Joined Mar 2009
Yes soldering is the most reliable, and I would even get further, don't solder wires "in the air" and then tape them, rather use a small prototype board as here
(Don't worry, in this example there are several additional wires for oscilloscope measurement.) I found this practical when I had to solder/desolder some wires without touching the other ones, for example to connect the osd to the anyvolt or to the battery directly, to add or remove capacitors etc. Now the pcb has been cut to its smaller possible size, and finds its place ahead inside the cockpit. |
Joined Mar 2009
I wouldn't give a definitive limit, but some comparisons. In the PC world, you can find 5 meter cables to connect the screen to the PC. It's using a shielded cable and you can see a slight image degradation, but really slight. The video signals used in this case have a far greater bandwidth (~180 MHz) than our tv signals (~6MHz). So don't have too much worries about using for example 30-50 cm of cable for the camera cable. What's more, camera signal is around 1Vpp, it's not a minute signal which would be more sensitive to noise around. So try it first, I would use a twisted servo wire. Another comparison : the network cable cat 5 that everyone is using is not shielded (utp = unshielded twisted pairs), but it carries high frequency signals (for the 100mbps) up to 150 m away, most of the time they are grouped with lots of similar cables and electrical installations, without any interference. these cables are similar to the twisted servo cables. But it's important that they are twisted. |
-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
Joined Jan 2011
Oh of course. I was planning on using ArdupilotMega for all of my autopilot and telemetry stuff. I was just wondering if the autopilot would need its own dedicated transmitter on the ground, or if perhaps I could use the same transmitter that I would use to manually control it as I would to send autopilot commands. Edit: Ah HA!! Okay, now I think I understand how this works a bit more.... I was thinking all of the autopilot stuff (corrections etc..) was actually generated by the autopilot on board the aircraft. But in actuality, the corrections and such are really generated on the ground, and sent out through the manual flight transmitter. Or am I wrong? I've looked all over for some kind of a description as to how this system actually .... works. |
If you are flying out in the middle of nowhere, 2.4GHz is likely better. If you are flying near a park or housing, 900 is the way to go. |
Posted this earlier in another thread but seems it might be better suited here...
Just looking at getting into FPV on my Gaui 330x. Mostly for just close park flyer type use for playing around with 500-600 meter range or so, no long range requiremnt for now anyway. Looking at the Fatshark RCV922 5.8 system: http://www.nghobbies.com/cart/index....aa322f3990e34f Realistically is this a good starting point and is the included Tx/Rx good enough for this sort of distance or would one relaly need to use a seperate Rx than those built in or a different Tx? Any general suggestions on a good "all in one" kit or suggested setup for such use? Will be using DX6i 2.4 Spektrum Tx/Rx so needs to be something compatible. |
Looking for something to use with Spektrum setup so this seemed to match up well. |
The autopilot functions can work without stabilisation as it uses GPS for course correction (you mat need a reasonably stable airframe) cheers Mike |
What I'm really looking to confirm is how well this actually will work with the 100mW Tx and built in Rx and what sort of range I can expect. Also would this unit upgrade well down the road if I wanted to add OSD, head tracking, and better range? Like to get something simple for now that will grow as I move forward with FPV if possible. |
![]() However, if I were to go down the 5.8GHz road I would try these goggles which have dual VRx (2.4 & 5.8GHz), built in HT and the same resolution as the Fatsharks (640x480). For me they're $429.99: http://www.hobbyking.com/hobbyking/s...dProduct=12175 |
| Thread Tools | |
| Discussion How to calculate flight time - guide | ikorman | Multirotor Talk | 11 | Dec 30, 2011 07:22 PM |
| Discussion How many FPV pilots in the world? | rbmaze | Video Piloting (FPV/RPV) | 10 | Aug 03, 2011 06:16 AM |
| Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? | FPVNOW | Video Piloting (FPV/RPV) | 36 | Oct 06, 2010 08:56 PM |
| Discussion Can this cam be used for FPV ? | SpookiePower | Video Piloting (FPV/RPV) | 8 | Sep 12, 2010 07:12 AM |
| Cool How cool would this be for FPV | Kai_Shiden | Video Piloting (FPV/RPV) | 2 | May 11, 2009 07:41 PM |
