This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Dec 24, 2012, 07:44 PM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
Originally Posted by IBCrazy View Post
I see now. This is a case of a saturated sensor in the camera (at least in the video). If the camera has changeable settings, then adjust the contrast and brightness. Also reducxing the sharpmness might help. Other than that, I don't know if there is a solution other than a different camera or a higher F number lens.
-Alex
On the topic of cameras, which would be a good camera from secuirtcamera 2000 that can be used with my Dragon OSD? I want to be able adjust the picture quality settings at the field. Any recommendations?
I'm considering this one... any thoughts?
Also, if I do end up going with a board camera like the one above.... how do I mount it to my pan/tilt backplate
williamjames is offline Find More Posts by williamjames
Old Dec 24, 2012, 10:37 PM
mikenc is offline
Find More Posts by mikenc
Joined Jan 2012
You can by a case for that camera. I think that is same camera I have. Case adds weight and you have to trim board. Or there is a post in first page this tread that shows building camera case.
mikenc is offline Find More Posts by mikenc
Old Dec 25, 2012, 01:15 AM
efx is offline
efx
Find More Posts by efx
efx
Rookie in training, heads up
efx's Avatar
Los Angeles
Joined Mar 2010
Most who have that camera or similar build their own case. I bought the metal case and it did not fit. They then send me a replacement, it was the same thing and did not fit. Just get one with a case or you will have to build your own. Unless someone actually has a case I don't know about.
Here are the pictures of it.
http://www.rcgroups.com/forums/showthread.php?t=1455768
efx is offline Find More Posts by efx
Old Dec 25, 2012, 01:54 AM
redodedo is online now
Find More Posts by redodedo
HD FPV on a 4m glider
Canada, BC, Richmond
Joined Dec 2012
I want to get a UHF long range system, should I get rangelink or chainlink???
redodedo is online now Find More Posts by redodedo
Joined Dec 2012
and what are the main differences?? I heard that i SHOULD buy rangelink but still dont understand why. it seems like they have the same basic funtions
Old Dec 25, 2012, 05:13 AM
Joined Jun 2011
What you "should" buy is the product that you're well informed about. I bought a chainlink and then decided to go with a Dragon OSD... I felt that the wiring becomes confusing really quick if you try to interchange product lines. I would recommend dragonlink, which is the system I have now. Their product is solid.
Old Dec 25, 2012, 05:18 AM
Joined Jun 2011
I actually want to avoid cases. I have another solution for protecting the camera from the elements. But what I do need to know is how I can mount the board camera on the pan/tilt unit I mentioned above. I saw a couple of people using spacers between the camera and the backing plate... but I don't know where these spacers are bought and which size I would need..... anybody familiar with this??
Old Dec 25, 2012, 08:18 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Get the UHF radio that is best supported. The reason is that supported radio systems are constantly evolving and getting better. The less supported ones were never revised and thus you are likely to end up with a radio that disturbs your video feed and doesn't give you the range you want.
A few good ones (In no particular order):
RangeLink
DragonLink
OpenLRS
EZUHF
Scherrer
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 25, 2012, 08:20 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Buy that camera and forget the case. Just coat it in hot glue or silicone for weather protection. I have cased versions of that camera that I have destroyed in crashes (due to shock impact) where the open board would have survived.
-Alex
Old Dec 25, 2012, 05:14 PM
Boulybooly is offline
Find More Posts by Boulybooly
Boulybooly's Avatar
France, RA, Saint-Étienne
Joined May 2007
Yagi antenna
Hi Guys
Can someone tell me if this antenna i've fund on ebay will work for video transmission:http://cgi.ebay.fr/ws/eBayISAPI.dll?...84.m1438.l2649.
Thank you guys for your answers.
Boulybooly is offline Find More Posts by Boulybooly
Old Dec 25, 2012, 08:50 PM
Capt. Crunch is offline
Find More Posts by Capt. Crunch
It's all fun till Crunch!
Capt. Crunch's Avatar
InSane Diego
Joined Jan 2002
No, go back and read pgs 1-4 for the antena systems lesson.
Capt. Crunch is offline Find More Posts by Capt. Crunch
Old Dec 25, 2012, 08:57 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
well, it would work for receiving 2.4ghz video, but it would be extremely directional
CrashAffinity is offline Find More Posts by CrashAffinity
Old Dec 26, 2012, 03:16 AM
Joined Jun 2011
hey guys, I would like to have a spare set of connector wires for this camera. I bought spare cables a few months ago from the vendor for $4.50 and I thought that was over priced. As of today, the vendor is asking $8 for the same cables which I think is way over priced. I would like to know where I can find these types of connectors?.... what are they called?.... and how do I know what size to get?
Old Dec 26, 2012, 01:30 PM
efx is offline
efx
efx
efx's Avatar
Los Angeles
Joined Mar 2010
Do you mean this connector...for a little over 2 dollars..
http://www.hobbyking.com/hobbyking/s...s_for_FPV.html
Or these connectors...there are many types. BNC, F connector, male to male...etc...by the way just sort by price on ebay to get the lowest cost for price and shipping.
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Old Dec 26, 2012, 07:41 PM
Joined Jun 2011
Quick question regarding my throttle settings. For some reason, when I throttle up to 70%, I get full throttle. So when I have the throttle stick at like 30%, I'm really getting 50% throttle output. How do I adjust this so I get 100% throttle when my stick is pushed all the way forward and not when I'm at 70%?
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 15 Feb 01, 2015 10:12 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 8 Sep 12, 2010 07:12 AM
