This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Dec 29, 2012, 12:23 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Originally Posted by williamjames View Post
IMEIV - Good timing... I just logged on to share my results right now too I'll tell you how my test went and then I have some questions for you regarding MuMetal.
My test: I basically powered up all of my components, video, OSD, VRx, Plane Rx, Futaba Tx, etc. With everything powered up, I was sitting (first beside and then in between) my VTx and VRx - Both times I got the same results which was very good picture quality with no video disturbance. I throttled up my motor with everything on and still no disturbance. Then, I noticed that as soon as I tilted the Dragonlink Tx antenna my way, the quality became not so good. When I touched the DL antenna to the goggles, the picture quality was most poor at this stage of the test. As I pointed the antenna away from my goggles, the picture quality again gradually improved.
Now- about your test: You mentioned MuMetal and covering your goggles with a special type of tape. Can you please attach a link to the tape you are referring to? As well, I would love to see pictures of your finished product so when you're done, can you please attach some picture?
Thanks in advance!
Hi,
yes we have got the same situation. Keep me informed on the progress you'll make.
I bought MuMetal in your country and here you can find a link http://www.ebay.com/itm/Ultraperm-80...item25654e9aa2
IMEIV is offline Find More Posts by IMEIV
Old Dec 29, 2012, 10:03 PM
saskya is offline
Find More Posts by saskya
DR , EVIL
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
This question puzzle me
What Dl video for a gopro hero 3
Very long range fpv will be the best
a ready kit with osd gps
trouble free if possible and easy to use?
I made research and this is what I find out so far
http://hobbywireless.com/index.php?m...roducts_id=457
saskya is offline Find More Posts by saskya
Old Dec 30, 2012, 07:36 AM
GroundAttack is offline
Find More Posts by GroundAttack
Ground successfully attacked!
GroundAttack's Avatar
Spain, AL, Lucainena de las Torres
Joined Sep 2011
Patch on a long Pole?
Can I put my 5.8 patch antenna on a long pole and extend the coax to my receiver?
If so, what would the maximum distance be?
Martin
GroundAttack is offline Find More Posts by GroundAttack
Old Dec 30, 2012, 08:48 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Martin
No, put the rx out to that pole, then extend the low frequency cables (AV, power gnd).
Basically using a patch - and I assume it's a linear polarized one - is not the optimal solution on 5.8Ghz. Way too many reflections. Use an SPW antenna on the ground and a cloverleaf on the plane. This will result in bigger range than what's flyable with the patch. If you want more range, use a circular polarized directional antenna on the ground but based on your questions, I'm almost 100% certain that a pair of CL and SPW will give you enough fun for the upcoming year.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Dec 30, 2012, 08:49 AM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Martin
Or course you can, but it is not recommended. There's no maximum distance, just account for x dB loss per coax length. See for example this calculator:
http://www.timesmicrowave.com/cgi-bin/calculate.pl
Don't know if it's accurate but you get the idea. E.g. 9 feet of the popular RG-316 at 5.8Ghz has 6dB loss. Hence you'll throw away 75% of your incoming rf-signal, so in this example you'll half your flying range. There's no simple yes/no answer, you must decide whether this is acceptable.
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Dec 30, 2012, 11:11 AM
Joined Sep 2011
Thanks!
I guess I will put the antenna and vrx on top of the pole and extend the video out cables...
Old Dec 30, 2012, 11:31 AM
Joined Sep 2011
rhcp
So I would be better off with these than the patch antenna?
Old Dec 30, 2012, 11:37 AM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
Don't buy those antennas. They are counterfeits of the real ones you can get from http://videoaerialsystems.com/ or http://readymaderc.com. Get the authentic ones and you won't be disappointed.
TexasAggie is offline Find More Posts by TexasAggie
Old Dec 30, 2012, 11:52 AM
LowlyElevated is offline
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Those are still better than Rubber Ducky anntennas. I know a guy who uses these with good results. The are immerscion/fatshark,which is a good brand, even if they are counterfit.
However, I wold recomend buying from one of the two recomwndwd above since those anntennas are made by the original designer of the cloverleaf/spw anttennas and are not knockoffs/coppies.
http://www.readymaderc.com/store/ind...roducts_id=550 is a really good set
LowlyElevated is offline Find More Posts by LowlyElevated
Latest blog entry: More Miniquad FPV!
Old Dec 30, 2012, 11:59 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
You can't possibly make such a sweeping implication with a single data point.
Old Dec 30, 2012, 12:07 PM
Joined Sep 2012
I am not saying that those are better that a RMRC or videoaerialsystems set.
However, basesd on what I have seen, these CP immersions perform better than LP rubber duckies, most noticably on the 5.8 band.
I thought that it was common knowledge in the FPV community that CP is almost always better than linear on 5.8. Better range and without multipathing.
Show me evidence otherwise and then I will beleive you.
Old Dec 30, 2012, 12:09 PM
Joined Sep 2011
RCGroups is great!
Thanks for the information and the pointers to the genuine products. They are not prohibitively more expensive than the HK ones.
Old Dec 30, 2012, 01:37 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
The burden of proof lies with the one making the claim.
Old Dec 30, 2012, 01:48 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
That, and you're supporting the people who actually did the hard work to develop the antennas, namely Alex Greve (IBCrazy).
Old Dec 30, 2012, 02:50 PM
Joined Sep 2012
But you are making a claim that a rubber ducky is better than an immersion CP set???
I do agree that RMRC anntennas are better, but these anntennas are not useless. I am not saying I like them, or would recomend them, but that these are better that the rubber duckies in the 5.8g band.
I am done on this. I am not going to sit here and argue over which anntenna is better.
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 10:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
