small connector. Is that just an ssma connector?
- Joe
chemnut842 is offline Find More Posts by chemnut842
Old May 27, 2011, 08:50 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Wow Joe, that's a lower price...but it's too late for me now, as I already ordered mine. Please let us know how that one turns out for you. I guess that one also has the same frequency as the one I bought, if so, that would make a backup a good choice, even if just for the transmitter that I can use on my first one. But later I guess. I did notice the antennas are different.
Old May 27, 2011, 11:45 PM
AussieHoppy is offline
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
in all honesty i've having a hoot with the basics
PZ P47
HK 5.8 200
*ibcrazy's* CL/SPW antenna designs
and since i've been using CL/SPW i've not bothered with oracle diversity... simple, clean fun
AussieHoppy is offline Find More Posts by AussieHoppy
Old May 27, 2011, 11:48 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
I was just wondering, is there a housing for these cameras? I'm not sure if people are making their own or if there's a housing you can get for them?
Originally Posted by whakahere View Post
get this camera, cheap and standard for many here. http://www.securitycamera2000.com/pr...-Security.html
it has great low light and okay colour. many many many people fly on this camera.
Old May 28, 2011, 12:16 AM
mrdaction is offline
Find More Posts by mrdaction
mrdaction's Avatar
Joined May 2011
Thanks for the info, I have it working now with current monitoring and gps but no return home feature. Still waiting for the dragon link but I don't think thats coming any time soon can't even get a response to an e-mail from them guys.
Anyway Thanks
Dennis
mrdaction is offline Find More Posts by mrdaction
Old May 28, 2011, 01:00 AM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Housing is easy. there are mant method to keep it light for example shrink wrap, tape it down or the foam ball (I use this).
whakahere is offline Find More Posts by whakahere
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
