This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Old Dec 04, 2012, 12:00 PM
markus123456 is online now
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by jasmine2501 View Post
So the only thing I'm missing is the voltage regulator? I am running a 1S lipo right into it. It gets hot when the battery is fresh, but the behavior doesn't change. It comes with an SMA connector I just didn't solder that on.
Yeah that's the behavior I would describe it's like there's no antenna at all. I couldn't get the wire they sent to attach - it was too big and not fitting in the little cavity so it wasn't making contact for me to solder it, so I grabbed some servo wire and used that, but by that time I had messed up the pad so much it didn't really attach right - for what I can see, it might be attached to the ground. I used my magnifying glass, but I really need a microscope for this little stuff. Also, shouldn't we be using solid wire for antennas anyway?
Solid wire is good as the antenna should remain straight, but it does not take a thick wire for this. i.e. a 0.6mm copper wire would do and would be solid enough.
If you put the module in front of you such that the side with five connections (powere, video and audio in etc) looks towards you and the other connections are on the top, the antenna connection would be the second from the left. The first and third are gnd connections. The following thre ones are for the channel selection.
HTH
Markus
The connection you should use is
markus123456 is online now Find More Posts by markus123456
Old Dec 04, 2012, 12:04 PM
austin.laws is offline
Find More Posts by austin.laws
Night flier
United Kingdom, England, Bromyard
Joined Mar 2008
Hi how come when I connect my nano fpv kit to my ladybird I get bad pic. Using 1 cell lipo that powers the board. Is there a way to stop this from happening.
austin.laws is offline Find More Posts by austin.laws
Old Dec 04, 2012, 12:38 PM
Cid156 is offline
Find More Posts by Cid156
Cid156's Avatar
Switzerland
Joined Sep 2008
What stuffs did you use?
Cid156 is offline Find More Posts by Cid156
Old Dec 04, 2012, 02:28 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
On the one I got, the connections were labeled on the back, so it's pretty hard to get the wrong one, but I have trouble actually seeing this little stuff, so what I think happened is, I stuck the end of my antenna wire into the little 'hole' in the ground plate, and heated and soldered until it stuck, and I think it's actually stuck to the ground, not the antenna. I ordered two more units and I'll just consider this one a practice run. I'll be putting the SMA jack on one to use with bigger stuff and CP antennas, but for the mQX I didn't want all that extra weight. If I can't get these to work, I'll just go back to using 1.3 stuff - my 1.3 stuff works great! I just thought this might be a lighter weight alternative.
jasmine2501 is offline Find More Posts by jasmine2501
Old Dec 04, 2012, 04:02 PM
Night flier
Joined Mar 2008
Model is a qr ladybird and stuff is from fpv hobby.com 5.8ghz Vtx and Vtx. 200 me power. Plugging into aux port. Did same with mcx too. Use separate battery and all well. Wots the problem?
Old Dec 05, 2012, 12:50 AM
williamjames is offline
Find More Posts by williamjames
United States, FL, Miami
Joined Jun 2011
I would like to know how far I can fly using this setup:
1 - 1.3ghz 800mw TX
2- CL/SPW
3 - Minimal RF noise area
I want to know the max. video range only... not how long I should expect to fly or anything like that. I have have flown FPV before, I just would like to know how far this system can go.
Cheers
williamjames is offline Find More Posts by williamjames
Old Dec 05, 2012, 02:55 AM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
I don't know a practical answer William, but for a theoretical answer you'll also need this one:
4 - receiver sensitivity in dBm
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Dec 05, 2012, 04:36 AM
Registered FPVer :)
Joined Aug 2006
Ok, this explains it then, as the vias do definately not carry the antenna signal. Doing so would be suboptimal for a HF signal on 5.8Ghz.
I have special "watchmaker" googles with 8x magnifying glasses. That helps a lot. I too could not do that without.
