This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Dec 14, 2012, 06:25 PM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
Originally Posted by IBCrazy View Post
^The sporatic jitters are because your transmitter is very close to your servos and the wires are not twisted. Twist up the wires and most of the jittering will be gone.
The other issue with the camera can be fixed by uncasing it and soldering directly to the board.
-Alex
This may sound like a dumb question but does it matter if the wires are braided INSTEAD of twisted??
Any one method do a better job at reducing noise?
williamjames is offline Find More Posts by williamjames
Old Dec 14, 2012, 07:09 PM
QUAD4EVER is offline
Find More Posts by QUAD4EVER
QUAD4EVER's Avatar
United States, TX, Houston
Joined Sep 2012
Related question - would wrapping the wires in conductive copper foil tape yield the same benefits as twisting?
QUAD4EVER is offline Find More Posts by QUAD4EVER
Old Dec 14, 2012, 07:28 PM
JLT_GTI is offline
Find More Posts by JLT_GTI
JLT_GTI's Avatar
Spain, Principado de Asturias, Oviedo
Joined Jun 2010
no... as far as i understand any shielding should be conected to ground..
What i used to shield the main wires (camera, video TX and PPM) was audio shielded stereo wire.. and use the external shielding as ground
More info here (in spanish)
JLT_GTI is offline Find More Posts by JLT_GTI
Old Dec 14, 2012, 07:48 PM
Joined Jun 2011
You need to solder the shield to the ground wire on one side only... the side that is transmitting. Failure to do this may result in the noise in fact being amplified.
Old Dec 14, 2012, 10:22 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You really need to do a little research on RFI and EFI. Once you get into it a little bit, you will understand certain techniques that minimize interference. However, some electronics are just sensitive to it and there is nothing you can do about it other than either switch to a lower VTX power, or replace the affected component. For 4-5km, 100mW is more than enough.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 15, 2012, 12:04 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
[QUOTE=JLT_GTI;23527686]Sorry to quote myself.. but i havent got much info on this..
Also i need sugestions for another problem..
Any hint or sugestion to how mount the camera wire? now i have it like this:
But im having problems.. the plug was well fixed with hot glue.. (so it doesnt move), but one of the wires broke inside due to the 180 pan movements.. its like i cant put the wire in a way where is not streesed when moved 90 to each side...[/QUOTE
Twist it so its like a curl
The wires from camera is straight wire but circular
This will show for travel without stress
Where wires come from camera add extra hot glue so they are not stressed
Make sure the camera does not turn to far around with stopper to prevent wires to get binded
Take off outer plastic from camera wires so they are more flexible
You can make wires move with camera and not bind this way
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Dec 15, 2012, 12:17 AM
David22 is offline
Joined Apr 2008
-Alex
If you use good servos the video tx and servo can be right on top of each other
It's best to choose best equipment the first time rather than need to separate stuff
Even with high powered video tx a servo works no problem when very close
Pick your components properly rather than have to separate them
This makes fpv much better
P
Once you find channel that works best hot glue that channel as well as connector to camera and video tx
No need for uncasing camera as hot glue makes for sold connection
Old Dec 15, 2012, 01:06 AM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
Hey guys, any of you know a good way to shield my tx from uhf so i can have my long range mounted on my transmitter... My tslrs gear sometimes caused problems or the a9 caused problems.... Any how u know what i mean. Ive sinced jumped ship and i have ezuhf enroute... Doing a chage over, had some issues on my smaller quads with interference and tslrs. Amazing system and worked great on my planes, any interest in it pm me. Ill have it the classifieds once i do the changeover
elliott000 is offline Find More Posts by elliott000
Old Dec 15, 2012, 02:59 AM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
The reason for twisting is inductive coupling. A radiated field will couple with nearby wires inducing a current in them. Twisting the wires causes the induced currents to balance and thus they knock themselves right out. This is how CAT5 and CAT6 cable work.
-Alex
Alex.. twisting wires or putting a toroid have a result the same function ?
IMEIV is offline Find More Posts by IMEIV
Old Dec 15, 2012, 08:54 AM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
Twisting will cancel out nearby EMI (of any frequency), a toroid just blocks high frequencies.
I would not use toroids for signal wires such as servos and video signals; these wires carry high frequency signals which you don't want to block. So use twisting here. Use toroids for dc-power wires like between battery and camera/vtx.
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Dec 15, 2012, 08:57 AM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
But the shielding is the ground itself .... it needs to be conected to each side or there is no ground
Old Dec 15, 2012, 09:17 AM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
Martin
any guide on twisting? i just twist the wires as much as possible without the wires "notting" ..it seems to be quite easy and it remains twisted rather well.. that makes me think i might be doing something wrong
Old Dec 15, 2012, 09:41 AM
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
I think the (different!) twist rate is only important when using multiple twisted pairs inside one cable. For a couple of different cables it should not matter that much; just use enough twisting so that EMI-exposure will be equal for both wires. And maybe even more important, use some separation between different cables to lower EMI in the first place.
Martin
Old Dec 15, 2012, 11:01 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
While for the most part I agree with Martin, I have put toroids on servos and it had no effect on the servo at all. However, as he stated, separation is a key ingredient to success as well as twisting.
-Alex
Old Dec 15, 2012, 12:28 PM
JLT_GTI is offline
JLT_GTI's Avatar
Joined Jun 2010
i have twisted 5 wires..
2X servos (the plane uses 2 servos only) wich are internal and 15cm only
1XESC wire
1XCurrent sensor wire
Theese two come out of the OSD directly to each ESC and current sensor.. i have twisted the part of them that goes inside the plane , since both ESC and current sensor go in a pod over the wings , so i made an internal extension and then plug them from outside.. the only untwisted part is the part that go from both ESC and sensor to fuselage .. but they can be twisted easily tought
Still... if i usually dont have noise , neither in the video or in the controls and only noise in the controls apears ocasionally.. does that discard internal noise (from Video Tx, OSD, etc)?
And if i had that noise with all unshielded wires and still have it with shielded wires?
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 11 Aug 16, 2016 11:08 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