HTH
Markus
Old Dec 05, 2012, 04:41 AM
Joined Jun 2011
Martin
To be honest Martin, I don't even know what that is
Old Dec 05, 2012, 08:38 AM
mikenc is offline
Find More Posts by mikenc
Joined Jan 2012
Need some advise
Made it out to 11/2 miles yesterday. Longest flight for me. Using 1280 vtx 72mhz rx . Video was good all the way out, started getting static on the way back right after making turn to home. Had some problem with rx link also a few times. No drop out when going away just after i turned back toward home.
I have V antenna mounted on vert. stab. Rx antenna runs under wing.
I have twisted my servo wires and it increased rx range by at least double.
(Alex recommended twisting servo wires )
Using listed equip. below
http://www.readymaderc.com/store/ind...oducts_id=1017
http://www.readymaderc.com/store/ind...roducts_id=417
http://www.readymaderc.com/store/ind...roducts_id=301
Would moving V up higher make a difference? Or maybe placeing on wing would be better? I use patch antenna setting close to ground and turn it in direction i am going to fly.
Is there a different antenna set up that would work better?
Should note only lost video completly for few seconds twice which seemed much longer. Had quite a bit of static several times.Trying to get out to about 3 miles.
I have been flying usually above 500 ft when going out to a mile or so. So signal should not be getting blocked by trees. Pretty safe to fly high where i fly, planes flying under 2000 ft will fly into mountain side.
Your thoughts, ideas appreciated.
Michael
mikenc is offline Find More Posts by mikenc
Old Dec 05, 2012, 08:56 AM
KentF is offline
Find More Posts by KentF
FunkMaster
KentF's Avatar
United States, OH, Mason
Joined Jan 2011
Antenna placement
Michael,
I have the same antenna. I've placed mine out on the wing with my DragonLink antenna on the other wing. Been out about 4.5 miles with this setup and the video always gets better on the return trip due to the placement but it's actually still very good before I turn back too. I'm running RMRC 1.3Ghz Vtx but mine is 1500mW.
I'm using Alex's BiQuad antenna on a tracker. I believe it has a little higher db than your patch (maybe 11db).
Kent
KentF is offline Find More Posts by KentF
Old Dec 05, 2012, 09:43 AM
mikenc is offline
Joined Jan 2012
Originally Posted by KentF View Post
Michael,
Kent
Nice plane Kent thanks for input. Been looking at one of those on RMRC web sight.I am flying a Skywalker at present time for FPV. Looking to get a new plane in future and have been considering one like you have. Skywalker's are nice planes but by the time you order one from china and have to buy all the materials to reinforce wings along with all controls the penguin comes in at about same price.
Is your vtx out under wing also, or did you extend the antenna cable? Cable on my v antenna is pretty short. Do you think the Biquad would be better just using it without tracking.
Do you have any videos posted of your plane flying FPV?
Michael
Old Dec 05, 2012, 10:48 AM
Rocket Programmer
Joined Jul 2007
Do you have a link for that? I just use reading glasses from the store.
Old Dec 05, 2012, 11:47 AM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Michael
I mount the vtx under the wing and run the antenna up through a hole. Seems to work well but I had to add a little weight to the opposite wing because the dragonlink antenna is not very heavy. The BiQuad will get you more distance but has a more narrow beam. I think there are people (even IBCrazy) that use a biquad without a tracker. I think I remember seeing him post that.
Sorry no videos right now. One of these days I'll get around to getting a small DVR.
Kent
Old Dec 05, 2012, 11:48 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
If you are having trouble getting past 1.5 miles, you need to evaluate your ground station. Make sure your patch is in the correct polarization and nothing is disturbing the Fresnel zone. Mount your antenna on the wing as well.
The below flight was done on 125uW (1/8th mW). This is over 5,000 times weaker than your system.
125uW test flight - 2250 feet (3 min 18 sec)
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 11 Aug 16, 2016 11:08 PM
Discussion How to calculate flight time - guide ikorman Multirotor Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 08:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
